255/75/17 w/spidertrax
Discussion in 'Wheels & Tires' started by 4RWVOH, Apr 21, 2024.
  1. Apr 21, 2024 at 4:47 PM
    4RWVOH
    4RWVOH [OP] New Member
    It's time to correct the mistakes of the previous owner of my truck.
    The Helo wheels and Chinese tire setup is vibrating me to pulling my hair out.
    I'm installing my Eibach lift in the next few days and bought OEM TRD Off-road wheels (which I think looks great) for my classic silver rig. Haven't landed on the brand yet but I want to run 255/75/17 but also want a poke of 1.25" spidertrax spacers. I've lived my adult life condemning spacers and believed negative offset after market wheels were the only logical choice. However, after extensive research I've concluded they are a viable option if done correctly.
    If anyone knows what trimming is needed with this tire setup and spacer I'd appreciate your experience and pictures.
    Thanks.
  2. Feb 3, 2025 at 2:31 PM
    mostfrantic
    mostfrantic New Member
    late bump to help the search function.
    Not much trimming is needed, if any. Maybe a small front fender trim.
  3. Feb 3, 2025 at 3:18 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    For skinny 32s very minimal trimming will need to be done, even with the spacers.
    If you step up to 255/80/17 (33" tall) the spacers will mean you may need to push the front fender liners forward, trim the bumper, and potentially remove the front mud flaps (or use a heat gun to mold them back)
    For the record I'd recommend the skinny 33s even with the trimming required. Simply because you'll have a decent increase in sidewall height over the stock size.
    Regardless of my opinion there are a ton of threads on this tire size. Use google to locate them as it works much better than this sites search function.
    Site:4Runners.com/ 255/75
    mostfrantic likes this.
