245/75R17?
Discussion in 'Wheels & Tires' started by RepentOrPerish, Nov 28, 2024.
  1. Nov 28, 2024 at 8:51 AM
    RepentOrPerish
    RepentOrPerish [OP] New Member
    4thGenv8
    Looking at a set of toyo open country in this size.. is there any major reason why i shouldnt go with 245 width? Anyone else run this size?
    Thanks
  2. Nov 28, 2024 at 9:55 AM
    1) Too small than what comes with the 4Runner.
    Factory 31.6" vs 31.5" generally with 245/75R17 tire
    2) All Toyo tires in that size seem to in Load E which the ride could be hash.
    3) To my personal taste tires that are skinnier than factory width of 265mm is ugly or looks not matching to wider look of the 4runner. (Just my personal opinion.)
    Here's an example of a 255mm tire that looks not matching to a 4runner imo. So I think 245 would be worse. (Not my pic)
    But per experts skinnier tires are far more better functioning than wider tires in many ways.
  3. Nov 28, 2024 at 10:04 AM
    RepentOrPerish
    4thGenv8
    My factory size is 265 65 17 so the 245 75 have taller sidewalls. The toyo i am looking at isnt E rated.
    Thanks for posting the pic
  4. Nov 28, 2024 at 10:15 AM
    Oh shoot, very sorry. I missed that yours is 4th gen.
  5. Nov 28, 2024 at 10:32 AM
    java
    java fauxrunner
    2023 ORP ice cap
    I love my 255/80/17's
  6. Nov 28, 2024 at 11:24 AM
    RepentOrPerish
    4thGenv8
    Did you have to do some trimming to make those fit?
  7. Nov 28, 2024 at 2:53 PM
    java
    java fauxrunner
    2023 ORP ice cap
    Nope they fit right in. Slight rubbing on the mudflap at full lock, but that is minimal, I'll have the caster? pushed forward when I install a front leveling lift. The viper cut is just because lol.
  8. Nov 29, 2024 at 4:52 AM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    Well......I like my 235'sx80x17.
    icebear, java and RepentOrPerish[OP] like this.
  9. Nov 29, 2024 at 8:24 AM
    RepentOrPerish
    4thGenv8
  10. Nov 29, 2024 at 10:48 AM
    Lost Woods
    Lost Woods New Member
    .1" is so insignificant here that absolutely nobody would be able to tell the difference. You'll get greater variance correcting for air pressure from the manufacturer's measurement method.
    The second number is aspect ratio in that it is the sidewall height as a percentage of tread width. So a 245/75R17 means it has a 245mm wide tread and a 245*.75 or about 183mm sidewall. A 265/70R17 is 265mm wide with a 185mm sidewall.
    If you don't mind the narrower width, they're fine. That is the size that comes on most Wranglers and Gladiators so it's easy to find take-offs for cheap.
  11. Nov 29, 2024 at 2:29 PM
    jeepster09
    Twin Cities MN
    4Runner 2008 Sport
    Factory 17x7. 5 wheels on a 4Runner should have an offset somewhere between 13-17mm, most likely 15mm.
  12. Nov 29, 2024 at 7:07 PM
    java
    java fauxrunner
    2023 ORP ice cap
    Wow they look great, man!
