2019 MGM SR5 Build
Discussion in '5th Gen 4Runners (2010-2024)' started by Audio_Connect4R, Jun 7, 2019.
  1. Jun 7, 2019 at 11:51 PM
    Audio_Connect4R
    Audio_Connect4R [OP] New Member
    2019 MGM SR5 4Runner
    I've had the 4Runner for about three weeks now but have been ordering parts for many weeks prior to picking her up. Finally got some time to do work on her this weekend. A little back story on this. I am from Northern California but I am down in Orange County visiting friends, one of whom I used to work on cars with many years ago. He is an ex-FJ owner, so this was fun for him (I think). Obviously this is still a work in progress.
    Some of the boxes (6/6/19)
    old SR5 wheels and tires in the background with my 285/70/17 Ko2's up front
    The before shot of the factory front driver side suspension.
    Total Chaos spindle gussets front and back shots after they were welded and before they were coated with VHT enamel. Welding was done by Demello-Offroad in Corona, Ca.
    The after shot of the factory front driver side suspension. Parts below:
    FACTORY RACE SERIES 2.5 COIL-OVER IFP SHOCK (883-02-025)
    Total Chaos Urethane UCA's (#96504)
    Total Chaos weld on spindle gussets w/ sway bar mounts (59698-SB)
    Finished for now. For some reason I wasn't thinking about rear shocks. Need to order Fox Performance Series 2.0 Smooth Body IFP Shock (980-24-679). Currently have Cornfed 1" spacer in the rear. Currently on order, Demello Offroad Hybrid Sliders.
    Other than the rear shocks and sliders, my next big project waiting for me is the Stereo system upgrade. That I will have tons of pictures of.
    Here are pictures of this weekends work (6/7/19). Wheels are Method Race Wheels 315 in 17x8.5 w/ 0 offset
  2. Jun 8, 2019 at 5:14 AM
    ForRun
    ForRun 4Runner
    2020 orp
    Very cool, nice touch!
  3. Jun 8, 2019 at 6:46 AM
    WallyT4R
    WallyT4R New Member
  4. Jun 8, 2019 at 6:50 AM
    Nice build!
    What spring rate did you go with on the Fox coilovers? How do they ride?
    Strandskov likes this.
  5. Jun 8, 2019 at 7:14 AM
    Audio_Connect4R
    Not sure on the spring rate. Fox uses adjustable 3.0 Eibach® racing springs. The ride is good so far. Nose dive gone and not getting tossed around on "rougher" city roads.
  6. Jun 14, 2019 at 3:24 PM
    danssr5
    danssr5 New Member
    Dan
    2017 sr5 premium 4x4
    Did you adjust the coil-over or put it in with factory preset settings?
  7. Jun 14, 2019 at 7:33 PM
    PaulB-2006 T4R
    PaulB-2006 T4R New Member
    Paul
    Twin Cities, MN
    2016 Trail MGM
    Falken Wildpeak AT3W. Matte Black TRD Wheels. Leveled with 2" spacer. All LED interior. Mud flaps deleted. TRD Air Filter. TRD Oil Cap. Heated Front Seats. FJC Shifter. Subaru Kicker tweeters.
    Nice start and you have a good friend.
  8. Jun 14, 2019 at 9:19 PM
    Audio_Connect4R
    Stupid me just realized there was a "5th Gen Builds" section on the forum. Whoops!
  9. Aug 2, 2019 at 8:25 PM
    Audio_Connect4R
    Driverside engine bay (Firewall)
    Apex Overland electrical mounting plate. Currently housing the inline fuse for the audio system amplifier. Will add Spod relay box
    here in the future.
    Peerless 830667 8" woofers in the front factory door location. Doors and door panels are treated with sound deadening material
    AudioControl D-6.1200 amplifier mounted under the passanger seat. The 6 channels will drive the Peerless 8" woofers, Audison Voce AV3.0 (3" midrange) & AV1.1 (1" tweeter)
    The audio system wiring is by MIT Cables. Styleline 8 RCA interconnects and Styleline 9 Speaker cables. Out of the amplifier are short (6") 16gauge speaker wire to barrier strips (as shown below) and ran to the speakers.
    Kenwood Excelon head unit
    IMG_6879.jpg Soon to come, pictures of the custom fiberglassed A-pillars for the tweeters.
  10. Aug 2, 2019 at 9:16 PM
    Audio_Connect4R
    Originally put them in at factory setting and drove around for 2 days, then cranked up the coilovers 2 full turns and went for an alignment.
  11. Sep 7, 2019 at 12:03 AM
    Audio_Connect4R
    The holes in the A-Pillar were a quick solution for my tweeters before I drove down to Orange County from Northern California to work on the A-Pillars with my friend.
    We used the original holes as a guideline to mount the ABS plastic mounting surface with wooden dowels.
    We ended up using an old tshirt as the fabric to shape the tweeter pod using super glue to hold in place while we used fiberglass resin to harden the mold.
    First pass with fiberglass resin. Set them out in the sun in hopes of speeding up the curing process.
    Test fit for clearance.
    Sanding the pillars prior to using bondo to contour.
    Applying Bondo
    Bondo Curing
    Sanded down and almost ready to primer, texture and paint.
    3 step process (L-R) Flat white Primer first, Carribean Sand Texture, then finally satin Stone Gray to match as best as possible.
    All primer, texture and paint by Rust-oleum.
    The texture used, if you are wondering.
    Applying primer
    First fit with tweeter installed (Audison Voce AV 3.0)
    Passanger side fit.
  12. Sep 7, 2019 at 6:44 AM
    guhner123
    guhner123 New Member
    Guhner
    2019 TRD OR T4R
    Stock...for now...
    Looking good! Those spindles are beefy!!
  13. Sep 11, 2019 at 9:09 AM
    danssr5
    danssr5 New Member
    Dan
    For your stock roof rack. Did you paint the end caps? If so what did you use?
    Thanks!
  14. Sep 12, 2019 at 8:23 PM
    Audio_Connect4R
    It's for a better imaging. A good soundstage and tonality are huge components of sound quality in my book. So yes, I would definitely say it's for better sound quality! :)
    4Runner fun likes this.
  15. Sep 12, 2019 at 8:25 PM
    Audio_Connect4R
    I did not touch the stock roof rack, that's exactly how it came from the dealer. Shortly after the lift, I ordered my Gobi Stealth rack and today was the mark of my 12th week into my order. I am going to sell the factory roof rack with crossbars once the rack arrives. If you know anyone that is interested.
  16. Sep 12, 2019 at 10:10 PM
    4Runner fun
    Ryan
    Nebraska
    Beautiful truck & build!
    I wish I had those skills.
    You could sell those pillar pods if you have the time...
    Top notch!
    jgcaps and Audio_Connect4R[OP] like this.
  17. Sep 22, 2019 at 8:46 AM
    Audio_Connect4R
    Thank you for the comment! I wish I could take the credit for these A-Pillars, but I simply was the tool grabber for my friend. lol. Now I wish I had done a video log of how he did it, for those who might want to try it out.
  18. Oct 21, 2019 at 7:52 PM
    Audio_Connect4R
    Mounted the Gobi Stealth rack this weekend. Joined in on the RCI group buy and got the full skid package and gas tank skid in steel, hopefully I'll find time to install those soon. Gobi 1.jpgGobi 2.jpg
    4runGirl88, jgcaps and nimby like this.
  19. Nov 3, 2019 at 6:41 PM
    Audio_Connect4R
    Installed some RCI skids in powdercoated steel.
    Before picture:
    After pic (Full skid package):
    Gas tank skid:
  20. Feb 12, 2020 at 7:44 PM
    Audio_Connect4R
    Factory upper vs. Total Chaos upper
    Factory panhard vs Total Chaos panhard
    I forgot to get a picture of the factory lower link vs. the Total Chaos lower link, but here is a picture installed.
    Another picture of the Total Chaos lower link with an RCI link skid.
    Total Chaos panhard installed.
    Total job took about 2.5-3 hours to do. Some of those nuts and bolts were a pain in the ass to get to.
    4Runner fun and WallyT4R like this.
  21. Apr 12, 2020 at 1:46 PM
    Audio_Connect4R
    Weather finally cleared up for me to install the bumper, but had a big of an issue with the winch and fitment (my misunderstanding). Trying to get that situated then I can pull the bumper and mount the winch.
    Demello Off-Road bumper
    Baja Designs Squadron Pro lights
    Tactical Recovery Equipment Safety Thimble Fairlead.
    Up next:
    Motoalliance Viper 13,000lb winch (replacing the Motoalliance Viper 12,000 that doesn't fit. lol)
    Tactical Recovery Equipment Safety Thimble II
    Victory 4x4 rear bumper with tire swing out (So I can finally take the damn spare off of the roof!)
  22. May 10, 2020 at 2:52 PM
    Audio_Connect4R
    Projects for the past 2 weekends.
    Finally got the winch situated. Motoalliance Viper 13,000 winch:
    Installed and wired. Also moved the Baja designs Squardron Pro's onto Rago Fab ditch light brackets and put Acro Lights in the Demello front bumper foglight location. Tactical Recovery Equipment Hawse Fairlead and Safety Thimble II.:
    Victory 4x4 rear bumper with swingout install:
    Things are masked off and ready for the cut.
    Cut has been made:Bumper Cut.jpg
    Bumper installed and spare tire on the swing out. Rear:side passanger with bumpers.jpg
    Rear:side w: bumper.jpg
    Side w:bumpers.jpg
    Next planned upgrades:
    1) Nitro 4.56 gears installed by YotaMasters in a month or so. (ordered)
    2) Relocating rear differential breather into engine bay. (waiting on 1 part)
    3) Rokblox mudflaps. (ordered)
    4) Rear Toytec 2.5" lift springs. (ordered)
    5) Mean Green high output alternator. (ordered)
    6) Install new subwoofer (going from Audison 10" standard rectangle box to a Image Dynamics 8" in custom ported fiberglass enclosure). To be installed on next trip to Orange County
    Near Future upgrades:
    1) Wheelers Offroad front/read Super Bumpstops.
    2) Clazzio Napa Leather seat covers.
    3) Victory 4x4 driverside swing out with Rotopax Carrier.
    4) Rotopax fuel and water storage and locking mounts.
    5) Remove the Gobi rack to get the roof vinyl wrapped.
    6) Possible move from 285/70/17 to 295/70/17
  23. May 10, 2020 at 3:13 PM
    2A4R
    2A4R New Member
    Northern VA
    19 4R TRD PRO
    Hey man, your build looks sick!
    I've ordered my Gobi and just waiting for it to come. Just curious, why are you looking to get your roof wrapped?
  24. May 10, 2020 at 3:21 PM
    Audio_Connect4R
    Thank you! It's just precautionairy. Sun still bleeds through the rack grid and I live in city with tons of trees. So hoping the wrap will keep the paint on the roof from being warn down by the elements and sap. You're going to love that roof rack! Well worth the wait. I will say though that the accessories, like a high lift jack mount also carries the same wait period as the rack. So order whatever rack accessories you want if you can. I've been waiting since the middle of Feb for my high lift jack mount.
    El General***** and 2A4R[QUOTED] like this.
  25. May 10, 2020 at 3:27 PM
    2A4R
    2A4R New Member
    Northern VA
    19 4R TRD PRO
    Thanks man that's not a terrible idea. Yea I placed my order in the beginning of January. I understand the wait for a made-to-order rack, but for a simple accessory? That's crazy. They sell the tie downs for the rack..do you really need theirs or will any ratchet straps work?
  26. May 10, 2020 at 3:34 PM
    Audio_Connect4R
    Yea, I was a little dumbfounded with the wait for the accessories. I would think with how little material (compared to the roof rack) and how I would imagine a "Stealth series" or "Ranger series" accessory would work regardless of the car and having those things on the shelf would be beneficial to ship out right away. But oh well, the rack was well worth the wait. I was using 1.5" rachet straps I got from Home Depot to tie down my spare while I searched for what rear bumper and swing out I wanted, they held up perfectly. I think their tiedown kit gives you a cleaner connection point to the rack.
    2A4R[QUOTED] likes this.
  27. May 10, 2020 at 6:53 PM
    2A4R
    2A4R New Member
    Northern VA
    19 4R TRD PRO
    Also, what window deflectors do you have? They're nice and slim and streamline.. hardly noticed they're there
  28. May 10, 2020 at 7:41 PM
    Audio_Connect4R
    Weathertech
  29. May 14, 2020 at 7:33 AM
    Audio_Connect4R
    Have you been in touch with anyone from Gobi lately? Ive sent a few contact emails regarding my orders and nothing. And I never got a call to confirm an order I made 2 weeks ago. I wonder if they are closed due to COVID.
  30. May 14, 2020 at 8:50 AM
    2A4R
    2A4R New Member
    Northern VA
    19 4R TRD PRO
    I actually got an email earlier this week saying my rack was done and being turned over to the freight company. (Ordered it in early Jan)
    El General***** likes this.
