Ran out of gas, gauge showed a quarter full
Discussion in '5th Gen 4Runners (2010-2024)' started by cbrannen75, Nov 21, 2022.
  1. Nov 21, 2022 at 11:39 AM
    cbrannen75
    cbrannen75 [OP] New Member
    Del
    2011 4Runner
    My wife was driving her 2011 4Runner on the highway the other day and ran out of gas. The gauge on the dash read 1/4 of a tank and the digital reading said she had 60 miles to empty. Was wondering if anyone has had this issue before or may know what the issue may be?
    Rocko9999 likes this.
  2. Nov 21, 2022 at 11:54 AM
    Lockdown
    Lockdown New Member
    Los Angeles
    2023 ORP Lunar Rock
    lol wtf.
  3. Nov 21, 2022 at 12:19 PM
    Any idea how many miles had been driven on that tank? I think it's possible that the float got stuck. Otherwise, I would think it might be a different problem. Did you put more fuel in, and did it fire back up?
    bassist likes this.
  4. Nov 21, 2022 at 12:25 PM
    cbrannen75
    Del
    2011 4Runner
    She had a full tank before running out. Yes, I put more fuel in it and it cranked right up.
  5. Nov 21, 2022 at 12:28 PM
    Doesnthe needle seem to track accurate until quarter tank? Maybe the that sensor is messed up
  6. Nov 21, 2022 at 12:59 PM
    Sounds like the tank sending unit is in need of repair/replacement.
  7. Nov 21, 2022 at 1:08 PM
    cbrannen75
    Del
    2011 4Runner
    Thanks for the feedback from all.
  8. Nov 21, 2022 at 1:54 PM
    At least it sounds like the pump is okay. :)
    McSpazatron likes this.
  9. Nov 21, 2022 at 3:56 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    Lol. When I was dating my wife, she ran out of gas a bunch of times. Although I didnt like that she was stuck on the side of the road, I didn't mind leaving work to go get the gas can and get her enough fuel to get to the gas station. After all, I got to see her during the work day on those days.
    We now have a saying in our home... "half is empty". Might be an accurate statement for you.
  10. May 5, 2023 at 4:56 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Did you fix this? What was the issue?
  11. May 5, 2023 at 5:26 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    My wife seems incapable of buying gas before the orange light comes on. She does watch the trip odometer and miles remaining, so she never actually runs out, but she has a lot more tolerance for low fuel levels than I do.
    nimby, ValK83 and Ironguy like this.
  12. May 8, 2023 at 8:19 AM
    Rocko9999
    2011 Limited
    So it wasn't a faulty sending unit or gauge?
  13. Jul 3, 2023 at 9:10 AM
    Cityredneck
    Cityredneck New Member
    2005 RWD 4.0 & '97 4WD 3.4
    I've driven 4 different models of Toyota ranging from 2005-13, and all of them had sloppy fuel gauges. It's a pretty standard Toyota issue, although they may have fixed it in their newer models. If you keep track of your mileage and what kind of driving you're doing (highway vs stop & go) you'll get a pretty good sense of how many miles you should get per fill (once I had a 22 gal tank run out @ 325 miles, but there were extenuating circumstances). Play it safe and go with 17/18 mpg & you'll never run out.
    There may be a fuel gauge upgrade (I'm not familiar with one) but don't expect any improvement if you replace with oem parts.
  14. Jul 3, 2023 at 9:26 AM
    Rocko9999
    2011 Limited
    Mine was faulty sending unit.
  15. Jul 3, 2023 at 1:07 PM
    That's odd to hear. I've had 10 different Toyotas (1985-2019) and none have had a sloppy fuel gauge. The only thing I have ever noticed is that the level can fluctuate in the 4runner on steep climbs and descents. But, it rights itself on level ground.:notsure:
    nimby and HotelMedicis like this.
  16. Jul 3, 2023 at 1:21 PM
    Cityredneck
    To be fair the sloppiness on the gauge was relatively minor except on the 2005 4runner. The inconsistency is most noticeable after starting up, when you regularly get lower readings that can often take a while to go back up. On another note, the idiot light is way more inconsistent and regularly comes on with 1/4 tank left & then turns off again with all three models and four years. I'll take a sloppy fuel gauge over a sloppy odo or speedo any day though.
    HotelMedicis and Thatbassguy like this.
  17. Jul 3, 2023 at 1:45 PM
    Agreed!
    And, good point earlier about keeping track of your miles per tank. I'm pretty confident that I would know if my fuel gauge crapped out because I am always tracking this.. I reset the "trip A" odometer every fill-up because I still don't trust the computer's fuel economy readout, even though it has been pretty accurate with the '19.
    Cityredneck[QUOTED] likes this.
  18. Aug 23, 2023 at 1:49 PM
    bruce 4runner
    bruce 4runner New Member
    Bruce
    4 RUNNER OWNER 2011
    NONE
    I have a 2011 and ran out of 3 times. The latest one was one month ago and gas gauge shows 1/2 tank and about 120 miles to go till empty.
    This was while in drive-thru line at Carl's Jr hamburgers, soooo very embarrassing.
    The first 2 times was on the freeway, 1st time showing 50 miles remaining, the next showing 70 miles remaining.
    The 2nd time was the most scary as we were in the #1 fast lane and it just died.
    With so many owners with this same problem it seems it should be a recall as this is very very dangerous.
  19. Aug 23, 2023 at 2:09 PM
    TeslasBigCarbonFootprint
    2014 Neglected by the previous owners 2020 is an abused former rental... 2023 New
    Report problems like this to the NHTSA.
    As a side note, my low fuel indicator seems to be calibrated at 5 gallons left. Twice, I refueled soon after the light went on, one time while I was in line for gas the indicator went on. Both times I put 18 gallons in the 23 gallon tank.
  20. Aug 23, 2023 at 2:15 PM
    bruce 4runner
    Bruce
    4 RUNNER OWNER 2011
    NONE
  21. Aug 23, 2023 at 2:16 PM
    Or you might get contacted by Toyota with a fix. They did have a fuel pump recall a few years back...
  22. Aug 23, 2023 at 2:49 PM
    Rocko9999
    2011 Limited
    Replace your sending unit.
  23. Aug 23, 2023 at 2:50 PM
    Rocko9999
    2011 Limited
    Not applicable. It's the sending unit. I replaced mine. Fixed the issue.
  24. Aug 23, 2023 at 3:13 PM
    Do you reset the trip odometer when you fill up? Seems like it could save you some trouble. If it happened to me once, I'd never trust the gauge again.
    As far as "so many owners" having this problem; it seems pretty rare to me. I've never heard of it happening until last November, and I've been driving Toyotas since the mid-90's.
    SlvrSlug and nimby like this.
