265/70/18 with 3" lift rubs in reverse
Discussion in '5th Gen 4Runners (2010-2024)' started by Dakine_8zero8, Dec 2, 2019.
  1. Dec 2, 2019 at 12:47 AM
    Dakine_8zero8
    Dakine_8zero8 [OP] New Member
    2019 4 Runner SR5
    3 inch suspension lift
    I have a 2019 Runner with a 3 inch suspension lift with 265/70/18’s and it rubs in reverse. Rubs the front bumper. Would spacers help?
    irep8oh8 likes this.
  2. Dec 2, 2019 at 3:22 AM
    Trident904
    Trident904 That Guy
    Brian
    Treasure Coast, FL
    22 TRD Offroad Premium on 35’s
    King 2.5 with resis, C4 Hybrid Front, TC Uppers, Victory Rack, Smitty 12k winch, 17x9 -38 SCS F5’s with 295/70 Ridge Graps
    You are on a 32.6” diameter tire. It is likely rubbing on the cab mount. You can either add some caster to the alignment and see if that helps or do the cab mount chop.
  3. Dec 2, 2019 at 5:48 AM
    Todi
    Todi New Member
    Maryland
    2018 4Runner TRD Off-road
    M.O.R.E. aluminum skid set; Artec aluminum gas tank skid and LCA skids; C4Fab rear diff skid; HeftyFab Banshee front bumper; RezFab flat sliders; SSO rack; 285/70-17 E Falken AT3W; Ironman 4x4 Foam Cell Pro Stage 3
    If it rubs on the front bumper, you need to do a front liner mod (Google it and there are several videos on this). Spacers will not fix it as the turn radius increases and it will rub when you turn.
  4. Dec 2, 2019 at 5:58 PM
    Backwoods
    Backwoods New Member
    2019 silver SR5 4x4
    What's your offset?
    And if it's rubbing on the front bumper, neither the fender liner mod or a body mount chop will solve that.
    I'm on 285s with -10 offset and rubbed the front bumper on the bottom. Unless you actually trim the bumper itself where it's rubbing you will continue to rub. Once you trim that area you might start rubbing on the fender liner as well, and then need the fender liner mod.
    I have the front bumper trimmed, fender liner mod, and the cab/body mount chop. Now no matter what I do there's no rubbing.
    Before the trimming and chopping... I rubbed front bumper forward or reverse, on any sharp turn.
    After bumper trimmed no more rubbing, went ahead and did the fender liner mod and body mount chop just to be safe..
    Don't need to trim very much, and a sharp razor knife is all that's really needed. You can use a Dremel... But a sharp razor works.
    irep8oh8 and jgcaps like this.
  5. Dec 2, 2019 at 6:01 PM
    Just chop the bottom corner of the front bumper and good to go.
