2016 AC issues
Discussion in '5th Gen 4Runners (2010-2024)' started by beachT4R, Apr 7, 2021.
  1. Apr 7, 2021 at 5:13 AM
    beachT4R
    beachT4R [OP] New Member
    2016 Silver SR5
    When I press the button to turn on the AC on the dash the light turns on and blows cold air for 15 seconds then turns off and no more cold air. I had the dealer charge it last time I had a service appointment but that did not solve the issue. It's starting to get hot outside and I need to fix this issue somehow but cannot find the reason its not staying on. Does anyone have an idea of what to do here?
  2. Apr 7, 2021 at 7:48 AM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    Could be a bad pressure switch.
  3. Apr 7, 2021 at 10:31 AM
    Well if the dealer charged it and it gets warm again could be a leak also.
  4. Apr 7, 2021 at 10:34 AM
    beachT4R
    2016 Silver SR5
    good thought, I looked up the "symptoms" of that and them seem to be similar - I might try replacing the high and low switches
  5. Apr 7, 2021 at 10:36 AM
    beachT4R
    2016 Silver SR5
    I haven't noticed any leak under the car after being parked for awhile, I guess I could check around the compressor
  6. Apr 7, 2021 at 10:48 AM
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
    You're not going to see a refrigerant leak.....it's a gas. A dyed leak test is the only way to find those.
  7. Apr 7, 2021 at 10:58 AM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    You can try the DIY recharge kit with stop leak. I don't have much faith it would fix the issue, but I'd try it if it were my ride. I've used the other DIY recharging kits with the pressure gauges before and had success (with past rides), but I didn't have a leak either. The gauges are super handy though to prevent over filling your system.
    beachT4R[OP] likes this.
  8. Apr 7, 2021 at 11:42 AM
    beachT4R
    2016 Silver SR5
    This will be my first troubleshoot, hopefully it is that simple and not a larger issue
