2024 4runner
Discussion in '5th Gen Builds (2010-2024)' started by snd050, Jan 10, 2025.
  1. Jan 10, 2025 at 4:18 PM
    snd050
    snd050 [OP] New Member
    Spencer
    2024 4runner
    Dobinsons 3 way lift
    was shopping around for tires and wheels, thinking of a 285/75/17 with a -12 method 701 wheel.
    just wanted to see if it was possible to fit these wheels and tires. totally fine with body mount chop and trimming in the plastic if need to, just didn't want to run into bigger problems such as rubbing against sway bar and UCA's
  2. Jan 20, 2025 at 6:07 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Sorry no one ever helped you out with this post.
    An aggressive body mount chop (or body mount relocation), folding pinch welds and and trimming the bumper/ fender liner should get you there.
    Winwin end caps help keep a clean look if needed. This was enough for me even with -38 offset and 34's. Should be more than enough for the setup you're looking into.
    Wheel specs were 17x8.5 -12 with 1.25" spacers
    Offset equivalent to the more common 17x9 -38
    This would be more than enough for the setup your looking into. But my journey continued.
    Once I removed my front sway bar I needed even more room to allow the front wheels to articulate. The extra articulation and offset was chewing up fenders when flexed out with the wheels turned. I could reattach my sway bar or just remove the wheel spacers... But I liked the extra flex and the wide stance seemed to help with stability in off camber situations.
    Here's some photos of the carnage.
    So back to cutting; Instead of removing the spacers or reattaching my sway bar I upgraded my front bump stops and installed high clearance fender liners from C4. This gave me plenty of clearance and allows me the space for 35's in the future.
    It also mitigates some of my concerns with ingesting water after I did a viper cut and extensive fender liner trimming. This is a concern I have with all viper cuts since the air intake is under the passenger side fender directly above the fender liner.
    This is how it sits now with lots of offset and 34s. Ready for 35's!
    This should give you an idea of what it takes to run 35's with pretty aggressive offset.
    This link will provide some more simple mods to start with. Should get you running 33's or maybe 34's without issue.
    https://trail4runner.com/2019/07/14/fender-liner-push-back-trimming-on-4runner/
