2016 T4R vehicle does brake dive
Discussion in '5th Gen 4Runners (2010-2024)' started by j cat, Jul 17, 2016.
  1. Jul 17, 2016 at 12:04 PM
    j cat
    j cat [OP] New Member
    massachusetts
    spacer lift front 1inch
    I have 500 mi on my T4R . did not like how the brakes worked when I picked it up on purchasing. sales guy says that is normal that the front brakes grab and the front end will drop down. so I took his word and tried like hell to adjust to the odd working brakes. push down on pedal no brake then a little more too much brake very hard to stop evenly. So since I have bled many vehicles of many sizes some 20 times bigger than this vehicle . I decided to bleed the brakes since that was my experience with braking systems on how to correct this issue.
    well the right rear passenger side caliper was full of air , lots of bubbles in the bleeder hose shooting out .
    the driver side good NO air. took for test run normal braking only a slight dip ..
    so if the brakes are like this bleed them.
    I was gonna bring it in , but it took me 15 min. max to do this , why spend a day at dealership to have them break something else .
    now I can say I am happy with it .
    topdec likes this.
  2. Jul 17, 2016 at 4:32 PM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    glad you found an easy solution!
  3. Jul 17, 2016 at 7:39 PM
    topdec
    topdec New Member
    2023 4R ORP CSM 2024 Sprinter AWD 2016 4R TE (sold)
    Thanks for the tip.
