2018 Limited Nav Questions
Discussion in '5th Gen 4Runners (2010-2024)' started by IDC03, Aug 11, 2018.
  1. Aug 11, 2018 at 3:56 PM
    IDC03
    IDC03 [OP] New Member
    Ira
    '03 4runner SR5 4WD V8
    None.
    How well does nav system work in the new 4Runners? Is it simple to use & reliable?
    Thanks for answering my questions!
  2. Aug 11, 2018 at 4:06 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Extremely simple nav and I would say 99% accurate. I rarely get random errors but typically it's with newly build roads.
  3. Aug 14, 2018 at 6:50 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    there are times when the NAV screen is blank no roads as I drive on the same hywy.. then the road comes back . weird but my wife with the cell phone had the road on her screen..data of the software must have defects .where I live I had no problems but in other states it does this sometimes for a few miles.
  4. Aug 14, 2018 at 10:17 AM
    IDC03
    Ira
    None.
    I thank you both for your comments.
  5. Aug 14, 2018 at 5:27 PM
    Grumpy Uncle
    Grumpy Uncle New Member
    Pat
    2018 Limited MGM, hers. 2016 Tundra CM BLK, mine
    Grey TRD Wheels, Nitto Terra Grapplers, 3"Toytec Eibach
    My wife has had no problems with hers. Matter of fact it got me through Denver pretty well.
  6. Aug 15, 2018 at 4:15 PM
    TN_FunRunner
    TN_FunRunner Custom Title
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    I haven’t had any problems with mine. Very easy to use
  7. Sep 24, 2018 at 3:47 PM
    Sparkkky
    Sparkkky New Member
    2018 4 Runner TRD Off-road
    Eiback Pro lift, ARB Summit bumper, Smitty Bilt wench, Summit flood LED
    You cannot set a destination while you are moving safety design.
    j cat likes this.
  8. Sep 24, 2018 at 7:35 PM
    4runningMan
    4runningMan New Member
    New Mexico
    If you zoom out, the roads might show up. Errors are more likely to show up the further in you are zoomed.
  9. Sep 25, 2018 at 6:36 AM
    j cat
    j cat New Member
    massachusetts
    I actually did turn off nav then turned on nav and same deal road was missing as I was on the same road for many miles.
    then suddenly the road began to appear again .. screen not blank only the road I was on was gradually disappearing then after several miles the road gradually came back .. data dead spot on Toyota nav programing.. North Carolina
