2020 drls stopped working
Discussion in 'Lighting' started by newlife, Aug 6, 2021.
  1. Aug 6, 2021 at 3:50 PM
    newlife
    newlife [OP] Not all who wander are ...... squirrel
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Long story short my drls just randomly stopped working. Have checked fuses, bulbs and wires no breaks in wires, no blown fuses, and bulbs were ruled out by switching bulbs out. High beams work so stumped. Anything else I should check ? This happened on our Wyoming trip and took until now so I could diagnose. I still need to check voltage on the wire With the switch turned on.
  2. Aug 6, 2021 at 3:52 PM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Also to add I took my bulbs and put them in my wife’s 21 and they worked fine.
  3. Aug 6, 2021 at 4:45 PM
  4. Aug 6, 2021 at 5:11 PM
    Mtbpsych
    Mtbpsych New Member
    Might sound dumb but did you check the interior fuse box?
  5. Aug 6, 2021 at 7:15 PM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Yes. Pulled every fuse out and visually checked then had a buddy go behind me and check as well.
  6. Aug 6, 2021 at 7:23 PM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    Visual is not always conclusive. Swap the fuse with one that you know it works or get a multimeter.
    newlife[OP] and Toy4X4 like this.
  7. Aug 6, 2021 at 7:43 PM
    Parking brakes off?
    Both bulbs checked? (It seems they work in series)
    2Toys likes this.
  8. Aug 6, 2021 at 7:43 PM
    Mtbpsych
    Mtbpsych New Member
    I second not relying on visual inspection. I’d use a circuit tester on each one to make sure everything is working as it should.
    2Toys and Toy4X4 like this.
  9. Aug 7, 2021 at 10:46 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    The issue is there isn’t a dedicated fuse for the drl lights. I’ve read it could be an ign fuse and swapped those around with no change. I’m digging out my multi meter now to check at the socket. If it’s in the stalk I’ll have to take it to the dealership
  10. Aug 7, 2021 at 10:47 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Yes both bulbs pulled and they work in my wife’s truck but hers don’t work in mine
  11. Aug 24, 2021 at 11:34 PM
    dricko
    dricko New Member
    Derick W.
    Could be a bad relay or signal socket.
    newlife[OP] likes this.
  12. Aug 25, 2021 at 2:14 AM
    Daddykool
    Echoing kmeeg - parking brake is a possibility. Depress/release a few times. Could be that switch. Make sure the pedal comes all the way up and doesn’t bind or stop short.
    2Toys and newlife[OP] like this.
  13. Jul 31, 2022 at 3:31 PM
    88maroon
    88maroon New Member
    Any info or update on this? My drl just stopped working. When switched to drl no light. Switch it again to one where the orange sidemarkers come on and it works. Trying to figure out what's wrong
  14. Jul 31, 2022 at 6:56 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    People often overlook that after engine start, the emergency brake has to be released for the DRLs to come on. Try that first before you tear into everything.
  15. Jul 31, 2022 at 7:07 PM
    88maroon
    88maroon New Member
    I'll try that. But my e brake is usually never on. I have an aftermarket remote start and this happened before. I remember taking it to the dealership and the tech saying a wire was loose and he pushed it back in. I'm gonna look at it tomorrow again
    2Toys[QUOTED] likes this.
  16. Jul 31, 2022 at 7:09 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    Ah, the old remote start. There have been so many problems reported with that. Personally, I'm very glad I have a 2019.
    MeefZah likes this.
  17. Jul 31, 2022 at 7:10 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Did you check the light stalk? Mine has DTRL off as an option.
  18. Jul 31, 2022 at 7:13 PM
    88maroon
    88maroon New Member
    Yeah I turned it to drl and no go. Looked at my infotainment and the setting is to have drl on a well.
  19. Aug 2, 2022 at 4:55 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Mine ended up being corroded wiring in the drl fuse. I unfortunately sold the black 4R a little bit after this. So I can’t provide you much more on that one. The red 21 has yet to have this problem. But if it does I’ll report back.
    88maroon likes this.
