2013 Limited Power Window Troubleshooting
Discussion in '5th Gen 4Runners (2010-2024)' started by Lot Lizard, Jan 13, 2025.
  1. Jan 13, 2025 at 5:49 PM
    Lot Lizard
    Lot Lizard [OP] New Member
    Levi
    2013 Limited
    Long story short, I had a clogged sunroof drain and some water/vinegar ingress. Fixed that issue but now I’ve lost power to driver side window only. Also, smart keyless entry on driver side stopped working simultaneously. Assuming I’ve blown a fuse or two but not sure which. I replaced the 7.5 amp and 25 amp “Door” and “Door D” cabin fuses which looked fine with no change. Any ideas? The LED light on the driver door switch only is off (see attached).
