2024 Land Cruiser reveal
Discussion in '5th Gen 4Runners (2010-2024)' started by rmiked, Aug 3, 2023.
  1. Aug 6, 2023 at 10:32 AM
    YetiMtnBkr
    YetiMtnBkr New Member
    Frederick, MD
    2021 LR Pro
    None
    Well said! I bought the 4R for what it can do! Reality is that I do THAT less than 1% of the time!
  2. Aug 9, 2023 at 12:50 PM
    Startrek
    Startrek New Member
    Well said! I bought the 4R for what it can do! Not actually any time of my life I am gonna do it intentionally.
    YetiMtnBkr likes this.
  3. Aug 9, 2023 at 1:38 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Totally agree with ya'll. Every manufacturer is in a race to the top of oversize mountain. From body, to massive wrap around headlights with extra led junk, huge ugly taillights, and of course 500pt font size tailgate logos.
    I want to experience the new low end torque and horsepower, minus the owning part. I'm worried about what direction Toyota design takes the 6th Gen, disagree with me - tell me you love these:
  4. Aug 9, 2023 at 1:42 PM
    Buddy's right, LC kinda does look a little Bronco-ey
  5. Aug 9, 2023 at 3:05 PM
    Vito Corleone
    Vito Corleone New Member
    Georgia
    2022 4Runner ORP
    Current Mods: 3/2 Lift Kit w/Billstein 5100’s SPC Front Upper Control Arms 285/70/17 Michelin Defender LTX TRD Pro Wheels TRD Pro Grill 20% Tint on Windows & Sunroof Pedal Commander Cold Air Kit LED Front Turn Signals Brite-Box Anytime Foglight Kit “Tail as Turn” Rear Turn Signal Kit LED Reverse Lights LED Tag Lights LED Puddle Light Pods Sequential Turn Signals N-Fab 3” Step Bars Future Mods: In-Car Camera System Rear Molle Panel Storage System Magnuson Supercharger (when available)
  6. Aug 9, 2023 at 3:39 PM
    HotelMedicis
    HotelMedicis No Commercial Interests
    Toyota says the LC250 will only have 8.3 inches of ground clearance. It's in the reveal video. Here's a screenshot. For those looking for more ground clearance, a Subaru Outback has 8.7 inches.
  7. Aug 9, 2023 at 5:35 PM
    rmiked
    rmiked [OP] New Member
    Fort Mill, SC
    I don’t understand why Toyota would put out a legendary named vehicle with lame ground clearance? Makes you think the design team doesn’t expect anyone to go off road? Or the design team doesn’t value ground clearance? Both are hard to believe.
  8. Aug 9, 2023 at 6:05 PM
    I'm curious as to how they measure it. I'm wondering if they measure it from the rear pumpkin, and this has a beefy rear differential. Perhaps that would account for the low sounding ground clearance.
    wsu_runner, Thatbassguy and 3JOH22A like this.
  9. Aug 9, 2023 at 6:18 PM
    The 2024 Tacoma has a 9.5" rear diff to handle the hybrid torque. If the LC uses the same rear diff, it'll be a big increase over the 8" on current models and may reduce the ground clearance. But that's ok since you can smash the rear diff on rocks with no issue - the diff housing is a jacking point and can easily support the truck's weight.
  10. Aug 9, 2023 at 7:31 PM
    What gives me some hope is that the Tacoma doesn’t have a grill the size of a continent, and it overall looks pretty good.
    In fact, since both the tacoma and LC have non-absurd grills, it may finally mean that decades long trend is over!
    Also, the tacoma’s tailgate doesn’t have another tailgate for its tailgate. So that’s good lol
  11. Aug 9, 2023 at 8:30 PM
    wsu_runner
    wsu_runner Just lurking...
    I had a '94 pickup with an open diff. I think the ground clearance was under 9" back then (can't remember, and couldn't find a good source from Google). I went anywhere I wanted to go. Two thirds of an inch less shouldn't be a deal-breaker, it's as much about the driver and technique as it is about ground clearance.
    DirtyHairy, Trail Runnah and djwantke like this.
  12. Aug 9, 2023 at 8:37 PM
    wsu_runner likes this.
