2025 Trailhunter & Car Wash
Discussion in '6th Gen 4Runners (2025+)' started by AbbyNormal, Jul 19, 2025.
  1. Jul 22, 2025 at 4:58 PM
    AA-Ron76
    AA-Ron76 New Member
    At most attended automatic/belt driven car washes you can opt for no brushes, at least in the Phoenix area that seems to be the case.
  2. Jul 22, 2025 at 6:19 PM
    AbbyNormal
    AbbyNormal [OP] New Member
    Thank you for the info. Much appreciated. The car wash I have been using on my 20 y.o. Sienna has never caused any problems. It has cloth scrubbers as well. If I’ve been to the mountains in winter the underbody wash is a must. It needs to be washed right now. Dark paint…. I have soft cloth dusters but they don’t get the dirt off.
  3. Jul 22, 2025 at 6:22 PM
    AbbyNormal
    Thank you. I didn’t know that. I will check that out.
  4. Jul 22, 2025 at 6:41 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    @2ndGen22re @Nick B
    My door jams: :laugh:
    I commend you gentlemen, I have many things to learn, never waxed or polished or ever used “two buckets” haha
    2Toys, bancroftdg, 2ndGen22re and 2 others like this.
  5. Jul 22, 2025 at 6:44 PM
    @AbbyNormal you might be the nicest member with the most normal thread !
  6. Jul 23, 2025 at 6:48 AM
    We visit Ft Myers from October to January. I wanted to change the oil and didnt calculate the time of day and associated heat, long story short. I thought i was going to die
    bancroftdg and AbbyNormal[OP] like this.
  7. Jul 23, 2025 at 7:37 AM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    Come down here now and you probably will. The heat and humidity is miserable.
  8. Jul 23, 2025 at 8:02 AM
    AbbyNormal
    Too funny! Though there are lots of nice folks here with very knowledgeable and useful info.
    bancroftdg and djwantke[QUOTED] like this.
  9. Jul 23, 2025 at 8:04 AM
    AbbyNormal
    Hilarious. Much like St George in July. Plan carefully if you want to see another day.
  10. Jul 23, 2025 at 8:23 AM
    I was just having this conversation with my buddy who just bought a Disney timeshare and asked him when he plans on going down to orlando. He said August, and i asked why would you pick august? Just why?
  11. Jul 23, 2025 at 8:25 AM
    shooter1231
    shooter1231 New Member
    2023 Mag Gray 4Runner Limited
    Yep - my 4Runner is Magnetic Gray Metallic (dark gray) so it shows dirt and looks pretty dirty after driving it in the rain. Your point about the underbody wash is very good also. I live in central Missouri. We don't get super harsh winters - but we get plenty of snow storms between mid Dec. - mid March and the roads are heavily coated with salt during that time. I think the underbody wash at the carwash I go to helps keep the salt from building up on the underbody. Throughout winter, as long as the temperature is above freezing, I regularly run it through the carwash. I think one thing to point out is that what makes sense from a car washing perspective depends a lot on where you live. Do you live far enough south that you get no snow/ice and the roads are not treated with salt/chemicals? Do you live someplace like SoCal/Az where you hardly ever get any rain? Or do you live in the Midwest/East Coast where the winters are fairly harsh and you get frequent rain. There are places where you can wash/wax your vehicle and it may look great for weeks. Where I live, you wash it and get it looking good, and you are lucky if that lasts a week.
  12. Jul 23, 2025 at 10:48 AM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    Just don’t ask about oil change intervals or Raptor lights . ;)
  13. Jul 24, 2025 at 5:57 AM
    Beachguy
    2024 TRP ORP
    IMG_6526.jpgYesterday evening. Guess what I ain’t doing after work. I got a car wash membership years ago and never looked back. I also learned that I can’t do everything at once. I have neither the time nor the energy. So after I dry it off, I might wax the front clip and doors. Next week the back doors. Next the back panels and rear lift. The roof. Then maybe I’ll do a deep clean on the wheels and tires. It breaks it up for me and creates a rhythmic system that I can handle. Not to say I wouldn’t have a detailed do it maybe once a year. But it’s not much cooler in the mornings and I have other commitments on weekend mornings. YMMV
    AbbyNormal[OP] likes this.
  14. Jul 24, 2025 at 1:26 PM
    RobCM
    RobCM New Member
    Rob
    Florida
    2025 4Runner TRD Sport
    I also have a 2025 4Runner in Underground. Took it through an automatic carwash the first month I had it and it created a bunch of swirls so I ended up having to take it to a detailer to buff the swirls out which cost me like $600. Long story short my 4Runner will never go through another automatic car wash. I hand wash most of the time now or occasionally will take it to a touchless carwash.
  15. Jul 24, 2025 at 2:48 PM
    Even though I’ve gotten a ton of pinstripes from branches, I still refuse any carwash with brushes lol.
    I’m pretty lucky in Wisconsin, we have s gas station chain that has well maintained automatic car wash bays that do brushed or brushless option. The brushless is consistently good at cleaning everything. It’s not perfect because it doesn’t get the very fine/thin grime off the paint, but honestly you would need to hand wash to get that off anyway.
    I’d be a little worried about that snorkel with the overhead jets of the air blaster dryer.
    AbbyNormal[OP] and bancroftdg like this.
