2006 headlights in a 2005?
Discussion in '4th Gen 4Runners (2003-2009)' started by Angel pino, Jun 2, 2021.
  1. Jun 2, 2021 at 6:16 PM
    Angel pino
    Angel pino [OP] New Member
    Angel
    Plateada 4runner 2005
    Saludos a todos y gracias por permitirme ser parte de este sitio, soy nuevo y es poco lo que se para plantear una pregunta, quiero saber si puedo adaptarle a mi 4runner 2005 los faros delanteros de la 2006, cambiando los filler de faros
    Translation by staff:
    Greetings to all and thanks for allowing me to be part of this site, I am new and there is little I know to ask a question, I want to know if I can adapt the headlights of the 2006 to my 4runner 2005, changing the headlight fillers
    Mohoman likes this.
  2. Jun 3, 2021 at 2:47 PM
    Bob
    Bob Member Staff Member
    Bob
    I did a google translation but it might not be accurate
    y=mx+b likes this.
  3. Jun 4, 2021 at 6:06 AM
    y=mx+b
    y=mx+b New Member
    2005 SR5 v6 4wd
    It came out making sense to me, thanks Bob
  4. Jun 4, 2021 at 6:09 AM
    y=mx+b
    y=mx+b New Member
    2005 SR5 v6 4wd
    Yes you can. There is a thread on t4r.org about it too with more detailed instructions on the wiring of both headlight and bumper turn signals together. But you don't have to do that. I just left the stock bumper signals for now
    You need a 9006 to H11 adapter for the low beams. 2005 uses 9006 low beams and 06 uses h11 low beams
    High beams are a direct swap
    parking lights are a direct swap
    2006 Filler pieces for under the headlight
    Blank plug for 06 turn signal. This is to keep water out of the open hole. Just leave the current turn signal in the bumper filler if keeping stock bumper. if going aftermarket, than you can wire in a real plug in the 06 housing, but its not needed
    Here is a google translate to spanish of the above text:
    Sí tu puedes. También hay un hilo en t4r.org al respecto con instrucciones más detalladas sobre el cableado de los intermitentes de los faros y los parachoques juntos. Pero no tienes que hacer eso. Acabo de dejar las señales de parachoques de stock por ahora
    Necesita un adaptador 9006 a H11 para las luces de cruce. 2005 usa 9006 luces de cruce y 06 usa luces de cruce h11
    Las luces altas son un intercambio directo
    las luces de estacionamiento son un intercambio directo
    2006 Piezas de relleno para debajo del faro
    Enchufe en blanco para intermitente 06. Esto es para mantener el agua fuera del agujero abierto. Simplemente deje la señal de giro actual en el relleno del parachoques si mantiene el parachoques de serie. Si va al mercado de accesorios, puede conectar un enchufe real en la carcasa 06, pero no es necesario
    06 headlights in an 05 pictured below
    mCYG70qD0yARGHcV9bX5DXhbfVctkvlpbbBLQjOK_e79fd6770bc3adb76f69122ca25b569a3fe9c9a2.jpg
    RonT4R, Bob and Mohoman like this.
