2020 Limited to SR5 bumper swap
Discussion in '5th Gen 4Runners (2010-2024)' started by soyabm, Jan 16, 2020.
  1. Jan 16, 2020 at 10:57 AM
    soyabm
    soyabm [OP] New Member
    Soyab
    2020 4Runner Limited
    So I'm considering doing a bumper swap but there are a couple things that would make that more difficult than a 2019 or older.
    1. Safety Sense radar - I know that it's new to 2020 but the location, distance from ground, and possibly angle differs from trim levels. Just spoke to my local Toyota service tech and he told me that any little change could throw it off (even lifting) and they are told by Toyota to disable the whole system if a car comes in modified.
    - has anyone done a bumper swap from limited/nightshade to SR5/TRD and how did it go?
    -what aftermarket options do I have to recalibrate the system if it does spas out?
    2. This should be common with older models but what's the best location for parking sensors to be drilled into new bumper?
  2. Jan 16, 2020 at 3:42 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    I think it’s a fairly easy swap when I did it. My only concern is how is the TSS attached to the limited bumper and can the original one be swapped to the TRD bumper ?
  3. Jan 16, 2020 at 3:48 PM
    soyabm
    Soyab
    What's the difference between TRD and Sr5?
    Daytonaviolet[QUOTED] likes this.
  4. Jan 16, 2020 at 3:50 PM
    Daytonaviolet
    Bay Area, CA
    TRD bumper has slats on the bumper to secure the valance. Sr5 has no valance or slats.
    Here’s a picture of my TRD front bumper.
  5. Sep 16, 2020 at 9:54 PM
    cm3220
    cm3220 New Member
    2020 4runner limited
    none yet :(
    Hi there OP, did you have any luck figuring it out. I have a 2020 limited as well but would love to change the front!
  6. Sep 16, 2020 at 11:27 PM
    Daytonaviolet
    Bay Area, CA
    Should be plug and play with the right parts
  7. Sep 17, 2020 at 4:26 PM
    cm3220
    cm3220 New Member
    none yet :(
    Awesome, yeah I took a look online and through your spread sheet today which was super helpful (the dealership basically blew me off). I can't find the part number for the 2020 with a cutout for the TSS online (on McGregor and such), still searching though, any thoughts?
  8. Sep 18, 2020 at 11:14 AM
    Daytonaviolet
    Bay Area, CA
    i believe this is the lower radiator grille w/ tss. perhaps someone with a 2020 sr5/trd can confirm. p/n# 53112-35090
  9. Jan 13, 2021 at 10:09 AM
    Phishmonger
    Phishmonger New Member
    Atlanta
    2021 Limited Magnetic Grey
    TRD pro front bumper cover swap, TRD pro roof rack, TRD pro skid plate, raptor lights.
    Anyone have success doing the bumper swap without messing up their TSS?
  10. Jan 13, 2021 at 11:20 AM
    Daytonaviolet
    Bay Area, CA
    Should be no issue as trd’s have the same tss.
  11. Jan 13, 2021 at 12:22 PM
    Phishmonger
    Atlanta
    that's what I thought, but is the sincere high or angled differently? The guys at the dealership said it would have to be recalibrated for $250 if it was removed. Has anyone tried a bumper swap with the tss?
  12. Feb 15, 2021 at 10:42 AM
    matoolie
    Michael
    2021 Lunar Pro
    From your avatar looks like you completed the bumper swap. Any issues with TSS? Is the 53112-35090 part number correct for the lower grille to mount the TSS?
  13. Feb 20, 2021 at 4:53 PM
    Phishmonger
    Atlanta
    53112-35090 Is the part, didn’t have a problem with the TSS after the switch. Just take your time, I’ll put together some parts that I didn’t think about but you need.
    laceofbase likes this.
  14. Feb 20, 2021 at 7:16 PM
    matoolie
    Michael
    2021 Lunar Pro
    Thanks for the confirmation. Just to make sure, this grille part number has the TSS mount built into it and has the black square front cover for the TSS also?
  15. May 9, 2021 at 7:52 PM
    laceofbase
    laceofbase New Member
    2017 Black 4Runner Limited
    you ever put that list together? Would love to see it if you don’t mind sharing. This is my next project - looking to skip some pain & suffering.
