265 spare ok with 275 tires?
Discussion in 'Wheels & Tires' started by danssr5, Sep 13, 2019.
  1. Sep 13, 2019 at 11:39 AM
    danssr5
    danssr5 [OP] New Member
    Dan
    2017 sr5 premium 4x4
    Do you really need to swap the spare for something this small a change in size.
    Any real world experiences with this?
    Thanks!
  2. Sep 13, 2019 at 11:59 AM
    I've been told it will be fine.
    That is to say that you can use it in a pinch without damaging anything, but you should only use it as long as you need it.......basically use it on your drive to get to the tire shop.
    No real world experience, but I do have 285's with a 265 spare and no plans to upsize unless I blow a spare one day.
  3. Sep 13, 2019 at 12:25 PM
    4x Old Guy
    4x Old Guy New Member
    Riverside, CA
    Big-O Bigfoot A/T tires
    I bit the bullet and bought 5 tires and upgraded my 4000 mile “Dumblop” spare at the same time I got some “real” AT tires (Big-O Bigfoot A/T which are re-branded Cooper AT3s). Part of my thinking was that I’d hate to be out in the weeds somewhere where AT tires are a must and have to put a not-so-grippy “street” tire on the ground. I use a 4-tire rotation so, when the 4 that are always down wear out, I’ll put the best of the worn tires as the spare, put the nearly new spare on the ground and will only have to buy 3 new ones at that time.
  4. Sep 13, 2019 at 12:30 PM
    Firefly21
    Firefly21 New Member
    Duane Frazier
    18 off road premium trd
    Hid lows 3500 drl / high Led interior Led reverse Led oem fogs Sequential blinker Trd intake Unifilter pump mod Apex recover points BF Goodrich KO2 (matching trd spare) Kicker front tweeters Tvd overlays S2 yellow wide fogs Apex black sequential rear tails Cartrim home blue convex mirriors
    If you rotate in that spare your tires will last you 20% longer and if you have a damaged (unrepairable) tire you have an equally wore replacement ready to go
  5. Sep 13, 2019 at 12:46 PM
    4x Old Guy
    Riverside, CA
    I thought about that, but 1) the spare is a plain steel rim, and 2) there is no TPMS sender on the spare, and 3) Toyota’s TPMS only accommodates 4 senders. In order to do a 5 tire rotation I would have to dismount and mount 2 tires during each rotation.
  6. Sep 13, 2019 at 12:48 PM
    Dillusion New Member
    KYle
    I roll with the 265 spare even though I got 285s.
    But I do carry a plug kit and 12V compressor.
    Living the dream likes this.
  7. Sep 13, 2019 at 1:01 PM
    Firefly21
    Duane Frazier
    Sorry i thought you had a full size wheel for spare. I got an additional trd wheel at the 40% off sale and plan on a 5 wheel rotation as soon as mount new rubber on all 5
  8. Sep 13, 2019 at 3:26 PM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    I think you would be fine with a smaller spare. I would run it in the back though in the event you need it.
