2015 4runner trd pro rear axel. questions
Discussion in '5th Gen 4Runners (2010-2024)' started by Douggy Tundra, Oct 1, 2024.
  1. Oct 1, 2024 at 12:07 PM
    Douggy Tundra
    Douggy Tundra [OP] New Member
    Erik
    2018 T4R Pro Calvery, And 2017 Tundra TRD Pro Cement
    Does anyone know if i can use the rear housing from a 2016 4runner sr5 to fix my pro rear housing. The end of the housing is bent. the axel is good and runs out straight. Just the housing is bent. A car ran up under the bumper and bent it. I do know that the part numbers are different at Toyota. I wasn't sure if I can modify the sr5 housing to work. I already have the sr5 housing in the back yard. Thanks for any help.
  2. Oct 1, 2024 at 12:08 PM
    2019 TRDP w/Kangs brah!
    You would need an axle housing from a locker equipped Runner because the 3rd members are slightly different to accommodate the locker mechanism.
  3. Oct 1, 2024 at 12:19 PM
    Douggy Tundra
    Erik
    So that means an axel from any of the trails, off roads or the pro's?
  4. Oct 1, 2024 at 1:49 PM
    Yes. Anything that has a factory locker.
