2014 Head Unit will reset itself randomly - Fuse issue?
Discussion in '5th Gen 4Runners (2010-2024)' started by Prime4Runner, May 5, 2025.
  1. May 5, 2025 at 12:16 PM
    Prime4Runner
    Prime4Runner [OP] New Member
    2014 Limited 4WD
    I have a 2014 Limited with JBL sound system/head unit. It will randomly reset itself when I am driving. Wondering if this is a simple fuse replacement or if there may be a bigger underlying issue going on? I have had it since last July and LOVE it, but I find the resetting of the system an annoyance. I will replace it with a newer one if needed and it is possible, but figured I would start by seeing if anyone else has had this issue and or resolution. Thanks in advance!
  2. May 5, 2025 at 12:28 PM
    2016SR5P
    2016SR5P New Member
    Massachusetts
    2016 SR5P 4WD
    Just went thru the same thing with my 2016 non-JBL unit. Didn't want the hassle of taking it somewhere and paying somebody to tell me they can't figure out what's wrong with it. So, I just replaced it. Wanted something with CarPlay anyway. Couldn't have been a fuse though because the replacement works flawlessly. Went with a Pioneer 4600NEX:
    https://www.soundoftristate.com/pio...6t8B79RVKDQd8jpjtbImcqQrZMLHcOp4Piek5Cy_506e_
  3. May 5, 2025 at 12:40 PM
    Prime4Runner
    2014 Limited 4WD
    Did you have to make any mods for it to fit?
  4. May 5, 2025 at 1:27 PM
    2016SR5P
    2016SR5P New Member
    Massachusetts
    2016 SR5P 4WD
  5. May 6, 2025 at 6:51 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    If you go through Crutchfield, you can get everything you need for a fairly painless install. There's no reason to have to modify anything or cut any wires.
  6. May 6, 2025 at 9:09 AM
    Prime4Runner[OP] and catbrown357 like this.
  7. May 6, 2025 at 10:48 AM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    Before replacing it, try reseating (and maybe cleaning) all of the connectors on the head unit. Could be some oxidation / corrosion on the pins causing intermittent connectivity issues.
  8. May 6, 2025 at 11:02 AM
    Prime4Runner
    2014 Limited 4WD
    Sounds like it is a known issue with Bluetooth (in doing more research) and that a software update would resolve - now down the rabbit hole to find the software.
  9. May 6, 2025 at 11:52 AM
    hvac guy
    hvac guy New Member
  10. May 6, 2025 at 12:59 PM
    Prime4Runner
    2014 Limited 4WD
    You freaking ROCK! I found an older site (wayback machine) but it was a deadend! Thank you for this! @hvac guy
    roooo likes this.
  11. May 6, 2025 at 1:49 PM
    KCSilverTEP
    KCSilverTEP New Member
    2016 Silver TEP
    mostly stock for now
    I had the same issue with my 2016 trail premium. I switched back to the original SD card for the map and no longer had any issues. I suspect my updated SD card map failed.
    Prime4Runner[OP] likes this.
  12. May 6, 2025 at 2:36 PM
    Prime4Runner
    2014 Limited 4WD
    I did see the SD card could be a culprit but I am going to try the updated software first and see what happens! Will do SD card if it doesn't resolve. Did you get the SD card from a dealer or able to get it online? @KCSilverTEP
  13. May 6, 2025 at 8:26 PM
    totmacher
    totmacher New Member
    Daniel
    West TN
    2018 SR5 Nautical Blue
    done some stuff to it
    Software update via USB is what fixed reboot issue on my 2015 Sequoia last year. After that update I was able to put in a SD card of updated maps and it worked perfect except the maps did load a little bit slower when starting engine. Otherwise fine. Might be that i had cheap Amazn Chinese maps card though.
  14. May 7, 2025 at 8:14 AM
    photo8 New Member
    TRD Off-Road
    I had a similar problem on my 2018 (non JBL) last year. Kept rebooting at random times.
    I'm pretty competent with electronics and tried a variety of diagnostics without success. Finally, I tried replacing the map microSD card with an older version. Problem fixed, no more random reboots. I ordered a new map database micro SD card from Amazon any my infotainment system continues to function normally (Entune still sucks).
  15. May 7, 2025 at 12:02 PM
    Prime4Runner
    2014 Limited 4WD
    UPDATE: did the update to the firmware for the audio with the software provided by the link above (thank you @hvac guy) will monitor it over the course of the next few days/weeks and see if I encounter any issues. I ordered a new microSD card to update my maps also, so may or may not do that (totally separate)
    hvac guy likes this.
