2006 A/C replacement
Discussion in '4th Gen 4Runners (2003-2009)' started by tpa4runner, Jun 14, 2016.
  1. Jun 14, 2016 at 10:57 AM
    tpa4runner
    tpa4runner [OP] New Member
    I need to replace the A/C compressor in my 2006 V6 4runner. Does anyone have a write up or video on how to do this? An internet search returned no results for the 4th gen 4runner. I've replaced the A/C in other vehicles I've owned just would like a heads up so I know what I'm in for on this one.
  2. Jun 14, 2016 at 7:14 PM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    ive got the service manual and have the instructions on how to replace, hope that helps
  3. Jun 15, 2016 at 7:32 PM
    tpa4runner
    Thank you, that will definitely help!
  4. Jun 30, 2016 at 11:19 AM
    Jbriggsnh
    Jbriggsnh New Member
    Joe
    2004 4runner
    What are you replacing? How do you know what you need to replace? I am thinking of the components:
    - compressor
    - compressor clutch
    - cooler
    - evaporator
    - temp/thermostat controls
    Here is a FSM manual link:
    http://www.customtacos.com/tech.old/files/05FSM/repair.html
    Here is removing the AC:
    http://www.customtacos.com/tech.old.../06toyrm/06toypdf/06rmsrc/rm2006ta/046004.pdf
    I am in the middle of replacing a head gasket and nothing comes off without having to take 20 others off first. Good luck, bag & label your parts, and be patient.
    BTW - I had to remove the compressor, but I had first pulled the radiator shroud (easy), cooling fan (easy), the radiator (pain - you have to drain your coolant, and disconnect your transmission cooler lines (messy, but easy)), alternator (pain), then compressor. 4 bolts hold it on and one is just a pain to reach.
  5. Jul 4, 2016 at 1:16 AM
    tpa4runner
    I found a great fix, a NEW MECHANIC!!! After getting a THIRD opinion it wasn't my A/C that was causing my issue, it was that the previous mechanic who had installed the serpentine belt wrong....Twice!!! So it was eating the belt!!!!!. After getting the belt on correctly, I have had no problems. Third opinion..... PRICELESS!!
    Yet I still find it disturbing that a second place wanted to charge me $700 plus to replace my A/C Compressor because " It must be the A/C Clutch".
  6. Jul 4, 2016 at 11:47 AM
    Chris
    Chris New Member
    Chris
    '05 4Runner Ltd
    This and that
    Never undersetimate a good mechanic! Glad you found a cheap solution!
  7. Oct 9, 2017 at 10:54 AM
    tfbeverly723
    tfbeverly723 New Member
    I just had this same problem with my 2006 SR5 4WD. The shop is next door to my office so I dropped it off for an inspection. They came back and said it was the cabin air filter. $98+ Tax !!!! Wtf Firestone?!?!
    Edit:: I'll be picking up a new air filter from a parts store this afternoon.
