2011 4Runner rear key switch
Discussion in '5th Gen 4Runners (2010-2024)' started by lmc123, Nov 28, 2022.
  1. Nov 28, 2022 at 11:52 AM
    lmc123
    lmc123 [OP] New Member
    Logan
    2011 Black 4Runner SRF
    Hey guys,
    I have a 2011 4Runner SR5. The interior switch to raise/lower the rear glass works perfectly but whenever I insert my key in the rear switch on the hatch the key does not turn left or right. Any suggestions?
  2. Nov 28, 2022 at 12:17 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    If the hatch hasn’t been opened often with the key(s) over the years you’ll find that the key doesn’t quite fit that lock anymore. The reason is that as the key is inserted into the ignition many hundreds or thousands of times it wears a little around the edges, as does the ignition lock mechanism. They usually wear in the same manner so there’s no problem. But when you insert that old worn key into the hatch lock it doesn’t match and won’t turn.
    This happened to me on my 3rd Gen that I had for almost 20 years. After 15 years or so both keys didn’t work in the hatch and barely worked in the door locks. I just lived with it because the key fob had a window up/down control button.
    whippersnapper02 likes this.
  3. Nov 28, 2022 at 12:48 PM
    scanny
    scanny New Member
    Ontario, Canada
    2022 TRD Offroad
    Had exactly same issue with my 2010 SR5. Lock probably got some rust or debris and wasn't turning at all. I fixed it by putting Break Free CLP in the keyhole, wiping out excess coming from underneath the lock and waiting for a few hours. Then I was able to turn my key just fine. Probably other quality CLPs or gun oils will do, I wouldn't put in WD-40 though, people say it attracts dust and dirt too much. But it might work too.
