2006 4runner SR4 won't move after parked for one month
Discussion in '4th Gen 4Runners (2003-2009)' started by unixplus, Sep 10, 2018.
  1. Sep 10, 2018 at 5:14 AM
    unixplus
    unixplus [OP] New Member
    2007 white 4runner
    n/a
    Hello,
    I am new to this forum. I have some mechanical experience on old MB diesel.
    I bought the truck last year and added about 10000 miles on her . Last month, we parked the truck in garage and everything is fine. We came back on last weekend, we found the truck won't move no matter which gear it is on.
    The truck was started right away. But tried all gears, it just did not move at all.
    If I put the 2/L gear, and press gas pedal, it only moved about 2-3cm.
    Tried other gear, even 'N', no movement at all, so can it be towed it?
    Seems the wheels are dragged by something. I searched around, some threads says e-brake malfunctioning? I checked the floor, did not seems there is any fluid on the floor, so no trans fluid was leaking, by the way, where can I find the trans dipstick?
    any help is appreciated.
  2. Sep 11, 2018 at 3:49 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Brakes frozen?:notsure:
  3. Sep 11, 2018 at 5:18 AM
    billnourse
    billnourse New Member
    Bill
    Bloomfield, NM
    2017 4Runner TRD Off Road Premium
    Toytec Ultimate lift, SSO Slimline bumper and 10,000# winch, emblem blackout, hood scoop wrap.
    My 2002 Chev. Duramax with Allison trans. will do this sometimes. Have to let it run for a couple of minutes and get the torque converter filled back up. It seems they will drain into the pan if they sit for a period of time.
  4. Sep 11, 2018 at 1:30 PM
    That's what you get for being cheap and getting the SR4 instead of the SR5.
  5. Sep 11, 2018 at 1:44 PM
    unixplus
    2007 white 4runner
    n/a
    SR5 typo.
    Called mechanic , told me it is brake frozen he suggested to try to shift to d and r to unfreeze it.
    Thank you all for help. Will try it. And report it back.
  6. Sep 13, 2018 at 9:58 AM
    unixplus
    2007 white 4runner
    n/a
    Tried today and she finally moved. Will drive to mechanic to see which caliper with issues. Avoid towing , a good result.
  7. Sep 13, 2018 at 10:21 AM
    xdelmar
    xdelmar New Member
    Bob
    Currently San Felipe, Baja.
    Prospective buyer of 4th gen
    I want to travel and camp and will do Mod's necessary to do this with a 4runner.
    Please report back what you mechanic says was a probable cause. That way, we all will gain here.
    Thanks,
  8. Sep 14, 2018 at 1:58 AM
    unixplus
    2007 white 4runner
    n/a
    Exact like Ront4r mentioned it is brake frozen. I shifted to lowest gear gas pedaling , she reluctantly moved couple centimeters , then shifted to R , moved another couple cm , then again, then she moved like should be. Definitely need drive to mechanic to check which caliper piston is frozen.
  9. Sep 14, 2018 at 9:03 AM
    xdelmar
    xdelmar New Member
    Bob
    Thanks for the update. Good info to know.
