2016 TRD Pro Engine Whine
Discussion in '5th Gen 4Runners (2010-2024)' started by jmh77, Mar 14, 2019.
  1. Mar 14, 2019 at 4:05 PM
    jmh77
    jmh77 [OP] New Member
    2016 4Runner TRD Pro
    Hello, new to the forum... hoping for a little insight into a recent concern with my 2016 4Runner TRD Pro. Bought the 4Runner new back in '16... it's been absolutely perfect with no issues. Then, all of the sudden, about a month ago it developed an engine whine. It started almost as if with a flip of switch... there was no gradual worsening... it just appeared one day while driving home from work. The "whine" is consistent with RPMs and seems to be coming from the passenger side of the motor. I removed the belt and ran the motor briefly to rule out any pulleys, etc... Still no change. I also did an oil change just to see if there was a difference... nope. Also no change with outside or operating temps. So... Took it into Toyota and they gave me the standard dealer answer... "Uhhh, we think it's 'kind of' normal". My response being... "how could it be normal if it was silent for 3 years and now it whines?" They shrugged. It's really quite annoying... almost to the point I want to trade it. I compared it to several other 4Runners... some were dead silent, and one or two you could kind of hear a slight whine... but definitely not as loud as mine. So, I returned to the dealership... The service writer and tech. both agreed it was loud. I came back at the end of the day to pick it up and once again... they blew it off saying they didn't really feel it was a concern. But, this time... the tech. told me that he thinks it's the transmission oil pump but they didn't seem too inclined to investigate further. So, that's where I'm at... I love my 4Runner but I'm left with just turning the radio up. Can anyone offer any ideas? Is this normal? At what point do I call Toyota corporate? Thanks in advance for any help!
    toy33 likes this.
  2. Mar 14, 2019 at 4:18 PM
    4buggy
    4buggy Relapsing mod addict
    2019 4Runner pro MBM
    Whine or whistle? I assume you would have noted that you had an aftermarket or not original air intake. After trading my tacoma with a whistle at certain rpms, with a K&N intake, I tightened every new connection and looked for holes ANYWHERE air may be drawn to make that noise, with no fix, even when I let it go. So where I’m going with this is, check all clamps, openings, gaskets, and/or filters in your intake, that’s what I would do on my end.
  3. Mar 14, 2019 at 4:26 PM
    jmh77
    Thanks. Definitely a mechanical “whine”, not a whistle. And yes, stock intake... everything is sealed and tight. One would assume an idler pulley or power steering pump... it’s that type of noise. But, I ran the motor briefly with no belt to rule out pulleys, accessories, etc. It sounds internal. I’m still under warranty... but they don’t seem to want to investigate further even though they agree that it’s a loud, irritating whine.
  4. Mar 14, 2019 at 4:29 PM
    4X4Runner
    The left coast
    I’d keep taking it back and not settle with the “normal” response from them. Maybe take it to another dealer service department
    WallyT4R, 4buggy and HoBoDanny like this.
  5. Mar 14, 2019 at 4:29 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Take it to another dealer if yours won’t look into it.
  6. Mar 14, 2019 at 5:16 PM
    Firefly21
    Firefly21 New Member
    Duane Frazier
    18 off road premium trd
    Hid lows 3500 drl / high Led interior Led reverse Led oem fogs Sequential blinker Trd intake Unifilter pump mod Apex recover points BF Goodrich KO2 (matching trd spare) Kicker front tweeters Tvd overlays S2 yellow wide fogs Apex black sequential rear tails Cartrim home blue convex mirriors
    Front diff needle bearing?
  7. Mar 14, 2019 at 6:33 PM
    4Runner_Patrick
    4Runner_Patrick New Member
    2023 TRD PRO Black
    Try switching into 4WD and see if it still whines...the needle bearing is in that area you describe.
  8. Mar 14, 2019 at 7:23 PM
    WallyT4R
    WallyT4R New Member
    Call Corporate now. Your dealer is giving you the run around
    KSJ08 likes this.
  9. Mar 15, 2019 at 7:20 AM
    Hyper15125
    Hyper15125 Headlight Retrofitting Hobbyist
    NJ (609)
    ‘14 SR5 T4R, ‘13 Taco TRD Sport DCLB, ‘02 SC430
    Wife’s 4Runner does the same thing but its not all that loud. Sounds similar to an alternator whine in a stereo system with a ground problem, thats my best description.
    GJ4R and HoBoDanny like this.
  10. Mar 15, 2019 at 8:49 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    :rofl:I read that all wrong
    peter2772000 and WallyT4R like this.
  11. Mar 15, 2019 at 12:43 PM
    jmh77
    Thanks guys. I tried the 4WD... no difference unfortunately. I’m pretty certain the tech. might be right... it does sound as if it could be the oil pump. I just can’t get my head wrapped around why one day it’s silent, and the next it’s whining... and the dealership just shrugs. I wish I knew what is considered a “normal” sound. But seems I’m going to have to make that call to Toyota.
    WallyT4R likes this.
  12. Mar 15, 2019 at 2:57 PM
    4Runner_Patrick
    2023 TRD PRO Black
    Sorry to hear. At my dealer they have only 1 tech who had the knowledge to fix mine. He keeps it running like new.
  13. Aug 10, 2019 at 8:07 AM
    brownersd
    Sean
    Humble / Kingwood, Texas
    Hey hey all,
    I noticed the same noise with my '19, and was speaking with the head tech at my dealer. Evidently there is an air pump that pumps air into the engine, and this is what we are hearing and it is normal. It is the same noise you hear when turning off the vehicle, of the system purging. I was starting to worry that something was wrong too, but this is done as a part of the whole ECO process that everyone is jumping on now... I hope this helps...
  14. Feb 1, 2020 at 5:41 PM
    Getsum
    Getsum New Member
    17 TRD ORP
    Hi OP,
    Any follow-up info on your issue? Il add another case of this "whining noise". Same scenario, about 2.5 years (20k miles) after i bought my vehicle brand new it suddenly developed a whining noise. It's happens while accelerating over 1500 rpms. 1st dealer replaced idler pulley then alternator before declaring it a normal sound. Im still under warranty but not sure how far i want techs taking apart my fairly new vehicle. The sound is distinct. It reminds me of a failing power steering pump or (glass half full) a working supercharger
  15. Jun 1, 2020 at 6:09 PM
    MITCHL_D
    MITCHL_D New Member
  16. Jun 1, 2020 at 7:13 PM
    Getsum
    Getsum New Member
    17 TRD ORP
    Unfortunately I have not. Just learned to turn the music up and deal with it.
  17. Jun 1, 2020 at 8:28 PM
    Interesting. I've noticed a whine on occasion as well, usually during moderate acceleration.
  18. Jun 1, 2020 at 8:32 PM
    MITCHL_D
    MITCHL_D New Member
    I just spoke to a fellow 5th gen owner who had the exact same problem. He said he narrowed the issue down to a faulty bearing in a sprocket. The part number is 13530-31021.
    He said he had the dealership fix it and it was a pretty major job pulling the engine apart due to some other mods he had. They couldn't clearly identify it with the other accessories installed so it become a bigger process of elimination. Due that they replaced other components prior to finding the sprocket.
    He added in hindsight, he'd just live with the sound and just ignore it as it wasn't a dangerous / risky issue longterm problem.
  19. Jun 1, 2020 at 10:25 PM
    4Runner22
    4Runner22 New Member
    2019 VooDoo Blue 4Runner TRD Pro
    Mine whines too but its coming from the front passenger seat. The only way to fix it is to give it something to eat.
    Tmiesowicz, wfxt, 2Toys and 11 others like this.
  20. Jun 2, 2020 at 11:40 AM
    Getsum
    Getsum New Member
    17 TRD ORP
    Anyone gonna try this fix? That's alot of work to do and not be certain it will fix the noise. I will look into it when it comes time to service the chain. You would be hard pressed for a dealership to replace under warranty. Is there a test that can be done to 100% verify it is this sprocket?
  21. Jun 2, 2020 at 2:38 PM
    Bgdv1
    Bgdv1 New Member
    Dave
    Butler
    2014 SR5P
    Dangerous
  22. Jul 11, 2020 at 12:11 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    I have this exact same noise. Noise is related to engine RPM, not load. Higher the RPM, higher the whine.
    GJ4R and James P like this.
  23. Jul 11, 2020 at 5:33 PM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    Murphy’s Law states that all will be evident when the warranty expires. Or, in the corollary, all will become evident the further you are from civilization when it fails.
    Moon Landing and peter2772000 like this.
  24. Aug 1, 2020 at 7:45 AM
    Vori75
    Vori75 New Member
    2017 TRD OFF-ROAD
    New owner of a 2017 TRD OFF-ROAD 38k miles I was very excited since Ive been wanting this rig for a while. Sadly ive noticed this whine Ive been asking around some people say is normal but it’s loud it’s like failing power steering pump sound. I traded in an Escalade because I wanted some reliable this worries the heck out of me. Right I’m sitting at the dealership to see what excuse do I get. They sold me this not even 2 weeks ago and it was supposed to be fully inspected but ya know how that goes.
  25. Aug 1, 2020 at 8:59 AM
    Oldtoyotaguy
    Bummer, the good news is that it is not normal and can be fixed. Since you caught it early, hopefully they will fix it on their dime. My 2018 ORP is dead quiet, as it should be. Yours will be too.
  26. Aug 1, 2020 at 11:38 AM
    Vori75
    Vori75 New Member
    2017 TRD OFF-ROAD
    Thank you sir! So do we know what is causing this on the 4Runners? And how bad could be?
  27. Aug 1, 2020 at 12:32 PM
    Vori75
    Vori75 New Member
    2017 TRD OFF-ROAD
    They replaced the idle pulley but the noise still there
  28. Aug 1, 2020 at 12:44 PM
    Oldtoyotaguy
    I don’t think it’s the subject of a technical bulletin, to my knowledge, so it’s not a condition that all 4 Runners have. It sounds like your dealer is crossing his fingers and trying to fix the cheapest possibility. Obviously, it didn’t work if the noise is still there. If they can’t diagnose the problem, take it to someone who can, and then get them to fix it. Even if you pay for the diagnosis yourself, it will be worth it. There are lots of good, knowledgeable, and honest mechanics around that can help you. Ask around, maybe someone on here lives in your area and can advise you who to take it to.
  29. Aug 1, 2020 at 1:41 PM
    upperleftadventureguy
    upperleftadventureguy 2016 SR5. PNW
    Shawn
    Oregon
    2016 Black SR5
    My 2016 whines, my buddies 2018 whines most 4Runners has that ‘whine’ it’s I’ve come to love it. It’s just like the Toya Knock
  30. Aug 1, 2020 at 3:53 PM
    Agent_Outside
    Built 2011 T4R Limited
    You have them now. Once there is a repair attempt made, legally they have admitted there’s a problem. Call Toyota customer care and tell them that they dealer acknowledged the problem and has tried to fixed it but they are unable.
    This is literally the reason service advisors try to blow off complaints, once they write it up and a repair attempt has been made all the legal power goes to the customer.
    Moon Landing, 2Toys and Thatbassguy like this.
