265/70/15 on a 92 4Runner?
Discussion in 'Wheels & Tires' started by larryduran90, Mar 11, 2019.
  1. Mar 11, 2019 at 11:15 PM
    larryduran90
    larryduran90 [OP] New Member
    L
    1992 4runner 4z4
    Hello, I have a 1992 4runner, 4wheel drive. I want to know if 265×70, 15 will fit on the truck. I want to buy some general grabber at2. Please give me some advice.
  2. Mar 12, 2019 at 3:19 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Yes they will fit that’s probly close to oem size.
    SlvrSlug likes this.
  3. Mar 12, 2019 at 7:44 AM
    larryduran90
    L
    1992 4runner 4z4
    Yes they are. The oem us 225, 70, 15. I was just concerned because im buying them used with the wheels mounted on them. The pattern is 6 bolts.
  4. Mar 12, 2019 at 8:34 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    Make sure the center bore is big enough. I think it may be 106mm?
  5. Mar 14, 2019 at 7:43 PM
    larryduran90
    L
    1992 4runner 4z4
    What about ko2 31,10,5
  6. Mar 15, 2019 at 12:08 AM
    Dezman92
    Dezman92 New Member
    Doug
    Norcal
    1994 Green 4runner
    Yes, they will fit. They'll look good too! Those are slightly smaller than 31x10.5r15, which I have on stock suspension with no issues at all. I think they're about 30" in diameter and just a smidge under 10.5" wide. Make sure the bore in the center of the wheel is big enough to go over the hub.
    HoBoDanny likes this.
  7. Mar 16, 2019 at 8:23 AM
    larryduran90
    L
    1992 4runner 4z4
    Do I have to worry about my transmission gears getting compromised?
  8. Mar 16, 2019 at 8:25 AM
    larryduran90
    L
    1992 4runner 4z4
    9420, how many miles on your 4runner?
  9. Mar 16, 2019 at 11:29 AM
    Dezman92
    Dezman92 New Member
    Doug
    Norcal
    1994 Green 4runner
    No you don't have to worry about the gearing with those tires. My runner has 193k. Once you go over 33" that's when you have to start worrying. The owners manual says that you can use 31x10.5 on a v6.
  10. Mar 16, 2019 at 11:31 AM
    Dezman92
    Dezman92 New Member
    Doug
    Norcal
    1994 Green 4runner
    You have nothing to worry about gear wise with the tires you are looking at, you can actually bump it up to 31x10.5 if you wanted to assuming you have a v6. Yours is a v6 right?
  11. Mar 17, 2019 at 8:43 PM
    larryduran90
    L
    1992 4runner 4z4
    Yes, mine is a v6. I just got it, Its a project truck.
    What type of oil do you use?
    Thanks
  12. Mar 17, 2019 at 8:49 PM
    larryduran90
    L
    1992 4runner 4z4
    I will post pictures next week with the 31×10 tires.
  13. Mar 18, 2019 at 9:34 AM
    Dezman92
    Dezman92 New Member
    Doug
    Norcal
    1994 Green 4runner
    I just run 10w30. Here's a pic of my truck with 31's, they're bfg all terrains.
