2022 Features Question
Discussion in '5th Gen 4Runners (2010-2024)' started by Supernootz, Sep 13, 2021.
  1. Sep 13, 2021 at 3:00 PM
    Supernootz
    Supernootz [OP] New Member
    Probably shopping for a TRD ORP once the new model year hits because I definitely want BSM. One other feature that is absolutely stunning to me that has not been on that trim level was the lack of auto on/off headlights (NOT auto hi-beams). Does anyone know for sure, one way or the other, if Toyota is finally adding that to the TRD ORP?
  2. Sep 13, 2021 at 4:22 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Nope, pro and limited feature.
    Daytonaviolet likes this.
  3. Sep 13, 2021 at 6:07 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    Only pros and limiteds have the auto headlights option on the stalk. Why Toyota didn’t make it available for all models is unclear
    Desert Dawg and grizzlypath like this.
  4. Sep 13, 2021 at 6:36 PM
    Supernootz
    Wow that's just ridiculous. Okay, well thanks guys.
    Trail Runnah likes this.
  5. Sep 13, 2021 at 6:59 PM
    jlficken
    jlficken New Member
    '22 Starfire Pearl GX 460 Black Line Edition
    Why Toyota does a lot of things confuses me.
    No memory seat on anything but the Limited is another one. Also, no dual zone climate control on anything but the Limited or Pro.
    For that matter I don't get why on the GX 460 you have to get a Luxury to get MTS and Crawl Control. That one makes no sense at all.
    Surfinjoe likes this.
  6. Sep 13, 2021 at 7:12 PM
    Surfinjoe
    Surfinjoe New Member
    Joe
    2022 Lime Rush Pro
    Yep, auto headlights, dual zone would be an easy add…..
  7. Sep 13, 2021 at 8:18 PM
    The less bells and whistles the better.
  8. Sep 13, 2021 at 8:57 PM
    Daytonaviolet
    Bay Area, CA
    makes me wonder, if trd pros are really trd orp and the pro parts are simply added at the port .. do they add the stalk and dual zone there too ? Or is that configured at the factory ? I believe both require programming
  9. Sep 14, 2021 at 10:29 AM
    Old Red
    Old Red New Member
    Washington
    It's a long list...
    I can't believe it still isn't on the premiums or all the 2022 MY at this point. Since 2020, the models have come even closer as far as features (Smart key, etc) it is even easier for Toyota to do this. :confused:
    @Daytonaviolet to answer your question, the PRO is built with the Auto stalk and dual zone at the factory. It's only the cosmetic parts that get added post-port. The real difference in being able to have auto headlights comes from the programming in the main body MPX ECU. The solar sensor in the dash is the trigger for the auto headlights (Auto-high beam is the forward recognition/LDA camera) The Pro & Limited have the coding in the MPX enabled for the sensor input to toggle the headlight relay on or off based on ambient light. For the 2020+ folks that want auto headlights, it is probably as easy as putting the solar sensor in and swapping the MPX out for the TRD PRO/Limited MPX part numbers (Get a TRD PRO MPX if you have a TRD model, Limited for SR5, as there is other software based on the trim, and you CANNOT put a MPX from a smart key vehicle into a conventional ignition vehicle) As far as I know you need the programming in the ECU from the factory. No way to flash it via tech stream. The actual stalk on the column is mechanically the same for the switch. Only difference is whether "DRL" or "AUTO" is printed on it.
    -Old Red
  10. Sep 14, 2021 at 10:44 AM
    Daytonaviolet
    Bay Area, CA
    as always, thanks for the detailed info
    Old Red[QUOTED] likes this.
  11. Sep 14, 2021 at 5:58 PM
    Surfinjoe
    Joe
    2022 Lime Rush Pro
    Awesome analysis, might do some more research here….
  12. Sep 14, 2021 at 8:24 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Awhile back on the forum there were guys that were buying a $7 sensor on eBay and putting it in that little hole up on the dash to get auto headlights. There’s a spot on the dash by the windshield with a little cap on it. Pull off the cap, and it’s wired for auto dimming headlights. Or something.
    Anybody remember that thread?
  13. Sep 14, 2021 at 9:00 PM
    Daytonaviolet
    Bay Area, CA
    I know that thread. I don’t recall them receiving auto headlights from just adding the sensor. What I believe they got was auto dimming dash and radio.
  14. Jan 28, 2022 at 8:35 PM
    fbingha
    fbingha New Member
    Are there parts that we can purchase for the 2022 to add auto headlights and dimming display? A new stalk and a light sensor perhaps?
  15. Apr 12, 2022 at 5:00 PM
    Walkem
    Walkem New Member
    Ontario, Canada
    Waiting On: 2022 TRD Offroad - Lunar Rock
    I used to work at Honda and built the dashboards. I know it's not Toyota but I reckon it's close to the same. If you build a car that has auto headlights vs not the entire wiring harness is different. There will be no wire leading to that plastic cap in the dash. On top of that your signal arm off the steering wheel where the lights are controlled would be missing the auto selector.
    I imagine it would be a HUGE pain in the dick to add it afterwards.
  16. Apr 12, 2022 at 5:19 PM
    Correct, no auto headlights with the sensor.Only auto dimming dash and radio.
    https://youtu.be/ozlauIjifeo
    meowKittieh likes this.
  17. Apr 13, 2022 at 7:32 AM
    scanny
    scanny New Member
    Ontario, Canada
    It strange but my Canadian 2022 TRD Off-road has auto lights standard. So maybe if you can find Canadian parts maybe you can install it in your truck. But now I have no option to turn headlights off, I got 3 positions on the lever - Auto, headlights on and parking lights on.
  18. Apr 13, 2022 at 7:51 AM
    Walkem
    Walkem New Member
    Ontario, Canada
    God am I relieved to hear that. I am waiting for my 2022 Off-road. I was told it should be here next month. Luckily here in Canada our models usually have more options than the American ones. That being said we do pay more so it all works out lol. Would be tough to remember to turn them on after my last 2 vehicles having auto headlights.
  19. Apr 13, 2022 at 8:21 AM
    scanny
    scanny New Member
    Ontario, Canada
    Yes, we have no choice for TRD Off-road features, but it comes loaded with all the modern stuff. We have dual climate control, smart key, auto lights, rear, side and front cameras, Navigation system, bling spot monitoring and sort of electronic driver aids. Toyota now can track you everywhere and remotely stop/start engine. Personally I don't need most of those features but we have no choice : )
  20. Apr 13, 2022 at 5:08 PM
    Walkem
    Walkem New Member
    Ontario, Canada
    Ive had a 2015 Tacoma SR5, 2016 Tacoma TRD sport + tech package, and then 2020 tundra TRD sport premium. The 2022 4runner had no other package options as far as tech or premium.
    Can you tell me if the offroad has the rear window up and down buttons from the outside next to the emblem?
  21. Apr 13, 2022 at 5:20 PM
    scanny
    scanny New Member
    Ontario, Canada
    Yes it is has the buttons, I could open an close rear window from outside. You need to have your working smart key with you though.
  22. Apr 13, 2022 at 5:23 PM
    Walkem
    Walkem New Member
    Ontario, Canada
    Beauty, thanks for answering my question! If I have anymore I'll reach out to you lol.
  23. Sep 21, 2022 at 10:25 PM
    4T6&2runner
    4T6&2runner New Member
    22 ORP
    have you noticed your lights will not turn off on auto unless you open and close your door?
    So frustrating. What I wouldn’t give for an “off” option…
  24. Mar 19, 2023 at 12:29 PM
    toyotatron
    toyotatron New Member
    I have a 2022 TRD off premium and added auto headlights
    Body ecu part # 89220-35650, Light sensor 89121-30020, head light switch 84140-35171. Part numbers from a TRD Pro same year.
    The auto head light function works perfect the only problem I have is that my XM radio icon on the radio disappeared. I don't know why it would affect the radio but it did.
    I switch my body ecu back and the XM icon comes back.. If anyone knows how to fix this one problem would be a lot of help.
    FYI you have to hand shake the smart key ecu to get you remotes to work after body ecu is replaced.
    glwood54, trail_runner_93 and Rob41 like this.
  25. Jun 25, 2023 at 9:55 PM
    HBJ32
    HBJ32 New Member
    figure out the xm radio problem? Looking into doing this mod
  26. Jun 25, 2023 at 11:12 PM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Are you talking about when turning off the car? There should be an option in the head unit menu for that (time vs. opening doors).
    FYI all, all 4Runners have auto on/off lights: if you leave them on, they turn off when you turn off the car, and turn back on when you start it again. Not the same as true auto, but good enough IMO if you can't be bothered to turn on your own headlights.
  27. Jun 26, 2023 at 7:53 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I don't think that's the case for all trim lines. The headlights don't turn off automatically on my '23 ORP, even thought the DRLs do, and event hough it has automatic high-beam dimming. I would trade the latter for automatic turn-off at shutdown, but I'm sure there's a reason they set it up like this that I'll discover off-road.
  28. Jun 26, 2023 at 9:03 AM
    Agent_Outside
    Built 2011 T4R Limited
    My 2011 has off, parking lights, auto, and on.
    I can leave it in auto and the headlights will turn on and off as needed depending on current conditions. I leave it on auto 100% of the time and never change it I haven’t touched the switch in probably 5 years.
  29. Nov 27, 2023 at 9:36 AM
    Lou
    Lou New Member
    2021 TRD Off Road Premium
    I ordered the light sensor from jpanime2014 on eBay after seeing here that people had good results. I received it after about a week and installed it yesterday in my 2021 ORP. Now my display changes between night and day automatically. I wish I had known about this 2 years ago.
    It did not give me auto headlights, but I don't really care about those anyway. I turned them off on my Tacoma, because I wanted control over the high beams.
    https://www.ebay.com/itm/165027927715
    Daytonaviolet[QUOTED] likes this.
  30. Sep 2, 2024 at 6:43 PM
    dougfrommaine
    dougfrommaine New Member
    @toyotatron this was a while ago, but great info. It seems easy enough to swap the parts, but how do you "handshake the smart key ecu to get your remotes to work after body ecu is replaced"?
