2015 Battery Replacement Recommendation
Discussion in '5th Gen 4Runners (2010-2024)' started by ItsmeTee, Oct 3, 2022.
  1. Oct 3, 2022 at 8:56 PM
    ItsmeTee
    ItsmeTee [OP] New Member
    2015 Charcoal 4Runner
    What is the Toyota recommended battery for the 4Runner. Several Google searches come up with Die Hard or True Start. I also hear Interstate is a good one.
  2. Oct 3, 2022 at 9:06 PM
    I don't think you can go wrong with those 3. I thought someone had told me the OEM batteries were made by Diehard.
    ItsmeTee[OP] and wdsteven like this.
  3. Oct 3, 2022 at 9:28 PM
    The problem I’ve always had with aftermarket batteries is they start leaking after about a year.
    Wish we could get an original Panasonic replacement.
  4. Oct 4, 2022 at 1:12 AM
    Ramrod88
    Ramrod88 4Runner on Corolla budget
    New Orleans
    22 TRD OFF ROAD
    Exactly. The Panasonic is probably the longest life battery you'll have
  5. Oct 4, 2022 at 2:28 AM
    wdsteven
    wdsteven New Member
    The Duracell Batteries have come a long ways and they build a good quality battery with a excellent life span now, I have the Duracell batteries in my Boats same ones for 5 years now and in my Tundra for 3 years no issues.
  6. Oct 4, 2022 at 4:00 AM
    I've literally never had a battery leak, and I used to buy Walmart batteries. What kind of batteries are you buying, lol?
    Agreed about Panasonic, though. My '03 came with a Panasonic and it lasted about 170,000 miles and 10 years.
    ItsmeTee[OP] and brownersd like this.
  7. Oct 4, 2022 at 4:36 AM
    brownersd
    Sean
    Humble, Texas
    Totally agree. When the OEM battery usually dies or goes bad, I replace it with the Optima Gel Battery, just because they don't leak as well.
    Cheers,
    Sean
  8. Oct 4, 2022 at 6:24 AM
    Toyota Trustart, Interstate and now Oreilly’s battery. All leaked, guess I’m just a lucky guy.
  9. Oct 4, 2022 at 7:25 AM
    Weird.
  10. Oct 4, 2022 at 7:31 AM
    kmeeg LionRunner
    If I'm not mistaken per the testing some time back by "Project Farm" says Walmart batteries are better than some of the expensive options.
  11. Oct 4, 2022 at 7:36 AM
    It wouldn't surprise me. Usually store brand stuff is manufactured by name brand manufacturers. I've had very good luck with Cabelas and Bass Pro Shops store brand rods and reels. :)
    wdsteven, brownersd and kmeeg[QUOTED] like this.
  12. Oct 4, 2022 at 12:12 PM
    Curious on this because I’ve had a bunch of green stuff grow on terminals on previous old cars.
    When you had leaks, was it the green stuff/fuzz growing on the posts? Or was it a liquid leak of acid that ran down onto other metal?
    I found out the green fuzz happens when you have a bad ground strap. Turns out that’s what caused my problems, as my ground straps had corroded heavily and were coming apart.
  13. Oct 4, 2022 at 12:55 PM
    For demanding applications I like Odyssey batteries.
  14. Oct 4, 2022 at 1:06 PM
    Mainly just wet (acid) on top of battery. I use those treated felt washers under the contactor posts to help prevent battery terminal corrosion. I usually clean it up well before the battery terminals are effected.
  15. Oct 4, 2022 at 1:50 PM
    Ew, yeah, that’s bad.
  16. Oct 4, 2022 at 2:19 PM
    UncleShorty
    UncleShorty New Member
    My career in electrical engineering has taught me to buy the cheapest batteries that meet the OEM spec. Here in TX heat is death to batteries. So those long "guarantees" are meaningless. By the time the battery is three years old the warranty is pretty much worthless.
    There are only a few battery manufactures in the US. They brand every US made battery, die hard, interstate walmart.
    I buy the cheap ones, they last as long as the "premium" batts and are cheaper in the long run...
    Slopemaster and ElectroBoy like this.
  17. Oct 4, 2022 at 2:36 PM
    beedee
    beedee Member
    I just replaced my OEM Panasonic on my 2018 a couple weeks ago with an EverStart from Walmart. I don't live in a climate with extreme conditions, I usually hit the local SoCal mountains a few times in the winter. Thinking this should suffice. 3 year Warranty, I also uploaded a picture of my receipt to the My Purchases area of the Walmart app should anything happen when I'm out and about and need to warranty it.
    Trail Runnah and ItsmeTee[OP] like this.
  18. Oct 4, 2022 at 2:48 PM
    ItsmeTee
    Thank you, heading to dealer tomorrow to pick up windshield wipers and install myself that I ordered and got a discount on and had them free ship to the parts deparment. Saved about $18.00. I am going to ask them what they recommend and go from there. Most likely True Start. I will installing myself though. Funny, the battery is no longer available to order online thru Toyota.
  19. Oct 10, 2022 at 7:55 PM
    BallisticCoeff
    BallisticCoeff New Member
    Dave
    2015 SR5P
    None... yet
    I just replaced mine with a Super Premium MTZ Interstate AGM Battery. 1000CA 800CCA perfect for Montana winters!
  20. Oct 12, 2022 at 4:55 AM
    mac1usa
    mac1usa New Member
    What is a dealer replacement if Panasonic is not available?
  21. Oct 12, 2022 at 3:04 PM
    TN_FunRunner
    TN_FunRunner New Member
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    A Toyota Trustart battery. I can’t remember who actually makes it but it’s not Toyota. I think it’s a Johnson Controls battery but not 100% sure
  22. Oct 15, 2022 at 8:29 PM
    suaveflooder
    suaveflooder New Member
    Pretty much what I run. I’ve had zero issues so far.
    Trail Runnah likes this.
  23. Oct 16, 2022 at 9:59 AM
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
    I've only used Duracell for about 6 years now..........zero issues.
    wdsteven[QUOTED] likes this.
  24. Nov 30, 2022 at 5:16 PM
    This past Saturday my battery finally gave up the ghost, looking at it it's a Panasonic so it's most likely the original. Pretty good considering it's a 2013.
    My '07 Volvo actually did better, in early 2021 I replaced the original Volvo battery. I think those do really well because they're located inside the car, under the cargo floor. The guy at the auto parts store wasn't even surprised, said he sees a lot of old Volvo batteries come in.
  25. Nov 30, 2022 at 5:18 PM
    I'm literally watching the video right now, haha. I was just looking at batteries twice the cost, but I'm just going to go with $120 Walmart battery because it did so good in his testing.
    LuLu and kmeeg[QUOTED] like this.
  26. Nov 30, 2022 at 7:18 PM
    Wish we could get an original Panasonic. Most aftermarket batteries start leaking on me within a year. I’ve given up on the quest for “that” perfect battery.
