2022 sr5 - Transmission flush
Discussion in 'Performance' started by BobBee, Dec 9, 2024.
  1. Dec 9, 2024 at 1:25 PM
    BobBee
    BobBee [OP] New Member
    2022 $Runner S5
    npne
    Nowhere can I locate this as a preventive maintenance ... only "check for leaks".
    So, if there is lifetime "fluid" warranty, this is not the same as a leak.
    Is there a PM schedule for a transmission flush?
    Bob
  2. Dec 9, 2024 at 1:28 PM
    Check the "severe" service schedule, a drain/fill every 60k miles is usually the recommendation I hear.
  3. Jan 26, 2025 at 2:03 PM
    you should never flush, only drain and refill. Really shouldnt have to touch the trans fluid until 60-70k under normal driving conditions
    RumHamRunner73 likes this.
  4. Jan 26, 2025 at 4:41 PM
    Never never do a flush.
  5. Jan 27, 2025 at 8:29 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I highly recommend a tranny drain and refill by dealer before your 5/60,000 mile powertrain warranty expired. Insist they save or watch them save the drained fluid in a clean container. It contains important clues to tranny health.
    At 48,000 miles my 2017 SR5 tranny FlexLock torque converter control inside the tranny valve body failed.
    Resulting in a new tranny covered by my 7/100,000 warranty. Due to early mis-diagnosis total charges to Toyota amounted to $8k.
    I noticed a beige color in the tranny fluid which turned out to be excessive TC lock up clutch friction lining material from the failing Flex lock system. Eventually the shudder/chatter was very noticable.
