2018 4runner helper springs or air bag
Discussion in '5th Gen 4Runners (2010-2024)' started by Maisie, Mar 24, 2021.
  1. Mar 24, 2021 at 10:07 AM
    Maisie
    Maisie [OP] New Member
    2018 Grey 4Runner
    Hello, I wish to put helper springs on my 2018 4runner and need some advice on the best way and some manufacturers of these products. I will be towing a small camper and when it is attached the back end goes down. As i think this is a bad thing i would like to add these extra spring to help the car along. Thanks
  2. Mar 24, 2021 at 10:11 AM
    Mtbpsych
    Mtbpsych New Member
    Air bags would be best in my opinion if you don’t want to deal with lifting the vehicle.
  3. Mar 24, 2021 at 10:49 AM
    Maisie
    2018 Grey 4Runner
    OK thanks which mfg. would you suggest and can you install them yourself?
  4. Mar 24, 2021 at 11:07 AM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    I did Air Lift air bags. Mainly because I wanted to keep the stock ride height when I tow stuff and it keeps the headlight aim good.
    And the install was easy enough to do.
  5. Mar 24, 2021 at 12:34 PM
    Maisie
    2018 Grey 4Runner
    thanks for the help do you need an air compressor system for this.
  6. Mar 24, 2021 at 4:24 PM
    alittleoff
    Steve
    406
    '16 TP
    A small 12 volt portable would be all you need. Or some air from a gas/convenience station/store.
    Even a bicycle tire pump would do the trick, since you're only going from 5psi unloaded to 30psi loaded.
  7. Mar 25, 2021 at 5:40 AM
    Maisie
    2018 Grey 4Runner
    thanks guys i am going shopping!!
