2014 SR5 Dome Light Trigger Wire
Discussion in '5th Gen 4Runners (2010-2024)' started by Fourth_4Runner, Apr 11, 2019.
  1. Apr 11, 2019 at 9:34 PM
    Fourth_4Runner
    Fourth_4Runner [OP] New Member
    D
    2014 4Runner SR5
    Basically cosmetic. ICI Magnum step-boards, Plasti-dip front grill. Just got this one
    I recently purchased ICI Magnum Running Boards for my 2014 SR5 4Runner. These running boards come with LED lighting that needs to be tapped into the dome lamp trigger wire. For example, when the keyless entry is activated, the dome lamp and mirror lights will illuminate. Can anyone tell me what color wire and location controls this? All my wiring diagrams indicate a red wire, but none of them will trigger the light tester. There is one diagram that indicates blue/grey, but that sets off the horn. If you know what wire this is, please let me know so that I can attempt to finalize the install. Thank you.
  2. Apr 12, 2019 at 1:44 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    this may help
  3. Apr 12, 2019 at 2:01 PM
    4Runner fun
    Ryan
    Nebraska
    Boy how I wish 90% of that was not like trying to read Chinese!
    I truly envy those that have electrical abilities. Some of the dual battery setups I have seen on here & the attention to detail.
    I can wire in most accessories, amps & speakers (always a kid) & do a lot of my own work but that is it.
    I just realized I add nothing to this conversation. Sorry! Lol
    Good luck btw.
  4. Apr 12, 2019 at 2:20 PM
    Fourth_4Runner
    D
    2014 4Runner SR5
    Hi J Cat, thank you for the response and the schematic. I see that it's for a 2010, but it gives me another option and support for the option. I will give it a try this weekend.
  5. Apr 12, 2019 at 2:54 PM
    j cat
    j cat New Member
    massachusetts
    its is the 5th gen wiring .. also I am not an expert on how these are wired but from info I got the door switches and the PCM / ECM controls the dome lamp and puddle lamps .. so looks like the dome has 12 volts on it then the ground wire is the turn on wire which the door ground switch and also the PCM / ECM..
    so my guess is wire the LED lamps to 12 volt fused feed and then the ground should connect to the dome ground from the PCM/ECM..
  6. Apr 19, 2019 at 9:06 PM
    Fourth_4Runner
    D
    2014 4Runner SR5
    Hi J Cat,
    I am new here and it took a bit to find how to respond to you. I have tested every wire in the diagram, and I could not make a solid determination. There is a shop that is local that will complete the electrical connection for me, and I am planning to take it to get it finished.
    Thank you for al your input, I super appreciate it.
  7. Apr 21, 2019 at 1:19 PM
    j cat
    j cat New Member
    massachusetts
    those diagrams are 5th gen runner wiring . the hard part to find the ground wire on the dome lamp . info I found is the door switches and the computer control that lamp circuit .
    dealership may give you the exact location of that ground control wire.
    also try using the driver door switch .. remove switch and use meter to find the ground and the wire to lamp. see if that will ground the circuit lamp when switch is pushed in / closed position.
