2007 4Runner right passenger side clunking
Discussion in '4th Gen 4Runners (2003-2009)' started by Adam12, Jan 2, 2019.
  1. Jan 2, 2019 at 6:49 AM
    Adam12
    Adam12 [OP] New Member
    I am wondering if anyone can help meout?I have a Toyota 4Runner 2007. 114 k baby miles had a clunking on the driver's side front end so I replace the sway bar bushings and sway bar links which did quiet it down. But now I have the clunking back again could it be the A frame bushings or is there something else I should look at the struts seem fine?
    Ty,john
  2. Jan 2, 2019 at 9:24 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    4WD or 2WD?
  3. Jan 2, 2019 at 9:47 AM
    Adam12
    Hi...
    It's a four-wheel drive Ron
  4. Jan 2, 2019 at 9:47 AM
    Adam12
    I looked underneath it took the wheels off I do have new sway bar bushings in the front and new sway bar links in the front I'm thinking it could be the a frame bushings that are one
  5. Jan 2, 2019 at 5:06 PM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    when does the clunking happen? is it during turning, over bumps? could you replicate it by pushing down and compressing suspension?
  6. Jan 3, 2019 at 3:50 AM
    Adam12
    No I can't replicate it by pushing down on the car it's not the struts if I go over a series of small bumps it kind of go Kong Kong Kong Kong and then go right away once I clear the bumps not a loud clunk soft
  7. Jan 25, 2019 at 7:21 AM
    Batmango66
    Batmango66 New Member
    Tye
    N.E. Hoosier Land
    2006 Limited
    '06 Limited V8 Shadow Mica | USB Charger | OCD Console Organizer| Int. LEDs | Always on Fogs Mod | added LED strip light foot well | Smokers kit | Always on 115v | Always on 12v Cig. Lighter Mod | By-passed TPS | Wind Deflectors | 3/2 Corn Fed | 18" Moto Metal MO962 0 offset with General Grabber AT2 275/65's | Bilstein 5100's | 15% tint min. | 22" LED Light Bar Behind lower Grill | TINMANS Awesome Front Cup Holder. Yeah, I know it's mostly convenience and looks...
    Mine is doing the same thing, I replaced the bushings, no change, I think it is in the strut tower, I am hopefully tearing into it next week. If I find it, I'll let you know.
  8. Mar 22, 2019 at 12:10 PM
    Benny123
    Benny123 Toyota enthusiast
    Southeast Charlotte, NC
    2016 Nautical Blue SR5 Premium
    LEDs all around, otherwise bone stock.
    Check your skid plates if you just did all the bushings. Make sure theyre all snug.
  9. Mar 22, 2019 at 3:17 PM
    Batmango66
    Tye
    N.E. Hoosier Land
    2006 Limited
    Skid plates are solid, even when it’s on the lift, you can (attempt to) shake everything in the front end and it’s all solid. I was almost afraid the rig was going to fall off we were shaking it so hard... Mine only happens at the bottom of a hill with an abrupt change in grade, like pulling out of the drive that falls toward the street then the curb gutter falls back towards the drive, when I hid that valley “clunk”. Speed bumps are hit and miss, it’s as if only when there is backwards force on the front wheels. I haven’t tried bumping a curb straight on to see if that will replicate it. Skid plates are the first thing I thought too.
  10. Apr 28, 2019 at 7:59 AM
    Benny123
    @Batmango66 @Adam12 Did you figure this out? Mine started clunking again, same as you describe above, on the right side as well. I replaced my clunking OEM sway bar end links with some Valucraft ones from AutoZone a year ago. Same sound as before, now back. I'm starting to think that they're just shitty and I need better ones.
    I already did my struts and sway bar bushings.
  11. Apr 29, 2019 at 6:28 AM
    Benny123
    My hunch was correct. Bad sway bar links. Worse on passenger side. Will post a video soon. Bought Duralast ones this time with the lifetime warranty and we'll see if the last longer than a year. Definitely more solid than what came out.
  12. Apr 29, 2019 at 7:45 AM
    TN_FunRunner
    TN_FunRunner Custom Title
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    This sounds like the same issue I’m having on my 18.
    Looking forward to the vid
  13. Apr 29, 2019 at 8:16 AM
    Benny123
    Heres the short little video.
    End links should not be this easy to move. Clunk clunk clunk. 2 out of 4 joints were doing this.
    https://www.youtube.com/watch?v=v44wkTavqbw
    New ones took two hands and significant effort to move.
    jgcaps and SlvrSlug like this.
  14. May 1, 2019 at 12:59 PM
    Batmango66
    Tye
    N.E. Hoosier Land
    2006 Limited
    I have not had the chance to dig into it but, I can say, after seeing this, I ordered new sway bar links. Thank You for posting and following up!!
    Benny123 likes this.
