2023 4Runner Limited
Discussion in '5th Gen 4Runners (2010-2024)' started by Pinechunk, Apr 19, 2024.
  1. Apr 19, 2024 at 6:44 AM
    Pinechunk
    Pinechunk [OP] New Member
    Recently bought a 5 month old 4Runner. On multiple occasions it has started by itself, once while I was near it and several times I've walked outside and it was running. At first I thought with the key fob in my pocket maybe one of the buttons got pushed. The last time it happened the fob was laying on my kitchen counter. What is causing this and how can I disable it?
  2. Apr 19, 2024 at 6:46 AM
    jgalt
    jgalt New Member
    Remote start app?
  3. Apr 19, 2024 at 6:48 AM
    Daddykool
    Remove the batteries from all your fobs and see if the symptom changes. I'm assuming remote start is factory installed and not dealer installed or aftermarket. The truck may still be under warranty, too.
  4. Apr 19, 2024 at 7:05 AM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Previous owner messing with you and starting it from the Toyota app?
    kouack, Sin4R, Grandpawmoses and 2 others like this.
  5. Apr 19, 2024 at 7:08 AM
    Pinechunk
    It's a Limited so it is a factory install. I typically don't use autostart so if I could figure out how to disable I would.
  6. Apr 19, 2024 at 7:14 AM
    Daddykool
    Maybe the dealership can disable? Either way, is it still under warranty?
  7. Apr 19, 2024 at 7:14 AM
    Pinechunk
    Yes it is under warranty
    Daddykool likes this.
  8. Apr 19, 2024 at 8:04 AM
    steelevo
    Utah
    Go onto the Toyota app and make sure that you’ve registered the 4Runner under your login. It will have you enter a code into the nav screen. Someone may have registered the car and keeps starting it via the app.
  9. Apr 19, 2024 at 8:08 AM
    2019 TRDP w/Kangs brah!
    Is the engine actually running or are you hearing the EVAP test that is mentioned in the manual and starts a few hours after you shut the engine off?
    Grandpawmoses and Acesandeights like this.
  10. May 14, 2024 at 7:00 AM
    Pinechunk
    It is actually running
  11. May 14, 2024 at 7:13 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    5 months old? Call your dealer. This is an obvious warranty issue!!!!!
  12. May 14, 2024 at 7:14 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    This happened to me while camping this weekend. Wife climb down from the tent, then starts telling me something is on, not happy to have to go figure it out at 5 in the morning.
  13. May 15, 2024 at 5:49 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    When the initial free time expires of remote access that came with it new, it will quit doing that.
  14. May 15, 2024 at 6:00 AM
    Sin4R
    Distant land called Timbuktu
    2024 4Runner Limited
    Mall crawling kit.
    Someone activating remote start via DCM system. You need to disable that, or at the very least revoke previous owner's access to it.
    To do that, you need to contact Toyota Connected Services. While you are doing that, strongly recommend opting out of data collection "services". There are stories of GM/OnStar driving data ending up getting sold to insurance companies resulting in increased premiums.
  15. May 15, 2024 at 6:06 AM
    jgalt
    jgalt New Member
    ^ You're overreacting per the milgram fans lol! They will tell you that there is nothing to worry about w/ DCM, and that you are secure enough! However, you are correct!
