2024 Off-road suspension questions
Discussion in '5th Gen 4Runners (2010-2024)' started by TejasRunner, Jul 9, 2024.
  1. Jul 9, 2024 at 7:01 PM
    TejasRunner
    TejasRunner [OP] New Member
    2024 4Runner Off-road Premium
    I have a deposit down on a new 2024 Off-road Premium. I currently have a 2016 Trail Premium.
    Does the 2024 OR nosedive on hard braking?
    To counter this issue on the 2016, I installed Toytec Boss shocks and they’ve been fine. They are almost seven years old. Still drives and rides great.
    Assuming the 2024 shocks are soft like the 2016, any recommendations on replacements. I’d like to do a small front lift to level. One of the local shops recommended front and rear replacements for a better overall feel. I am getting quotes right now.
  2. Jul 9, 2024 at 7:03 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    I have found the KDSS does a good job on mitigating body roll, nose dive. I wouldn't change it.
  3. Jul 9, 2024 at 7:03 PM
    Its the same
  4. Jul 9, 2024 at 7:30 PM
    TejasRunner
    Neither of my 4Runners have KDSS. I should have mentioned that. Sorry.
    NV4Runner likes this.
  5. Jul 10, 2024 at 4:57 AM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    The most cost effective way to deal with the nosedive is to replace the shocks. I have a 2021 OR and replaced the OEM shocks with Bilstein 5100’s with the front adjustable shocks set to the .85 lift setting. This firmed up the nosedive and leveled the front.
    Cheer’s
    Bob
  6. Jul 10, 2024 at 5:24 AM
    Shanky
    Shanky New Member
    What do I have to do to get the nose dive? I’m stock, and it has not happened.
    Shredder likes this.
  7. Jul 10, 2024 at 5:31 AM
    2016 & 2024 are the same vehicle. It should handle exactly how your 2016 did.
    icebear and TejasRunner[OP] like this.
  8. Jul 10, 2024 at 5:33 AM
    I dunno. I have 176k on the original 2013 suspension and I'm not bothered by any nosedive. Could be because I don't expect sporty handling from a heavy SUV.
  9. Jul 10, 2024 at 5:55 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I can't stand the stock suspension on these things. Too soft allowing for a lot of body roll and nose dive under braking.
    OP I'd just throw on some bilstein 5100's if you're looking for a budget friendly solution.
    This should fix the brake dive issue and also allow some height adjustability.
  10. Jul 10, 2024 at 6:12 AM
    I did the same, but used Eibach shocks, same setting. Very happy with the results. A little over 4 years with this setup.
    nimby, LCJ77 and TejasRunner[OP] like this.
  11. Jul 10, 2024 at 6:18 AM
    TejasRunner
    Which 4Runner trim do you have?
  12. Jul 10, 2024 at 6:19 AM
    TejasRunner
    Thank you. I’ll be doing something similar.
  13. Jul 10, 2024 at 6:24 AM
    Shanky
    Shanky New Member
    TRD Offoad
  14. Jul 10, 2024 at 6:50 AM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    drive like an asshat? or maybe just be oversensitive and expect it to drive like a sports car?
    Trail Runnah likes this.
  15. Jul 10, 2024 at 6:50 AM
    Startrek
    Startrek New Member
    You have to press hard on acceleration pedal between traffic lights and hit brakes in emergency-like manner. AND you have to have more sugar in your daily consumption so you will be irritated easily by the smallest things. Sugar is your answer.
    Shredder, BC Hunter and Trail Runnah like this.
  16. Jul 10, 2024 at 7:43 AM
    Shanky
    Shanky New Member
    That’s hard to do while keeping the green Eco light lit all the time…….
    Actually we have technology to avoid nose dives, roll overs etc. For street use only. We have a bobblehead Pug from MIB that has sat on our dashboards since the kids got it in a happy meal in the 1990’s. If he slides, it means mellow out. If he tips over, switch drivers. If he flys off the dash entirely, check for injury’s and call your insurance co. A nose dive would definitely be a “violation”.
    This process got us through three teenage drivers back in the day.
    Spare Parts and Acesandeights like this.
  17. Jul 10, 2024 at 8:35 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I used to have it, but it went away. I guess the 4R trained me to brake even more gradually than I did already. Besides, I'm not in a hurry to need new pads and rotors.
    Trail Runnah and LCJ77 like this.
  18. Jul 10, 2024 at 10:13 AM
    1SilverRunner
    Tejas
    Reminds me of initial D.
    The cup of water was used to show the weight transfer of the car. The goal was always to keep the water in the cup, even during the most aggressive driving.
  19. Jul 10, 2024 at 10:43 AM
    TejasRunner
    Try driving around the Fort Worth area. Then you’ll get it back.
    Justkelvin likes this.
  20. Jul 10, 2024 at 11:01 AM
    TejasRunner
    Oscar is sending me a couple of quotes for full suspension.
  21. Jul 10, 2024 at 11:05 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Oscar is the man. Can't say enough good things about them. Consider Dobinson IMS for a mid priced suspension that's a lot of bang for the buck.
    TejasRunner[OP] likes this.
  22. Jul 10, 2024 at 11:11 AM
    1SilverRunner
    Tejas
    Tread Depot is only shop in DFW I trust.
    Oscar, Chayton and Pat are the people to see. They installed my long travel IMS suspension.
  23. Jul 10, 2024 at 11:33 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Mine has KDSS but still nosedives more than I would like. I will be upgrading the suspension in the near future.
  24. Jul 10, 2024 at 11:36 AM
    I am able to anticipate my stops 99.9% of the time so nosedive is not a concern for me.
    I like the softness of the stock suspension, but I was raised in the 60/70’s when ride comfort was a thing.
    5thToy likes this.
  25. Jul 10, 2024 at 11:40 AM
    R1200Jedi
    R1200Jedi New Member
    2022 4Runner ORP
    Drive a Tacoma. Then, when you get back in your 4Runner you’ll think you’re faceplanting from the nose dive. :rofl:
    At least that was my experience. The first time I hopped in my 2022 4Runner after coming from two Tacos in a row, I was shocked by the nose dive. Then after that first drive I promptly forgot about it and have never noticed it since. (Although in fairness, I went with such heavy springs on my OME lift I don’t think you could push the nose of this thing down with an M1 Abrams sitting on it….)
    CalcityRenegade likes this.
  26. Jul 10, 2024 at 11:45 AM
    Garlic
    Garlic New Member
    CO
    2024 TRD Off Road
    I’m with you, I’d like a softer suspension if anything.
  27. Jul 10, 2024 at 11:46 AM
    If you want to save some money, just put Eibach or Bilstein front shocks on (with your stock coils). Lift if you want (or don't). The rear shocks and coils can remain stock.
    Eibachs ride better than Bilsteins IMO.
    5thToy likes this.
  28. Jul 10, 2024 at 11:56 AM
    TejasRunner
    That will be one of the quotes. Apache will be the other. They did the brakes on my 2016 this past winter.
  29. Jul 10, 2024 at 11:57 AM
    2021venture
    Todd
    2021 Venture
    I have the Apache UCA and they are beefy.
  30. Jul 10, 2024 at 11:59 AM
    BobbyB
    Bob
    Marietta, GA
    hossler1788 and nimby like this.
