255/80R17 tire size
Discussion in '5th Gen 4Runners (2010-2024)' started by szuyung3000, Sep 27, 2018.
  1. Feb 26, 2025 at 8:33 AM
    #301
    CRasch505
    CRasch505 New Member
    Chris
    Rio Rancho NM
    5th Gen 4Runner ORP
    Trail edition wheels, Falken AT4W 255/80, Eibach stage 1, Super Pro UCAs, OEM rock rails, roof rack delete, no-scoop hood, ceramic tint on all glass.
    This is my setup. I think these are the trail wheels. Fits perfect with no spacers.
  2. Feb 26, 2025 at 8:35 AM
    #302
    CA4runner
    CA4runner New Member
    Nor Cal
    2019SR5
    6112s, TRD F2 wheels
    +15 is the offset of your FJ/trail wheels. From the looks of the reuslts the position of the tire is only slightly inward and most of the girth your losing in tire width is on the outside..
    scottiezilla likes this.
  3. Feb 26, 2025 at 9:42 AM
    #303
    MEski4x4
    MEski4x4 New Member
    2024 TRD Pro
    Looks like I am going with 255/75/17 - I don't want E load, so I can go a tiny bit smaller and get Toyo AT3s in C load. I've got a Pro with Pro wheels ('24) so I think I would be struggling with the 255/80 anyways. 275/70 is the only other option I am considering.
    BC Hunter and CRasch505 like this.
  4. Feb 26, 2025 at 11:56 AM
    #304
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    I was in the same boat as you, I considered skinnies but I like better the width of 265 and up. I wanted C load tires (absolutely didn't want E load).
    Also didnt want to modify anything suspension wise for now (might get a small lift eventually with Eibach springs).
    I started looking into 275/70 because its the perfect width IMO (not too wide, not too skinny) and slightly taller than stock without worrying about any other modifications (BMC, UCAs, etc..)
    as far as I know wildpeak falken are the only ones that comes with load C in that size. I chose AT3W over the new AT4W because several people have said the AT4W are slightly worse in the snow and also I was able to find AT3Ws for $250 cheaper for 5 tires.
    After install and alignment I had very minor rub at full lock in reverse. Most people wouldnt care but since I do offroad often and need all the space for articulation I trimmed ever so slightly the front fender for peace of mind (not noticeable).
    I had them for about a few days and really happy so far. IMO all the offroad trims should have came in at least that size
    Check this thread if you want to see pictures. I added some as well a few days ago
    MEski4x4[QUOTED] likes this.
  5. Feb 26, 2025 at 12:06 PM
    #305
    MEski4x4
    MEski4x4 New Member
    2024 TRD Pro
    Just looked at your pics - those look great.
    My big gripe is the Wildpeak AT3W is the weight. 57lbs vs 48lbs for the Toyo.....that's E load range weight right there.
    5six and Trail Runnah like this.
  6. Feb 26, 2025 at 1:39 PM
    #306
    scottiezilla
    scottiezilla New Member
    IMG_6107.jpg…but this story is far from over
    I’ll be posting my “nightmare” after I affirm one more event…
    Side note:
    Headed to other thread with this…what have you done today
  7. Feb 26, 2025 at 1:56 PM
    #307
    semprenissart
    semprenissart Mèfi
    Yes, anything that is not SL in a 275/70 is going to be heavy compared to pizza cutters. Even more more for the Falken Wildpeak like you said. I didnt care much about weight (even though lighter is obviously prefered).
    My main concern with the E load was how stiff they ride compared to C load
    If that is a big factor for you then skinnies are definitely better in that aspect.
  8. Feb 26, 2025 at 4:02 PM
    #308
    Gman2530
    Gman2530 New Member
    2018 SR5 4wd 4Runner
    clean clean clean rig! Looks just awesome
    CRasch505[QUOTED] likes this.
  9. Feb 26, 2025 at 4:08 PM
    #309
    CRasch505
    Chris
    Rio Rancho NM
    5th Gen 4Runner ORP
    Thank you!!! It's a bit different that most setups but I love it.
  10. Feb 27, 2025 at 3:32 PM
    #310
    Fishbum
    Fishbum New Member
    Why does no one make a 255-80 in c
    MEski4x4 and semprenissart like this.
  11. Feb 27, 2025 at 3:35 PM
    #311
    scottiezilla
    R1200Jedi, hossler1788 and MEski4x4 like this.
  12. Feb 27, 2025 at 4:30 PM
    #312
    Acesandeights
    Acesandeights #34
    2024 ORP
    Too much sidewall flex.
  13. Feb 27, 2025 at 4:34 PM
    #313
    Fishbum
    Fishbum New Member
    But you can get a 33 10.50 in a 15 that's not too much wider and would have at least equal if not more amount of sidewall
    Trail Runnah likes this.
  14. Feb 27, 2025 at 6:03 PM
    #314
    R1200Jedi
    R1200Jedi New Member
    2022 4Runner ORP
    My guess is because there is no market for it. Aside from a few of us goofballs who like skinnies on our trucks, the size is typically used on work/ utility trucks. They don't want a C-load tire for what they do.
    BC Hunter likes this.
  15. Feb 28, 2025 at 4:40 AM
    #315
    MEski4x4
    MEski4x4 New Member
    2024 TRD Pro
    What bumper is this? I love it!
  16. Feb 28, 2025 at 5:56 AM
    #316
    scottiezilla
    HeftyFab
    MEski4x4 likes this.
  17. Feb 28, 2025 at 7:09 AM
    #317
    Acesandeights
    Acesandeights #34
    2024 ORP
    The 255/80 was made for dually trucks, to have 3/4 and 1-ton capacity. Look at the rear tires of a F350 or F450 dually. That's the point of the 255/80, and that requires a stiffer, higher load carrying, sidewall.
  18. Mar 1, 2025 at 8:38 AM
    #318
    scottiezilla
    Swore there was a pic in the thread showing the clearance of the spare, I think someone with KDSS(which I have)…put mine back up finally n it is free/clear but close
    wondering if grinding down the back of hitch is a thing…might gain +- 1/4”
  19. Mar 1, 2025 at 2:19 PM
    #319
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    My 255/80 AT3W's on my Runner has officially come to an end. A screw went into an unpatchable area, and since they are no longer being produced I had to decide on tires on the spot. I only had 1 OG AT3W left, 2 were warrantied out due to tread chunking off and the 3rd was my fault slicing a side wall on a rock. My OG tire had 58k miles and was at 6/32's, honestly had plenty of life left. Ended up ordering the Toyo Open Country RT Trails. Was debating going with the 255/85 Baja Boss' but didn't want to deal with fitment issues since it is my winter DD. Maybe next time.
  20. Mar 1, 2025 at 2:48 PM
    #320
    Fishbum
    Fishbum New Member
    Did you go with the same size this time
  21. Mar 1, 2025 at 5:12 PM
    #321
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    I did. Love the 255's
  22. Mar 8, 2025 at 1:36 PM
    #322
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    255/80 Open Country RT Trails
  23. Mar 8, 2025 at 1:38 PM
    #323
    Fishbum
    Fishbum New Member
    Looks good I decided to change teams today lol pulled the trigger on 285 70s
  24. Mar 8, 2025 at 1:58 PM
    #324
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    The guy at discount was trying to talk me into 285's lol
  25. Mar 8, 2025 at 3:15 PM
    #325
    Fishbum
    Fishbum New Member
    I couldn't say no four brand new ko2s for 600 bucks
    HuskyMike and Stoney Ranger like this.
  26. Mar 8, 2025 at 3:30 PM
    #326
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    That is a killer deal
  27. Mar 8, 2025 at 3:33 PM
    #327
    Fishbum
    Fishbum New Member
  28. Mar 8, 2025 at 5:28 PM
    #328
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    You gonna get a spare?
  29. Mar 8, 2025 at 5:45 PM
    #329
    Fishbum
    Fishbum New Member
    Was thinking about just using a 255 75 for a spare.... Unless you have any thoughts
  30. Mar 8, 2025 at 7:20 PM
    #330
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    Are the new KO2's 255/75? If so, have at it. If the 75 ratio is a different number, your differential (and your wallet) will hate you.
