2018 4Runner headlight problem
Discussion in 'Lighting' started by 4Runner1105, Dec 28, 2024.
  1. Dec 28, 2024 at 6:19 PM
    4Runner1105
    4Runner1105 [OP] New Member
    2018 4runner
    New to the 4runner family ! Could someone please tell me why my headlights look like this ? IMG_4599.jpg IMG_4600.jpg IMG_4599.jpg IMG_4600.jpg
  2. Dec 31, 2024 at 8:45 AM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    Looks like moisture intrusion.
  3. Jan 2, 2025 at 6:35 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I agree -moisture inside somehow.
    Remove bulb holders and perhaps carefully remove bulbs with new clean rubber glove, place in a safe spot off truck.
    Blow air into bulb holder openings on backside of headlamp fixture
    I would use a camp style air mattress electric air pump. Either 12vdc or 115vac (Usually $20 at Big 5). They usually come with a small hose and various tips.
    Then blow air in larger volumes. Make sure air has discharge/leaks to outside to purge moisture out.
    Do this on a warm sunny day.
    Inspect carefully for source of moisture entry.
    Has the engine been washed?
  4. Jan 2, 2025 at 6:58 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Just moisture intrusion. Unfortunately this is pretty standard for aftermarket headlights. This is one reason I've stuck with OEM.
    But, with a 2018 that had the old halogen style lights, going back to OEM might be a big downgrade for you though. Unfortunately good aftermarket headlights cost a ton... Still, I've heard great things about Morimoto
