2020 Mirrortap location
Discussion in '5th Gen 4Runners (2010-2024)' started by j485, Jul 2, 2020.
  1. Jul 2, 2020 at 5:38 PM
    j485
    j485 [OP] New Member
    2020 OR Premium
    Hi All,
    Just installed my radar detector.
    I couldn’t find this posted for the 2020s as the wiring location is different. The mirrortap location on the 2020 is hiding behind the mirror stem trim (there is actually two trim pieces). Blue wire is the hot one. Don’t mess with the trying to tap the TSS as it won’t power the device. Good luck!
    ca5280 likes this.
  2. Dec 1, 2020 at 9:02 AM
    Elfer1
    Elfer1 New Member
    Chris
    Omaha, Nebraska
    2020 Venture - Blue
    Stock so far...
    What type of hardwire kit did you use? I looked on Blendmount’s website and the only option they show for the 2020 4Runner is a fuse box hardwire kit. I’ve done a couple fuse box kits but they require more hiding if wire... would really like to get the kit that taps the mirror power.
  3. Dec 1, 2020 at 9:41 AM
    j485
    2020 OR Premium
    I just reused the MirrorTap I had in my old VW. It has a in line fuse. Haven’t had any issues with it in the 4R. Once you get the trim off the tap slides in easy. You shouldn’t have to really hide any wires, as the trim covers most of it. Good luck.
  4. Dec 1, 2020 at 5:50 PM
    Elfer1
    Elfer1 New Member
    Chris
    Omaha, Nebraska
    2020 Venture - Blue
    Stock so far...
    Ok, got it. Thanks!
  5. Dec 12, 2020 at 8:33 PM
    dosomeplowin
    dosomeplowin New Member
    '24 ORP
    Hey man, I just wanted to say thank you for posting this. Just used it to tap the mirror power for the dashcam in our 2021. Having your post made it a little quicker and easier!
    j485[QUOTED][OP] likes this.
  6. Dec 30, 2020 at 11:25 PM
    j485
    2020 OR Premium
    Glad it worked!:yes::yes:
  7. Jan 20, 2021 at 7:03 AM
    LJCPA
    LJCPA New Member
    Lee
    2021 Toyota 4RUnner
    How do you open the mirror stem trim? Take off mirror? Take off box hiding the auto dimmer camera? I'm concerned I'm going to break something... any suggestions appreciated... Thanks
  8. Jan 20, 2021 at 7:42 AM
    j485
    2020 OR Premium
    I didn’t take off the mirror. The auto dimmer is inside the mirror, so nothing to worry about there. Not sure is a 21’ is different. First try and slide it down. If that doesn’t work, just be careful and slowly pull one side of the plastic cover off and then the other side. Go slow and your should be fine. Good luck.
  9. Jan 20, 2021 at 6:31 PM
    dosomeplowin
    '24 ORP
    Just go slow- I used a plastic trim remover to gently pop one side off first. They just snap back together when you're done. You don't have to take the mirror itself off, just the trim pieces around where it connects to the windshield/TSS module.
  10. Jul 20, 2021 at 6:02 PM
    Topher406
    Topher406 New Member
    Chris
    2021 TRD ORP (White)
    Would you be able to post a few other pictures of where your wires went? Its a bit hard for me to see whether you're looking from top or bottom, and how you got in there. I know there is that casing that can slide up and down but I am not seeing any connectors and only see a wire that goes into the headliner. I am in a 2021 and have the box for that safety system next to my mirror like yours I believe.
  11. Oct 5, 2021 at 8:21 AM
    Burnt Taco
    Tucson, AZ
    '22 ORP, Wife's 2020 SR5
    How about an install write up with pics??
  12. Oct 18, 2021 at 2:20 AM
    mweisslaw
    mweisslaw New Member
    Monte
    4runner
    None at the moment
    Just installed my radar detector with a mirror tap. The connection, as noted above, is in the stem. Simply slide the plastic cover of the mirror stem and it will be easy to pop off. There is a small harness containing two wires in the stem. Remove the harness, insert the two plugs and return the harness into the stem and you are done. 2021 TRD Off Road Premium.
  13. Oct 18, 2021 at 8:55 AM
    Big B
    Big B Out Exploring
    Reno/Tahoe
    2020 TRDOR
    KINGS! w/ adjust Method Race Wheels, Good Year Ultra-terrains 285/70/r17, GOBI Rack, Baja-Designs/Cali-Raised LED Lights, SSO stealth front bumper, RSG Sliders, FACTOR 55 ultrahook Smitty Bilt x20 winch (syn.), TYT TH9800, X Bull Recovery Boards
    better pics of this?
  14. Oct 18, 2021 at 9:09 AM
    mweisslaw
    Monte
    4runner
    None at the moment
    As soon as I get home I will post some pictures. I’m in the GT today. It’s beautiful outside!
    Big B and Shnook718 like this.
  15. Oct 18, 2021 at 2:15 PM
    mweisslaw
    Monte
    4runner
    None at the moment
    Ok. Let’s see if this helps.
    First, slide the cover off of the stem. Not much force is needed. It will slide out of the way.
    Next you will see the harness. There is a small tab in the middle of the harness that you will need to depress in order to remove the harness.
    Depress tab and remove harness.
    Insert mirror tap connections to harness.
    Reinsert harness into harness holder.
    Return cover to stem.
    Turn on accessories mode and see if radar detector powers on.
    Turn off accessories mode to see if radar detector powers off.
    If the radar detector does not turn, you have inserted the wrong mirror tap connections into the wrong sleeve of the harness. Simply reverse the inserted connections and try to power on and off the detector.
    Gently insert the excess wire above.8BC7699F-ED46-4AE7-A46D-600D55B836C8.jpgB4D6616B-2757-445E-955A-E1DD517F1E81.jpgF51CC428-1348-4276-B26B-D6908021CC63.jpg5EBDF1E8-3CC3-4A78-A6F0-6AB5E43C2886.jpgFD383B12-1D7B-4D20-B328-0D4B7440AFE8.jpg5464A2A6-EC43-4253-8EFD-D4434F16D4F5.jpgB651AD8A-DCFE-47D2-AC15-C8E26E83C4B4.jpg
    That’s it.
    Dabigono, Go Birds, ptengert and 4 others like this.
  16. Oct 18, 2021 at 2:43 PM
    Burnt Taco
    Tucson, AZ
  17. Oct 18, 2021 at 2:44 PM
    mweisslaw
    Monte
    4runner
    None at the moment
    You bet!
  18. Oct 19, 2021 at 8:14 AM
    Big B
    Big B Out Exploring
    Reno/Tahoe
    2020 TRDOR
    Thanks! Ordering now
  19. Oct 20, 2021 at 12:12 AM
    mweisslaw
    Monte
    4runner
    None at the moment
  20. May 3, 2022 at 11:30 AM
    dgtulsaguy
    dgtulsaguy Rocklanding Jedi Master equivalent
    22 MGM ORP long travel
    Got it done using this thread as info. Your guys rock!
  21. May 2, 2023 at 12:33 PM
    Go Birds
    Go Birds New Member
    23 ORP
    Thanks for the tips here, everyone! I was able to get my Uniden R7 all set up today in my 2023 ORP on a BlendMount. Here are a few extra nuggets of info that may be helpful:
    1. The part number for the mirror stem cover is 87818-53020. Why do I know this? Because, of course, I broke one tab on mine while popping it off.
    2. The BlendMount model that fits my 2023 ORP is BR7-2001R. You should remove the included bushings for proper fit around the mirror stem.
    3. I used BlendMount mirror tap power cord # MTX-1015, and it was the perfect length (some slack but not too much to try to hide). The second largest taps (of the four pairs provided) are the best size for the harness.
  22. May 8, 2024 at 3:30 PM
    HyperX
    HyperX New Member
    Dan
    2024 4runner TRD off road premium
    none yet
    Thanks for this awesome thread explaining how to hard wire my radar detector! CAC700C5-0F46-4AD0-9DB8-1058FC1EACDC.jpg
    RDCoug likes this.
  23. Oct 31, 2024 at 6:48 PM
    rproc
    rproc New Member
    Richard
    Calgary
    21 Black 4Runner ORP
    Sorry to drag this thread back from the dead, but I just wanted to say thanks for sharing!
    This is exactly what I was looking for
