2014 SR5 running boards
Discussion in '5th Gen 4Runners (2010-2024)' started by kurtis2244, Jan 27, 2024.
  1. Jan 27, 2024 at 5:52 AM
    kurtis2244
    kurtis2244 [OP] New Member
    Kurt
    2014 4runner SR5
    3 inch lift
    I have a 2014 SR5 and looking at running boards I like. But it says they fit the following. Compatible with Toyota 4Runner 2010-2013 SR5 & 10-24 Limited & 19-24 Nightshade Edition. Is there a difference between a 2013 and a 2014 that these running boards wouldn't fit??
    APS Stainless Steel 6.5in Nerf Bars Pocket Steps Square Tube Rocker Guards
  2. Jan 27, 2024 at 6:38 AM
    If those are made for the models you listed, you wouldn't want them on your 2014 SR5. All those other models have rocker panels that hang down considerably lower than yours. If you mounted them, there'd be a pretty good gap between the step and the bottom of your rocker trim panel.
    2014 was the first year of the SR5 having rocker panels like the Trail model.
    This link has the same steps, and says these are compatible with your year:
    https://www.amazon.com/APS-iArmor-S...-1-2229-116-5&vehicleName=2019+Toyota+4Runner
  3. Jan 27, 2024 at 6:42 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
    Ok. Thank you very much! I'm new to this truck. Just got it and put a 3 inch lift with bigger tires and new wheels and am looking to customize more stuff. I'll have to do some more research. New 4runner.jpg
  4. Jan 27, 2024 at 6:49 AM
    I added a link to my post for what you're looking for.
  5. Jan 27, 2024 at 6:50 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
    I just saw that right now. Thank you so much for that. I appreciate all the knowledge you guys have about these 4runners!!!!
  6. Jan 27, 2024 at 6:51 AM
    The steps look the same as your initial post. It would be the mounting brackets that would be different.
  7. Jan 27, 2024 at 6:56 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
    So the mounting brackets on these would bring the running boards up closer to the rocker panels? What's the difference between my SR5 and a trail model
  8. Jan 27, 2024 at 7:06 AM
    Yes
    No difference at all as far as the rocker panels.
  9. Jan 27, 2024 at 7:08 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
    Ok. Thanks. I appreciate it. On another note...I can't figure out how to put a "picture" on my "profile". Drivin me nuts here.
  10. Jan 27, 2024 at 7:08 AM
    If anyone sells steps compatible with 2010 SR5, all years Limited & Nightshade, they will have mounting brackets that a!low the steps to hang down lower.
  11. Jan 27, 2024 at 7:13 AM
    Click 'You' in the upper right, then 'Personal Details'. On that screen is the option to add a photo to your Avatar,
  12. Jan 27, 2024 at 7:15 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
    Jesus....I'da never found that. Thanks
