2005 SR5 Upgrades
Discussion in '4th Gen 4Runners (2003-2009)' started by DailyRunner, Aug 1, 2019.
  1. Aug 1, 2019 at 6:29 PM
    DailyRunner
    DailyRunner [OP] New Member
    Hi yall,
    I am super excited to be the new owner of a 2005 SR5!
    I am looking to start making modifications to it. Right now I am looking to put a 3" lift and 33" wheels. Right now I am looking at the Bilistein 5100 Coilovers, XD798 Adicts 16" for wheels, and KO2 285/75/R16 for tires.
    I guess the main question is will this combination work? I have an idea about how it will look but I am worried about it not fitting together correctly.
    Also how would it work for a spare? Would it be able to fit where the spare is now or will I have to buy a swing for the back?
    Any advice?
    Side note, the next thing would be Sliders. Where should I look for a simple bolt-on design?
    Thanks!!
  2. Aug 2, 2019 at 5:46 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    How many miles on your SR5? Rear differential ever serviced? transfer box? Front differential?
    How about chassis rust? Sway bar replacements? Lower arms with new bushing assembly.
  3. Aug 2, 2019 at 8:00 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Before you start tearing stuff apart best check your lower control arm cam bolts. If you lift it near 3" It will require camber/caster adjustments.
  4. Aug 2, 2019 at 10:36 AM
    aolson6
    aolson6 New Member
    Andrew
    2005 SR5 4X4
    3" Toytech Lift with Coilovers and Toyo Open Country AT 285s
    Nice! I have the same year and went with this: You can spend the extra $1000 and go with this: But I am not sure it is worth the extra.
    I am running the same size tires, but did not get the spare...you will probably have to mount that on a swing.
    Have fun!
    Rdesouza74 likes this.
  5. Sep 15, 2019 at 1:03 PM
    1grfe4x2
    1grfe4x2 New Member
    4runner 4x2 sr5 2008
    Dear Fellows, someone know if the rear diff of a 2008 4x2 sr5 4.0L is a limited slip or is a normal diff? the question is because I heard if I put a non LS type into a LS diff type this will broke my diff.
    Looking forward to hearing from you, also thank's in advance. (sorry for my english, is not my native language)
  6. Sep 16, 2019 at 2:49 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    Pretty sure 4runners don't have limited split - just cars. I used Valvoline 80-90W (conventional) when I changed mine 6 months ago (3 quarts GL-5)).
    Use synthetic is recommended. Take fill plug out first.. drain and fill.
    SR5 145,000 miles, 2WD V6
    Synthetic where I live was 5 times the costs of conventional Valvoline.
