2020 Aftermarket TRD Pro Grill Attempt
Discussion in '5th Gen 4Runners (2010+)' started by Defend_Pono, Feb 12, 2020.
  1. Feb 12, 2020 at 8:03 PM
    Defend_Pono
    Defend_Pono [OP] New Member
    Kupono
    Oahu, Hawaii
    2020 SR5 4x4 T4R Super White
    INTERIOR Black w/ White Piping TRD Wet Okole Seat Covers Husky All Weather Floor Mats 5% Ceramic Tint All Around AJT Pink Steering Wheel Emblem LIGHTING Full White LED Interior Lights LED Amber DRL's LED Headlights Highlander SE LED Fog Lights Cali Raised LED Low Pro Ditch Lights Mictuning LED 8pc Color Changing Rock lights SUSPENSION/TIRES Toytec 3" Boss Kit (Powder Coated Pink) Toytec 1" Body Lift SPC Upper Control Arms 285/70/17 Nitto Ridge Grapplers EXTERIOR TRD Pro Grill Aftermarket Debadged TRD Skid Plate (2015-2018) AVS Low Profile Window Visors EcoTechne Roof Rack
    Not sure if im blind but I absolutely cant find any information on installation of the "aftermarket" TRD Pro Grill on the 2020 4runners.
    The only lead I got is from this thread: https://www.4runners.com/threads/be...-pro-heritage-grille.11836/page-2#post-131033
    However I do know the OEM 2020 TRD Pro/Heritage grill is available to purchase through your local Toyota Dealer, but it will cost you BOTH of your arms and legs. I personally am not willing to spend that much when I can modify the aftermarket TRD Pro grill.
    So here I am! I do know Iʻll need to perform some trimming at the inner bottom portion of the grill to allow room for the grill to sit flush over the Toyota Safety Sensor. I do also know that the upper grill replacement has been changed for the 2020 4runners as well. How have they changed? I do not know, so any info from you fellow 2020 T4R owners would be greatly appreciated.
    Here is where ive got so far....
    Took measurements of how long the sensor is and how far the sensor sticks out. Orange arrows show where the sensor is located fyi.
    Used a Dremel Kit to cut and shave.
    Please if any other 2020 owner has performed this install your help or guidance is greatly appreciated.
    arnette64 and Daytonaviolet like this.
  2. Feb 12, 2020 at 8:49 PM
    4X4Runner
    The left coast
    NightRunner likes this.
  3. Feb 13, 2020 at 8:47 AM
    Ajmogen
    Ajmogen on pace to hit 200 posts by 2030
    Aaron
    Wisconsin
    2016 Red Tacoma. 2017 Red 4R. 2010 Red Yaris. 2017 Honda Africa Twin
    Liscence Plate Surround
  4. Feb 13, 2020 at 9:03 AM
    adrtoy
    adrtoy New Member
    I put an older oem on my 2020 and like you mentioned you do have to trim the black cover section (easy) and the upper grill. I'm not sure how to explain the cutting on the upper section, but I'll get you a pic at some point. I know you can also buy some new plastic brackets up top to avoid cutting the upper grill. I cut mine.
    arnette64 and Defend_Pono [OP] like this.
  5. Feb 13, 2020 at 12:11 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    looks good. how does it fit when you press it in ? (without tape)
  6. Feb 13, 2020 at 7:30 PM
    Defend_Pono
    Kupono
    Oahu, Hawaii
  7. Feb 13, 2020 at 7:31 PM
    Defend_Pono
    Kupono
    Oahu, Hawaii
    That would be greatly appreciated man! Thank you!
  8. Feb 13, 2020 at 9:09 PM
    TMReidAZ
    TMReidAZ New Member
    Ted
    2020 White SR5 Premium 4x4
    I’d also like to understand what needs to be trimmed on the upper section! Thanks in advance!
    Defend_Pono [OP] likes this.
  9. Feb 14, 2020 at 5:33 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    You're cutting up a 2020 front?? You have way more guts than me... :amen:
  10. Feb 14, 2020 at 6:13 AM
    adrtoy
    adrtoy New Member
    [​IMG] [​IMG]
    Your actually cutting the new pieces you buy to add and not altering anything on the vehicle.
    It's hard to really tell from a pic, but you basically take a course burring tool and grind out room for the 2020 bracket to recess into the new grill section. The old screws only grab by a couple threads so be prepared to buy 2 new screws if it bothers you. All the work is totally hidden and actually added about 10 minutes to the install. I think you can tell the old from new pieces in the pics. The old dirty piece is the used trd grill section and clean is 2020 bracket.
    Kfish, arnette64 and Defend_Pono [OP] like this.
  11. Feb 14, 2020 at 6:15 AM
    adrtoy
    adrtoy New Member
  12. Feb 14, 2020 at 7:48 AM
    AdmiralX
    AdmiralX New Member
    2019 TRD OR P, White
    Nice! I wish I could help but I only did the heritage grill on my 2019. I will say I love the way it looks after I put it in and the truck looks better IMO. Hope this goes well for you.
  13. Feb 14, 2020 at 10:32 AM
    Rngr188
    Rngr188 New Member
    Chad
    Harrison, AR
    Silver 20 TRD ORP
    Can you not get a PRO grill from a 20 to avoid any cutting? Or is there a difference in the TSS sensor location? Wife has a 20 TRD ORP and would like to have the PRO grill.
  14. Feb 14, 2020 at 10:42 AM
    adrtoy
    adrtoy New Member
    It's my understanding you can, but in my case I already owned it.
  15. Feb 14, 2020 at 10:43 AM
    Rngr188
    Rngr188 New Member
    Chad
    Harrison, AR
    Silver 20 TRD ORP
    Oh got ya.
  16. Feb 14, 2020 at 11:42 AM
    Defend_Pono
    Kupono
    Oahu, Hawaii
    I work at the local Toyota dealer here in Hawaii and the 2020 Pro grill is available to purchase from the parts department. However, with my employee discount I would be paying about $700-$800 for the part.
    Shadoww and TRDPro916 like this.
  17. Feb 14, 2020 at 11:58 AM
    Defend_Pono
    Kupono
    Oahu, Hawaii
    Thank you so much man. Really appreciate your help! Quick question, this picture refers to the support bracket that connects from the grill to near the hood latch correct?
    arnette64 likes this.
  18. Feb 14, 2020 at 1:09 PM
    adrtoy
    adrtoy New Member
    That's correct.
  19. Feb 14, 2020 at 3:27 PM
    Defend_Pono
    Kupono
    Oahu, Hawaii
    Again, really appreciate the help! Thank you!
  20. Mar 12, 2020 at 7:20 PM
    Defend_Pono
    Kupono
    Oahu, Hawaii
    Finally got my aftermarket TRD Pro grill on my 2020. Havent had the chance to take a good picture yet but will take some asap. So if any of you 2020 owners have questions, feel free to ask.
  21. Mar 13, 2020 at 4:19 AM
    adrtoy
    adrtoy New Member
    Did it require the same fitting as the OEM one did?
  22. Mar 15, 2020 at 7:34 PM
    Shadoww
    Shadoww New Member
    2020 ORP
    Are you able to share the part numbers for the 2020 Pro grill?
  23. Mar 15, 2020 at 7:53 PM
    Sundy
    Sundy New Member
    Ryan
    Co Springs
    2019 4Runner TRD ORP
    If anyone is doing this and buying a kit for the cheaper upper and an OEM garnish, we could maybe work something out and I'd buy just the garnish from you. I have one but it was painted, looks like crap, and need to either repaint regularly or replace with a non-painted one.
  24. Mar 15, 2020 at 10:29 PM
    celaw309
    celaw309 New Member
    Chris
    2020 MGM TRD ORP
    PZ323-35058 Garnish $287.92
    PZ327-35056 Upper Grille $113.59
    $401 for OEM from Toyota
    4RunnerRegina, arnette64 and Shadoww like this.
  25. Mar 16, 2020 at 4:33 AM
    Shadoww
    Shadoww New Member
    2020 ORP
    Thanks!
    celaw309 likes this.
  26. May 5, 2020 at 9:30 PM
    4RunnerRegina
    4RunnerRegina New Member
    Nina
    2020 Toyota 4Runner TRD off-road
    I have a 2020 TRD off-road, will these parts work to swap my stock grill to the pro grill with the safety sense? I’ve been trying to find an aftermarket pro grill for my 2020 off road but haven’t seen any come out yet. Help pleeeease!☺️
  27. May 5, 2020 at 10:04 PM
    celaw309
    celaw309 New Member
    Chris
    2020 MGM TRD ORP
    Sure will! That’s exactly what I did with my 2020
  28. May 6, 2020 at 4:08 AM
    Silverghost
    Silverghost New Member
    2020 venture
    Trd pro grill, Trd skid plate, trd led foglamps, trd exhaust, led hi and low beam headlights, full led interior lights, raptor grill lights, eibach lift kit, rsg sliders, falken wildpeak 275 tires, oem black hood scoop, tinted windows. More to come
    I'm not sure what you guys are cutting or modifying. I have a 2020 venture with safety sense. Bought the oem trd pro grill and installed it with no cutting or modification, it's a simple take off old grill put on new grill. Very easy swap there is nothing to modify. The piece with toyota letters just pushes on over your factory center beam and sticks with the installed 3m tape. Doesn't interfere with safety sense panel at all. Fits perfect.
  29. May 6, 2020 at 4:20 AM
    adrtoy
    adrtoy New Member
    We're using the pre 20 setup.
  30. May 6, 2020 at 5:16 AM
    celaw309
    celaw309 New Member
    Chris
    2020 MGM TRD ORP
    The 2020 TRD Pro grille has a notch cut out for the safety sense sensor whereas the pre-2020 TRD Pro models did not have the sensor and if you attempted to add to a 2020 model it would not sit flush and you would have to cut out a notch.
    Schijff749 and travelinscout like this.
