2023 4runner front valance
Discussion in '5th Gen 4Runners (2010-2024)' started by Pathpounder, Apr 26, 2023.
  1. Apr 26, 2023 at 1:13 PM
    Pathpounder
    Pathpounder [OP] New Member
    Just purchased the blackout valances for my 4runner. From researching I see the front cap needs to be removed as they have apparently added some backing of some sort behind the bumper and the radar detect needs to be uncoupled as well as the fog lights. Anyone done the 2023 yet and seen any other unforseen issues? I was going to just paint them but I just can't think it would last. Yes I've searched the forum but most are attaching by just removing the valance alone on previous years. Sorry if I'm yanking anyone's chain but updates create new challenges sometimes.
  2. Apr 26, 2023 at 1:57 PM
    EC15
    EC15 New Member
    It's the same as previous years and yes, it can be done without removing the bumper.
  3. Apr 26, 2023 at 2:02 PM
    Pathpounder
    Thanks. Much appreciated.
  4. Apr 26, 2023 at 2:21 PM
    josephp732
    josephp732 New Member
    2019 Silver Limited, 2021 White TRD OR Premium
  5. Apr 26, 2023 at 5:18 PM
    Pathpounder
    Thanks for the video. Looks like that will do it.
    josephp732 likes this.
  6. Apr 26, 2023 at 5:30 PM
    wax poetic
    wax poetic New Member
    Arizona Desert
    21 Super White TRD OR
    If you have the TRD skidplate you'll have to remove that ... I was like why the fuck can't I do this haha. Now I can remove the valence in about 15-20 including removing the skidplate. The first time is a bit tricky finding a few of the clips.
    Pathpounder[OP] likes this.
  7. Apr 26, 2023 at 6:36 PM
    2016 4Runner Trail
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 4.5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -K&N Engine Air Filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Wheel well hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch *new April 29 RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit **new May 5 PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity Bought, in the garage queue, April/May 2023: -1" EZ Flares - only one side installed lol -Apex Overland 4runner KDSS recovery points -first needed SPC ball joint replacement kit Wanted - bolt on cat shields, Sumo Springs,
    It's faster to just remove your front bumper it's actually not scary or hard believe me I thought it would be
  8. Apr 26, 2023 at 6:37 PM
    2016 4Runner Trail
    What kinda hands ya'll got to do that with bumper on lol
  9. Apr 26, 2023 at 6:39 PM
    2016 4Runner Trail
    No one ever seems to mention you gotta get 13 clips back in after. When bumpers off clips out or in in 60 sec
  10. Apr 27, 2023 at 5:35 AM
    Pavo
    Pavo New Member
    I have a 2022, the clips were extremely stiff to do so I ended up partially removing the front bumper, that helped a ton. Watch the video by trd John on how to remove front bumper it’s the most helpful. The only added step you will have to do is remove the 10mm for the bracket holding the front radar (you will see what I mean)
  11. Apr 27, 2023 at 6:19 AM
    Pathpounder
    Thanks. I will look that one up.
  12. Apr 28, 2023 at 7:22 AM
    STrooper
    STrooper New Member
    Jack
    4runner
  13. Apr 28, 2023 at 7:23 AM
    josephp732
    No - I had to remove the rear bumper cover.
  14. Apr 28, 2023 at 8:05 AM
    Connor MacLeod
    Connor MacLeod New Member
    Connor
    2023 TRD Off Road
    I did the replacement on my '23 OR without removing the bumper. It was probably 30 degrees in the garage when I did mine, and it was hell on my fingers getting the clips out, so I'd recommend doing it when the temperature is warm and the clips and other plastic parts seem to flex a little better for removal.
  15. Apr 28, 2023 at 1:34 PM
    Pathpounder
    A nice 60 degree day so I went for it. Had 1 clip that gave me some trouble but otherwise install went smooth. Rain in the forecast so I'll wait for another day for the rear. Thanks for all the advice.
  16. Apr 28, 2023 at 11:14 PM
    SanJuan
    SanJuan New Member
    did you purchase from 4runner Lifestyle?
  17. Apr 29, 2023 at 4:00 AM
    Pathpounder
    Yes I did. Very quick shipping.
    SanJuan likes this.
  18. May 25, 2023 at 7:11 AM
    Shilo5000
    Shilo5000 New Member
    Lucas
    OC
    ‘22 TRD PRO
    Anyone find a way to get new clips? 4Runner lifestyle is only the valance. Mine came loose and when I got it all the way off, a few clips were missing. Now I have to get a new valance and clips ‍♂️. I may have to go OEM which is super pricey for a piece of plastic.
  19. May 25, 2023 at 8:08 AM
    2016 4Runner Trail
    Damn sorry to hear that, I recently needed OEM yellow valance cap clip replacements (down behind front wheels), ridiculous prices. Same with hex bolt screws for fender and windshield.
    So for bumper valances, after being in a lot of threads on the topic I've never seen anyone talk about replacing, sorry. OEM is prolly the choice you know you gotta make. This problem is why just didn't risk it, stopped trying to remove those clips with the bumper on because I was starting to potentially damage them due to frustration :p
  20. May 25, 2023 at 8:09 AM
    Pathpounder
  21. May 25, 2023 at 8:19 AM
    2016 4Runner Trail
    Is it just me or do all quantities in that link say Currently Unavailable
  22. May 25, 2023 at 8:19 AM
    2016 4Runner Trail
    But ya no giv er on Amazon
  23. May 25, 2023 at 8:22 AM
    Pathpounder
    I show quantities. Sorry if it doesn't show for you.
  24. May 25, 2023 at 11:10 AM
    You could also post a "WTB - bumper valance clips" on the 5th Gen for sale section. There's got to be plenty of OR or Pro 4R owners who have replaced their bumpers with aftermarket, and may have these just lying around. They may send you what you need for the price of the postage.
  25. May 25, 2023 at 7:44 PM
    Shilo5000
    Lucas
    OC
    ‘22 TRD PRO
    I ordered some OEM and Amazon ones. Took some doing, but got the old ones off without taking off the bumper, but I have a feeling I’ll be pulling the bumper to install once the replacement valance (also OEM) shows up.
  26. May 31, 2023 at 10:11 PM
    Shilo5000
    Lucas
    OC
    ‘22 TRD PRO
    Not that anyone cares, but… new OEM valance arrived today. I ended up installing without removing the bumper (got partway through taking it off and got frustrated with all the wiring harnesses and clips - decided to save that for another project). Those Amazon clips worked perfectly. OEM valance ended up being ~$200 (toyota San Diego has free shipping and was much cheaper than my local dealer who wouldn’t match the price) which is ridiculous for a piece of plastic, but happy with it and didn’t have to worry about matching the rear valance… if I was doing front and rear, I probably would have gone with 4Runner lifestyle.
