2010 SR5 - Suspension Leveling and Mild Lift Questions...
Discussion in 'Suspension' started by SigP415, Dec 31, 2024.
  1. Dec 31, 2024 at 1:31 PM
    SigP415
    SigP415 [OP] New Member
    Fair Oaks, California (Sacramento County)
    2010 SR5
    Hi All,
    Just got a new to me 2010 SR5!
    Looking for pictures and experiences with these two set ups I'm considering... and other thoughts as well. Did a search, lots of results with a mixture of the following parts. Also going for budget at this stage.
    1) Level out the front with the rear:
    • Bilstein 5100 24-328258 front shock set at middle perch 1.75"
    • Stock rear leave as is
    2) Mild ~2.5" Lift:
    • Bilstein B8 5100 24-328258 front shock set at top perch 2.5"
    • Bilstein B8 5100 33-313146 rear shock
    • Bilstein B12 36-281817 rear coil 1" Lift
    Will both of these get me level or close to it? (I'm in the not a fan of rake, camp.)
    Won't be adding heavy steel bumpers, RTT (any time soon at least). Just kids and camp gear.
    This will be 90% grocery getter, 10% car camper/overlander.
    Thanks!
  2. Dec 31, 2024 at 3:57 PM
    White TuRD
    White TuRD New Member
    SC
    2021 TRD ORP
    In retrospect, I wish I had done a level lift instead of 2.5” just to keep things simpler.
  3. Dec 31, 2024 at 3:59 PM
    icebear Recovered Kia Owner
    I could be completely wrong but I was under the impression that 5100’s at the lowest setting at just under an inch was a level but don’t quote me.
  4. Dec 31, 2024 at 4:22 PM
    SigP415
    2010 SR5
    Tell me more.
  5. Dec 31, 2024 at 4:43 PM
    White TuRD
    SC
    2021 TRD ORP
    '21 ORP is my wife's daily driver/grocery getter. We take it off road a couple times a year... "off-road" is defined as not asphalt (hint: it's not really "off road"). So modifications have been primarily for aesthetics. I tend to be very pragmatic with cars since I am the one turning wrenches on them.
    At delivery, we had TRD wheels with 265/70 C-load BFG KO2's installed. It looked good, but wife still wanted a lift. For Christmas a couple years ago, I got her the Eibach stage-1 lift (+2.75"). Lift looks good, and rides nice, but tires look small.
    Now we need to upgrade to 285s. On 7" wide wheels (too narrow). Will it rub/how much trimming needed? How will it ride? Will the droning on the highway be annoying?
    This is the can of worms you open with a 2"+ lift, when leveling it with some 255/75 trail terrains would have been perfectly sufficient and aesthetically pleasing.
    My only gripe with the Eibach kit is the rear springs sag less than expected and the fronts sag more than expected giving a bit more rake than I'd like. That, and the 265s look small. Otherwise, ride quality is great for a lifted truck.
    SigP415[OP] likes this.
  6. Dec 31, 2024 at 4:51 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    Leveling your vehicle is fine if you want to reduce your departure angle, and increase the likelihood of catching your rear bumper on something.
    If you want to level and not hurt your departure angles, you’re going to need to lift the rear.
  7. Jan 1, 2025 at 4:10 PM
    SigP415
    2010 SR5
    That's what I've read as well... first setting at 0.85" levels it out... but also read that the middle 1.75" is the setting to level.
  8. Jan 1, 2025 at 4:15 PM
    SigP415
    2010 SR5
    Thanks, for this reminder.
    I lost a rear bumper in Death Valley last year... I'm heading to the same spot in Feb., so don't want a repeat of that.
    bassist[QUOTED] likes this.
  9. Jan 2, 2025 at 3:36 AM
    bassist
    bassist New Member
    Bring an off-roading bumper and some tools.
    That way, you don’t have to do the work of removing the bumper yourself!
  10. Jan 2, 2025 at 6:33 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Since you have camping in mind, I'd recommend keeping a little bit of rake.
    You don't want to be nose high after you load up with camping gear.
    From the factory, there is 2" of rake on your rig... I'd keep 1" minimum.
    The TRD Pro 4Runners come with Fox suspension. If you can find some low mileage take-offs for a decent price I'd run that. You'll get roughly a one inch lift up front. They're still very comfortable and the front shocks actually have a slightly longer extended length, unlike a lot of aftermarket options.
    The bilstein 5100 also have an extended length and they're at a great price point. So that would be my second choice if I couldn't find a good deal on some lightly used TRD pro suspension.
  11. Jan 30, 2025 at 9:52 PM
    SigP415
    2010 SR5
    Closing the loop…
    I ended up going:
    Before:
    After:
    Kept the rake per 1SilverRunner‘s recco above. There is the 4runner lean in effect.
    37” front driver
    37” front passenger
    38” rear driver
    39” rear passenger
    Mechanic did say after install, that if we did top perch at 2.5” I would’ve needed adjustable upper control arms.
    White TuRD, 1SilverRunner and java like this.
  12. Feb 4, 2025 at 5:52 AM
    1SilverRunner
    Tejas
    Looks great!
    SigP415[QUOTED][OP] likes this.
