255/80r17 no rubbing no cutting
Discussion in '5th Gen 4Runners (2010-2024)' started by fecesinmyeyes, May 9, 2024.
  1. May 9, 2024 at 5:08 PM
    fecesinmyeyes
    fecesinmyeyes [OP] New Member
    2022 4Runner Trail Lunar Rock
    After a ton a waffling about size and reading other forum posts, I finally got a lift installed and new tires. I went with the at3ws in 255/80r17. The lift is Bilstein 6112s maxed out, 5100s in the rear with Bilstein 1.5 springs. There's absolutely no rubbing at all, and I think I could have gone with a 34" tire if it was skinny enough. Hope this helps anybody agonizing over tire size.
  2. May 9, 2024 at 5:24 PM
    Looks good! I really wanted to run this size tire, but I hate that they only come in load range. E. How's the drivability been with the heavier tire?
    kmeeg and fecesinmyeyes[OP] like this.
  3. May 9, 2024 at 5:30 PM
    fecesinmyeyes
    I had a small crisis when my installer said he had a hard time getting them on cuz they're so stiff, but they drive beautifully. They're quite and smooth, better than stock I think. Of course that could be the 6112s.
  4. May 9, 2024 at 5:44 PM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    Thanks for sharing been thinking of 255/80/17 s
  5. May 9, 2024 at 5:49 PM
    steelevo
    Utah
    Welcome. Looks great!
    djwantke and fecesinmyeyes[OP] like this.
  6. Jun 18, 2024 at 9:21 AM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    Thanks for sharing! I am now thinking Toyos. They seem to be lighter. What springs did you use in the front?
  7. Jun 18, 2024 at 9:54 AM
    fecesinmyeyes
    I used Bilsteins eq series standard springs. I forgot to mention I also had Bilstein b8 ucas installed. Steering is definitely a bit heavier with the at3ws, any weight savings you can get will help
    java[QUOTED] likes this.
  8. Jun 18, 2024 at 10:02 PM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    Thanks, also what psi are you running on road?
  9. Jun 19, 2024 at 6:01 AM
    fecesinmyeyes
    32-33 cold seems to be perfect. It's so hot here rn that they've gotten up to like 38, they start to get a little noisy at higher psi but nothing crazy.
  10. Jun 19, 2024 at 9:54 AM
    4Roamer
    4Roamer New Member
    2022 Army Green ORP
    C4 lo-pro front bumper, Bilstein 6112’s/5100’s
    I decided on 255/80/17 in the Falken Wildpeak AT4W after much research. To my surprise it just barely scrubbed my drivers side mudflap but only while turning and compressed. After an alignment there is no scrubbing at all. The ride is very good as well. I’m on Bilstein 6112’s in the front and 5100’s in the rear.
  11. Jun 19, 2024 at 9:58 AM
    fecesinmyeyes
    Do the trd wheels have more offset than the ORPs?
  12. Jun 19, 2024 at 9:59 AM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    Sweet I am going to order mine today and will be putting them on OEM steelies +19 offset. Hoping for minimal/no rubbing.
  13. Jun 19, 2024 at 10:00 AM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    Looks lime they are +4mm.
  14. Jun 19, 2024 at 7:04 PM
    TheColonelJLK
    TheColonelJLK New Member
    Mall crawling! I decided to go with Goodyear Duratracs 255/80r17. Zero rubbing and running a 6112/5160 lift (3in) with Dobinsons UCA.
  15. Jun 20, 2024 at 12:39 PM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    Finally got them! Can confirm no rubning but it is pretty close, will prob need to push the caster. Thanks to everyone on this thred, hepled greatly deciding.
    fecesinmyeyes[OP] likes this.
  16. Jul 6, 2024 at 12:11 PM
    fecesinmyeyes
    Looks great guys! I was just reading about tire pressure today and realized I had been running mine like 10 pounds low. With e load the sidewall is supposed to run with way higher pressure. Used an online calculator and it says to run 42 cold. I just filled up to 44 hot and the ride is a little stiffer but not in a bad way.
    java likes this.
  17. Jul 6, 2024 at 2:57 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
  18. Nov 21, 2024 at 10:43 AM
    LittleHunter
    LittleHunter New Member
    Thomas
    2022 ORP 4Runner
    Pending
    Hey guys! I'm thinking about getting the 255/80/17 and wanted to check in on y'all and see how ride quality still is? Have any regrets?
  19. Nov 21, 2024 at 10:51 AM
    Ride quality is fine with my Duratrac RT in load range E due to the taller sidewall.
    LittleHunter[QUOTED] likes this.
  20. Nov 21, 2024 at 10:52 AM
    LittleHunter
    Thomas
    2022 ORP 4Runner
    Pending
    That is good to hear. I was actually just looking today at the Duratrac RT. What psi do you keep them at?
  21. Nov 21, 2024 at 10:54 AM
    I realize this post is 4 months old, but the online calculator is ass-backwards. Why would a heavier load range tire with more sidewall plies need more pressure to achieve the same load capacity as a P-metric tire? That's against common sense.
    LittleHunter likes this.
  22. Nov 21, 2024 at 10:54 AM
    32 front, 30 rear.
  23. Nov 21, 2024 at 11:17 AM
    IMO or by previous experience;
    - it wasn't a good choice not experiencing ride quality first had (like on a friends vehicle or some sort).
    - it would be a bad choice to to ignore to take action if you don't like something and let the brain overcome the happy feeling of having a new thing.
    I wasted time and money buying Load E tires. After some miles I sold them on facebook market place and got Load C tires. Now with my light duty use I'm surviving with standard load tires.
  24. Nov 21, 2024 at 12:21 PM
    Court
    Court New Member
    Court
    2023 4Runner Lunar Rock ORP
    I just installed some 255/80R17 Nitto Ridge Grapplers last week and did a wheeling weekend with OEX in Uwharrie Forest. Keep them at stock tire pressure, 32psi. E load does have a slightly firmer ride, but nothing I regret. There were a couple staff/volunteers at OEX that run 4Runners, and they all highly recommended the 255/80R17 size. I was very happy with them, no rubbing or trimming needed at all under full flex. The spare barely fits, only about .25-.5" clearance to the KDSS bar, but it fits.
  25. Nov 21, 2024 at 12:44 PM
    AA-Ron76
    AA-Ron76 New Member
    I really like mine, absolutely zero difference in ride quality from the previous C load tire, BFG K0 2 285/70/17 to my current Falken Wildpeak AT4W's 255/80/17 in E load.
  26. Nov 21, 2024 at 12:48 PM
    bigshmoop
    bigshmoop New Member
    Joe
    Schaumburg, IL
    '23 Lime Rush ORP
    LT255/80R17 ATW3's, Westcott Designs DOM/TIG sliders, low profile roof rack, ladder, preload collar lift, Baja Designs 40" S8 lightbar
    I have over 40,000 miles on my 255/80 Falken ATW3's while running them at 40-42psi cold with no issue. Is the ride firm? I guess, but not uncomfortably so. I get decent milage ~17mpg (lifted and often loaded up) I actually prefer the firmer ride and feedback versus the pillows that came from the factory. I feel like this falls under many things on the internet that gets blown out of proportion. Years ago I spoke with tire design engineers from several big brands (Good Year, Michelin, Firestone) and all of them said that E load tires are designed and built with higher pressures in mind. When I go off road I drop them down to 15psi and they conform and grip anything in front of me.
    My suggestion is try several different pressures and see what you think.
  27. Jan 13, 2025 at 2:27 PM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    Any recs for chains that fit 255/80/17?
