265/70/17 AT on a stock 5th gen?
Discussion in '5th Gen 4Runners (2010-2024)' started by Anotherreject, Sep 16, 2018.
  1. Sep 16, 2018 at 3:06 PM
    Anotherreject
    Anotherreject [OP] New Member
    I have a completely stock 2018 4runner and was looking to upgrade from my factory dunlap tires. I want to stay in the stock size. My question is does anyone have pictures or first hand info on 265/70/17 tires in an aggressive a/t tread or an m/t tread on a stock 5th gen? Im asking because i know some tire brands can fit a little differently depending on the tread, especially on an m/t.
    I dont want to drop several hundred on tires and mounting on "stock" size tires only to find out they tread rubs or etc...
    I saw the tire info thread but many people have lifts and aftermarket wheels
    toy33 likes this.
  2. Sep 16, 2018 at 3:31 PM
    Dark Knight
    Dark Knight Get off my lawn
    Although there are slight size differences, a 265/70/17 tire size is safe all around with no lift. Pick any tire you like in that size for no rubbing when mounted on a stock wheel.
  3. Sep 16, 2018 at 4:35 PM
    Anotherreject
    Ok thanks
  4. Sep 16, 2018 at 5:05 PM
    rsimi72
    rsimi72 New Member
    2017 SR5 Premium - Gray
    I think the TRD PRO comes with Nitto Terra Grapplers. Should be lots of pics of those floating around and maybe even at dealerships for you to check out.
  5. Sep 16, 2018 at 6:59 PM
    Area52
    Area52 New Member
    PHX
    ‘20 SR5p
    97796DF6-A7A9-44A9-A8CB-A53C4876307C.jpg 140BB8E5-7D4D-4681-B80E-B98CC0389C6A.jpg
    265/70 17s atw3 with stock suspension no rubbing and the wheels are 0 offset so they push out a little further than stock
    Grilla36 and hurley119 like this.
  6. Sep 17, 2018 at 10:15 AM
    doublewide
    doublewide ShittCo
    TRD OR PREM
    @Anotherreject I put General Grabber AT/X 275/70 17's on my "non lifted...yet" TRD OR and have had NO rubbing issues. So I think you'd be fine with the stock tire size.
    Grilla36 and Pushyguy like this.
  7. Nov 4, 2019 at 1:28 PM
    carsgarrett
    carsgarrett New Member
    Is it possible to put the TRD Pro 17" Wheels on a stock 2018 5th Gen with Falken Wildpeak 265/70 R17 tires without any rubbing?
  8. Nov 4, 2019 at 5:46 PM
    Area52
    Area52 New Member
    PHX
    ‘20 SR5p
    TRD pro’s are +4 offset with 4.5 back spacing. My wheels above were 0 offset and 4.5 bs with no rubbing so I imagine you’d be fine at +4
  9. Nov 5, 2019 at 5:05 PM
    Firefly21
    Firefly21 New Member
    Duane Frazier
    18 off road premium trd
    Hid lows 3500 drl / high Led interior Led reverse Led oem fogs Sequential blinker Trd intake Unifilter pump mod Apex recover points BF Goodrich KO2 (matching trd spare) Kicker front tweeters Tvd overlays S2 yellow wide fogs Apex black sequential rear tails Cartrim home blue convex mirriors
    Wild Peak AT3s 265/70/17 stock size on TRD wheel no issues
  10. Nov 5, 2019 at 6:20 PM
    carsgarrett
    Thanks so much! This is what I thought but wanted to make sure.
  11. Nov 6, 2019 at 12:00 AM
    MountainMan
    MountainMan New Member
    Pacific Northwest
    Goodyear Wrangler Authority tires ordered online from Walmart for $600. They look sexy, perform amazing off road, and are cheap. But, they kill gas mileage and ride a little harsh.
    rsimi72 likes this.
  12. Nov 9, 2019 at 3:48 AM
    Joekader
    Joekader New Member
    Joe
    Should have gone with falken at3 great tire and ride is close to stock and excellent off-road plus the gas penalty was about 1mpg
    J
  13. Nov 9, 2019 at 5:50 AM
    I'm stock. These are stock size KO2's. They rub slightly on occasion, but I think it's due to a wider rim and negative offset.
  14. Nov 9, 2019 at 2:54 PM
    Area52
    Area52 New Member
    PHX
    ‘20 SR5p
    Are those pro comp wheels? If so did you go with 0 offset or -12 ? They look good. I was trying to get those but they were out across the country so I went with a different style.
  15. Nov 9, 2019 at 3:05 PM
    cmtaz
    cmtaz New Member
    Stock as of now....
    I just replace the stock Duelers with 265/70 17 Wildpeaks on my TRD rims.
    They fit fine, look great, and the 4Runner rides a little better.
    I will be going to Bilsteins 5100 (.85") but that's cause i want to ... the tires are fine on stock suspension.
    WallyT4R likes this.
  16. Nov 9, 2019 at 3:39 PM
    WallyT4R
    WallyT4R New Member
    Check out Eibach
  17. Nov 9, 2019 at 4:16 PM
    Thank you!
    Yes, 05's. They're 17×9, -6 offset. I had planned on getting the 17×8, 0 offset, but I changed my mind at the last second.
  18. Nov 11, 2019 at 7:07 AM
    cmtaz
    cmtaz New Member
    The kit or the shocks? I'm not looking for the 2.75" / 1.0" lift, but if there is feedback on the Eibach shock w/ stock springs i'd love to hear it.
  19. Nov 11, 2019 at 11:49 PM
    WallyT4R
    WallyT4R New Member
    Eibach pro kit does exactly what you want to do. I have it and it works great.
    SlvrSlug likes this.
