2021 Nightshade Headlights
Discussion in 'Lighting' started by Inayah, May 15, 2021.
  1. May 15, 2021 at 9:51 PM
    Inayah
    Inayah [OP] New Member
    2021 4Runner Limited Nightshade
    Morimoto XB headlights Gen 2
    1F774EA2-94D2-4AF9-8C21-87CBD608F4A6.jpg B458BADC-679C-4302-9BCF-B066DBC1AC53.jpg A3C56DDD-4A87-45AB-B184-4C8643BFDF28.jpg 7C553A02-49F5-4180-9BF6-9A1B0382B925.jpg F4E6C288-009B-4C20-A58B-ACBBD77D4661.jpg AA317146-9D92-4A7B-8473-2F7670FB611F.jpg Hello, I recently upgraded my stock Led headlights to the morimoto XB gen 2 headlights mainly because the stock DRL was halogen and any led bulb I tried to replace it with simply wouldn’t work. I learned later it had something to do with the computer regulating the amount of out put to the DRLs, which only allowed the halogens to work. After a lot of convincing myself, I decided to buy the expensive headlights and do the install. Although I had to wait for a converter because the limited and TRD models in the 2021 have a different wire connector they finally came out with one and I ordered the lights. Everything fir perfectly, and I love the way they look. Especially the sequential turn signals, they give it such a modern look. The only thing is though that my highbeams don’t work now. I noticed in the converter I received, it has two wires going to the 4 pin adapter, but the wires coming from my vehicle have 3 connected to the adapter. I’m assuming one of the wires that’s not there is supposed to control the high beams. I tried every connector in every possible combination, blew a fuse while doing so, and still no highbeams. If anyone knows about this, please let me know what it could be? I’ll attach some pictures of before and after as well. Also if anyone’s interested in buying OEM 2021 headlights that come standard with LEDs, please let me know as I have them up for sale. They are in absolutely flawless condition with less than 1000 miles driven with them on. 4ED6F692-4067-4C78-BC51-CA7BBAC14ED8.jpg 2673DB6D-F54C-49CA-B0C6-7CA5FE0D264D.jpg Thanks!B72D652F-19C8-464E-8194-8C065EEFF1EF.jpg
    Dabigono and Stumpjumper21 like this.
  2. May 16, 2021 at 6:18 AM
    Ebadai98
    Ebadai98 New Member
    18 TRD Off Road
    PM sent about headlights!
  3. May 20, 2021 at 1:14 PM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    Your high beams do not work because the factory bi-LED projectors are controlling a mechanical shutter for the high beams rather than igniting a bulb. That is, the factory projector is fully lit but there is a shutter that provides a cutoff for when you're using low beams only.
    The Morimoto headlights are designed to replace the single LED projectors and older halogen units only, because their high beams are separate lamps (and circuits controlling them). They are not compatible with the new Pro and Limited trucks, as they have completely different circuitry controlling the DRLs and high beams.
    There are many examples of the aftermarket headlights working on the other trims, and also retrofitting the single LED factory lights to older trucks. But so far I have not seen a successful implementation on the Pro/Limited trucks. You'll need some custom wiring and controls for them to work correctly.
    suaveflooder likes this.
  4. May 20, 2021 at 6:11 PM
    h4yd3n
    h4yd3n New Member
    Hayden
    2021 Limited
  5. May 29, 2021 at 12:29 AM
    Inayah
    @mynameistory. Took me about a week for figure it out, even with the adapter harness provided from morimoto they weren’t working and I was torn because I didn’t want to do any wiring additives. However, I changed my high beam fuse from a 25 to a 10 and it works just like factory. So if anyone has a trd pro or limited 2021, it’s as simple as changing that fuse and you’re set.
  6. May 29, 2021 at 11:27 AM
    mynameistory
    Tory
    You were blowing a 25 amp fuse before, and now you've switched to a 10 amp fuse and it's fine? Something isn't adding up here.
    Kyblack76 likes this.
  7. May 29, 2021 at 11:48 PM
    Inayah
    That’s literally all I did, and it works like a charm.
  8. May 30, 2021 at 1:39 PM
    mynameistory
    Tory
    Yes but that's not how electricity works. What else did you do?
  9. May 30, 2021 at 1:41 PM
    Inayah
    Seriously, I did nothing else.
  10. Oct 20, 2021 at 6:25 AM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    2021 Magnetic Grey Metallic TRD Pro
    Are these still working perfectly?
  11. Oct 20, 2021 at 7:24 AM
    Inayah
    absolutely nothing wrong with them, not a scratch. In perfect working condition.
  12. Oct 20, 2021 at 8:36 AM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    So you are still running the XB's? DO you like the overall output of them?
  13. Oct 20, 2021 at 8:50 AM
    Inayah
    Yes I am, and the output is great, in fact I have people highbeam me regularly because they think I have my highbeams on.
  14. Oct 21, 2021 at 6:42 PM
    mynameistory
    Tory
    That's... not a compliment. You either have them aimed incorrectly, or the optics are very poorly controlled by the manufacturer.
  15. Oct 21, 2021 at 10:13 PM
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    Yep that’s correct. I have the Mori XBs too. I spent some time adjusting them properly and I never get flashed..well at least not how I’d like to be :)
    Jrunr likes this.
  16. Jan 7, 2022 at 7:28 PM
    Belfastboy
    Belfastboy New Member
    2021 lifted pearl limited
    BP51’s/IKON rims 275 70 17 falkens Prinsu S&B CAI Pedal commander
    Apologies in advance. Recently had Slee in Colorado do a 2.5 lift on my 21 limited along with putting in squadrons to replace my fogs, now my headlights seem pathetic. I like the Morimotos but doesn’t sound like plug and play? Considering my lift-Do I need to adjust my factory headlights down? The Squadrons really light up the road in front of me but now it seems like the headlights are weak further out..i would like brighter and more white light,a super model girlfriend , to win the lottery and a few other things. Any advice? Especially on the super model thing.
  17. Jan 7, 2022 at 7:45 PM
    mynameistory
    Tory
    Your headlights aren't designed to blind other drivers, that's probably why they are overwhelmed by off-road lights. I'd recommend removing the squadrons and putting in a better performing, street legal fog light.
    jmkulbeth likes this.
  18. Jan 7, 2022 at 8:13 PM
    Belfastboy
    Thanks- I’m not looking to blind other drivers, I had the squadrons angled down a bit when installed- I don’t get flashed, at least haven’t in the 2k since install. Just looking for something that is a bit more white to blend better and be a bit brighter. Other than daily day driving I do some distance driving at night and was hoping there was an enhancement.
    Thanks-
  19. Jan 8, 2022 at 9:05 AM
    mynameistory
    Tory
    So, headlights aren't really designed to light up the foreground in front of your truck. They're meant to project light far into the distance with a concentrated beam pattern (called a hotspot) and provide gentle fill illumination below that. Pull up to a wall with your headlights on to see what I mean. If the headlight pattern was bright everywhere, the street immediately in front of your truck would be overwhelmingly bright, constricting your vision to about twenty feet in front of you (not ideal for driving). You have OEM LED headlights that perform twice as well as the previous halogen equipped trucks, and people manage to get down the road with those just fine.
    As for the squadrons, there are only a few varieties to get. There's the SAE fog pattern light (which is street legal but very poor performing, as they are dimmer than the factory halogen or LED fog lights). They have glare shields and look like this:
    Then there's the sport/pro/racer versions. They're off-road only lights and they look like this:
    There isn't really a way to "aim these down", as they don't have a pattern cutoff the way a proper fog light does. This is what a fog pattern looks like:
    And this is what the Baja squadron looks like:
    Not ideal for street use, as you're glaring everyone's face off in opposing traffic.
    Check out this thread for more info about fog lights and their use cases. The links at the top of the thread are the current list of best recommended products:
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
  20. Jan 8, 2022 at 11:44 AM
    Belfastboy
    Great info.this is why i joined.will check the links. What is the purpose of the Morimotos? Why do people buy them? I came from a stock 2018 Audi SQ5 that had way better coverage than the 4R with or without the new fogs. I am looking for function above all else and dont use the fogs around town.Being new to all this my mindset is more projectors would be better? Are there better LED’s that would do it? Anyway, as you can probably tell by my questions-its all new to me.
  21. Jan 8, 2022 at 3:12 PM
    mynameistory
    Tory
    Same guy ran a test on the newer 4Runner LED headlights (low beam, in your case you have low and high beam LED. The high beams activate a shutter to reveal the full projector in your headlights).
    https://www.tacomaworld.com/threads...ctor-headlights.589465/page-252#post-26224347
    He notes that the Morimoto unit is likely very similar to the Tacoma version that he has tested, so you can see the lux comparison for yourself. Note that the Morimoto units use a higher color temperature (blueish rather than flat white), and they lack proper uplight pattern above the cutoff (a small amount of light is allowed to leak above the cutoff, helping to illuminate street signs). Lastly, be aware that Morimoto does not make their own headlights, they are rebranded units from a company in China called VLAND. I would say that the quality is ... hit or miss. OEM lights will have better consistency and reliability from one set to the next.
    memario1214 likes this.
  22. Jan 8, 2022 at 3:33 PM
    Belfastboy
    Thanks! I’m sticking with what I have. Appreciate the insights.
  23. Jan 9, 2022 at 6:56 AM
    mynameistory
    Tory
    I understand the frustration, especially coming from other vehicles with headlights from this century. The 5th gen 4Runner was introduced in 2009 and has had minimal updates. Even the newer LED headlights are probably a compromise, because they had to fit them in existing sheetmetal.
  24. Jan 9, 2022 at 8:02 AM
    Belfastboy
    Yep.Nothing is perfect..
  25. Jan 9, 2022 at 1:01 PM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    But it’s fun making it as good as possible!
  26. Jan 9, 2022 at 1:19 PM
    Belfastboy
    That’s the best part for me.
    Jrunr likes this.
  27. Jan 10, 2022 at 2:38 AM
    suaveflooder
    suaveflooder New Member
    i can agree with this. I came from a Tacoma with the LED’s and it is crazy the difference. I’m not complaining because I’ve owned a ton of older cars with much worse lighting, but the Tacoma LED’s were far superior to what LED set up they have in the 4 runner.
  28. Jan 10, 2022 at 6:32 AM
    mynameistory
    Tory
    Yep, they must have had two different engineering teams for the headlights. No idea why they would put kick-ass LED reflectors in the Tacoma
    and a single wimpy LED projector in the 4Runner.
    https://www.tacomaworld.com/threads...ctor-headlights.589465/page-182#post-24546907
    Speaking of which, these popped up in my eBay search for OEM LED replacements. Don't think I'm going to gamble though.
    https://www.ebay.com/itm/Pair-LED-R...r-2014-2021-Toyota-4Runner-4-0L-/403325141925
    suaveflooder[QUOTED] likes this.
  29. Jan 11, 2022 at 2:58 AM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
