2016 Full time 4 wheel drive
Discussion in '5th Gen 4Runners (2010-2024)' started by TurtleTagger, Sep 24, 2016.
  1. Sep 24, 2016 at 12:01 PM
    TurtleTagger
    TurtleTagger [OP] New Member
    2016 4Runner
    Hello. I just bought a brand new 2016 4Runner Limited. Also it's the first brand new vehicle I've ever bought. I'm new to Toyota vehicles but I have heard nothing bad about them. My 4Runner came with the full time four wheel drive transmission. I would like to know if anyone has had any problems and if there is any precautions I should take to make my vehicle run forever. Thanks for any of your suggestions you may have.
  2. Sep 24, 2016 at 1:01 PM
    TejasRunner
    TejasRunner New Member
    2024 4Runner Off-road Premium
    Which model 4runner do you have?
  3. Sep 24, 2016 at 1:16 PM
    TurtleTagger
    2016 4Runner
    2016 Toyota 4Runner Limited
  4. Sep 25, 2016 at 12:14 PM
    Relentless
    Relentless Offroad armor Fabricating beast! Vendor
    Eric
    Sparks NV
    05 Limited 4.7 V8, long travel, dual locked
    Lifted on 35s and Relentless Armored, too much to list!
    Should be good to go. Our 05 Limited AWD has 108k on it and gets taken off road regularly with no issues to the system. Just remember to unlock the center diff after you get done offroad to keep from binding in 4wd on pavement.
    TurtleTagger[OP] and jester243 like this.
  5. Sep 29, 2016 at 11:35 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    AWD vehicles require all tires to be rotated and be worn at the same exact amount. when all the tires are worn down all the tires must be replaced. rotate the tires often and make sure the tire pressures are correct TMPS will help tell you that.
    10K mile rotations and make sure the wheel alignment is correct.
    having a limited the spare will be the same tire . make sure that as well is properly at the same air pressure.
    since new have the front rear differential oils replaced at 10K miles. after that should be good for 80-100 k miles[breakin issue]
