2006 4Runner SR5 4.0 4x4
Discussion in '4th Gen 4Runners (2003-2009)' started by SMOKEEATERFF, May 21, 2024.
  1. May 21, 2024 at 11:52 AM
    SMOKEEATERFF
    SMOKEEATERFF [OP] New Member
    Clay
    2006 White 4Runner
    I bought a new to me 06 4Runner 4.0 4x4 a while back. It has a few check engine codes and I’m trying to figure out where to start on addressing them. The codes are
    P0016
    P0335
    P0340
    P0325
    And of course the vsc light is on. I’m hoping I haven’t screwed myself with a costly repair. The vehicle is in pretty good shape and drives well for 220,000 miles.
  2. May 21, 2024 at 6:22 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Welcome Clay!
  3. May 21, 2024 at 6:25 PM
    Dabigono
    2020 4Runner
    Welcome Clay!
  4. May 21, 2024 at 6:45 PM
    P0016:
    P0335:
    P0340:
    The code is pointing to a mismatch in sensor output. This is indicative of timing being off... or, if it's not that, either a bad crank or cam sensor or wiring. Luckily, TOYOTA uses mostly non interference engines so you should be ok.
    P0325:
  5. May 22, 2024 at 6:35 AM
    SMOKEEATERFF
    Clay
    2006 White 4Runner
    I’m gonna check wiring and then the cam sensor and go from there. The vehicle drives fine with no issues that I’ve noticed.
