2019 4runner Check Engine+Multi-terrain+Select indicator warning lights
Discussion in '5th Gen 4Runners (2010-2024)' started by HugoAvenTRD, Jul 15, 2021.
  1. Jul 15, 2021 at 11:44 AM
    HugoAvenTRD
    HugoAvenTRD [OP] New Member
    Hugo
    2019 White 4runner
    Hi, I'm new to the forum. I need help, has anybody had this issue? Not sure where to look. I was told that it's the gas cap. These lights came on after I got an oil change and a flat repaired.
    Lights: Check Engine/ Multi-terrain select indicator/ Atrack indicator.
    Thank,
  2. Jul 15, 2021 at 11:48 AM
    Dillusion New Member
    KYle
    Yeah thats not the gas cap.
    I think they might of whacked a sensor when they pulled the tire off for repair.
    Slopemaster, Thatbassguy and Mtbpsych like this.
  3. Jul 15, 2021 at 11:49 AM
    HugoAvenTRD
    Hugo
    2019 White 4runner
  4. Jul 15, 2021 at 11:50 AM
    HugoAvenTRD
    Hugo
    2019 White 4runner
    Humm...never thought It could be a tire sensor issue. I look into that.
  5. Jul 15, 2021 at 12:08 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    An OBDII dongle+phone app or separate scanner will display the DTC codes.
  6. Jul 15, 2021 at 12:14 PM
    HugoAvenTRD
    Hugo
    2019 White 4runner
    Thanks for your feedback! All help is welcomed.
  7. Jul 15, 2021 at 12:23 PM
    I got those same lights on not long after buying my new 4R. Turned out it was a rodent-chewed injector wire. Just a thought...might be worth checking out, and just coincidence that it happened when you had the other work done...
    Thatbassguy and HugoAvenTRD[OP] like this.
  8. Jul 15, 2021 at 12:28 PM
    Waraba
    Waraba New Member
    2018 TRD OffRoad
    I had a flat fixed a couple of years ago on my 2018 TRD OR, and they destroyed the TPMS sensor. I didn't have those same lights. In my case just the TPMS light came on. Not saying your symptoms aren't the TPMS sensor. Just saying my symptoms were different.
    HugoAvenTRD[OP] likes this.
  9. Jul 15, 2021 at 12:42 PM
    HugoAvenTRD
    Hugo
    2019 White 4runner
    Exactly, what I said - but of course the Mechanic/Tire shop wont own up to it.
  10. Jul 15, 2021 at 3:50 PM
    KYle
    I guess we should start from when you picked it up.
    Were the lights on when you got it back or came on after? If they were on when you picked it up you should of never taken it back.
  11. Jul 15, 2021 at 4:03 PM
    Bonitobob
    Bonitobob New Member
    06 V8 Sport
    Not under warranty?
  12. Jul 15, 2021 at 4:47 PM
    HugoAvenTRD
    Hugo
    2019 White 4runner
    No, the lights turned on after I picked it up. I parked the truck at work, and when I came back for lunch is when they turned on after turning it on.
    ps: update. Called Toyota and apparently my truck YR/MODEL has a recall. Dropping off at Toyota in the morning. Free repairs thank goodness! Crossing my fingers.
    Toy4X4 likes this.
  13. Jul 15, 2021 at 5:04 PM
    KYle
    Its probably the fuel pump recall. Unless they told you its specifically for the lights.
  14. Jul 20, 2021 at 11:49 AM
    HugoAvenTRD
    Hugo
    2019 White 4runner
    So, got the issue repaired. Lights were indeed the gas cap. Also, got my recall taken care of and yes it was the fuel pump. That being said, all codes are off now and back to normal. Thank you everyone!
    raimieb and Toy4X4 like this.
  15. Jul 21, 2021 at 7:39 AM
    Odin4R
    Odin4R New Member
    Boston, NY
    2018 Blizzard Pearl Limited
    Brakes upgraded to PowerStop
    I had the same issue yesterday on my 2018 Limited. Took the gas cap off and re-installed - problem resolved..... Thanks!
  16. Mar 5, 2024 at 4:00 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    I just had this issue today. Going to check wires tomorrow under the hood.
  17. Mar 5, 2024 at 4:00 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Tried a new gas cap today and seems to have helped. Could be anecdotal bc I am an optimist. Will hope it's not there tomorrow.
