2024 SR5 Roof bag question
Discussion in '5th Gen 4Runners (2010-2024)' started by craftech, Jul 23, 2024.
  1. Jul 23, 2024 at 7:02 AM
    craftech
    craftech [OP] New Member
    Hi,
    New 2024 4 Runner SR5. I was wondering about roof bags. For a short trip in which the bag will be removed when I get there:
    1. If the weight is reasonable can the roof bag simply be rested on the roof and lashed to the two rails on the roof?
    2. If the answer is yes, do you have any recommendations for such a bag?
    Thanks,
  2. Jul 23, 2024 at 7:36 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    It can rest on the roof, I have always tried to not do that, but for a little weight it’s ok.
    I have a Sherpa bag and one I got at Wally World.
  3. Jul 23, 2024 at 10:23 AM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    how much do you like the paint on your roof?
    Captain Spalding likes this.
  4. Jul 23, 2024 at 10:50 AM
    craftech
    Are you saying a bag scratches it? When I looked on Amazon, a lot of them come with roof pads.
    Thanks,
  5. Jul 23, 2024 at 11:14 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    I run a roof bag on occasion. I forget the brand but it was a name brand waterproof model. Whatever you choose pack your contents In contractor bags. They all leak.
    Will you be using the oem rack or do you have a basket you plan on using? That might make the difference in what you choose with regards to strap layout, size, shape.
  6. Jul 23, 2024 at 11:16 AM
    Lost Woods
    Lost Woods New Member
    It'll definitely give it small scratches and wear spots over time as dirt and whatever works its way underneath. It all depends now much you want to use it
    ATX14 likes this.
  7. Jul 23, 2024 at 12:11 PM
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
    Yeah. It will scratch and rub. There is a lot more vibrating and movement than you think going on up there.
  8. Jul 23, 2024 at 12:56 PM
    craftech
    The OEM rack (two rails that come with it).
  9. Jul 23, 2024 at 1:09 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Yes, you can lay a pad under the cargo bag to help prevent scratching the paint on your roof, but you really have to limit the weight. I don’t have any recommendations on a cargo bag.
    I used to use a roof bag, until I got a rear hitch cargo carrier which makes life so much easier…
    Getting stuff down from the roof can be dangerous when you’re old like me.
    Plus, you get up to 500 lbs
    https://www.amazon.com/gp/aw/d/B086...&pd_rd_r=f80803ed-88ae-4ea2-a802-602f5dc99cff
  10. Jul 23, 2024 at 1:21 PM
    BLKNBLU
    BLKNBLU New Member
    Did you have any sort of cross bar?
    We cut our own Xmas tree and I made the mistake of thinking I could just cinch it down real tight but it wanted to slide around fore and aft pretty badly. I had to quick jerry rig something with wire and scrap wood. Worked but was not pretty. I got some cross rails after that mis-adventure...
  11. Jul 23, 2024 at 1:29 PM
    Dabigono
    2020 4Runner
    Yes, I replaced the 2 factory crossbars with 4 LFD crossbars.
    Now I have no crossbars because I don’t like carrying anything on the room anymore.
  12. Jul 23, 2024 at 1:50 PM
    BLKNBLU
    BLKNBLU New Member
    Yeah I liked their bars but ended up with some from Victory 4X4 which are also very nice. I had no factory bars.
    I like the hitch carrier too. I had forgotten about those.
  13. Jul 23, 2024 at 1:53 PM
    craftech
  14. Jul 23, 2024 at 2:00 PM
    BLKNBLU
    BLKNBLU New Member
  15. Jul 23, 2024 at 2:12 PM
    Dabigono
    2020 4Runner
  16. Aug 8, 2024 at 1:26 PM
    craftech
    Took the crossbars off. Too late to return them. There is no roof bag that fits in between the crossbars even when they are spread out as far as you can spread them out. "Small" Bag i bought will go right on the provided roof protector non skid sheet that came with it.
  17. Aug 14, 2024 at 6:05 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    The bag should have fit on the rails. The issue then becomes the bag sagging and touching the roof any ways. I would use some camp chairs in the bag to try to avoid this.
    good luck.
  18. Aug 14, 2024 at 6:22 PM
    Beachguy
    2024 TRP ORP
