2005 ABS Module Motor Seized
Discussion in '4th Gen 4Runners (2003-2009)' started by Trace4711, Mar 9, 2018.
  1. Mar 9, 2018 at 6:31 AM
    Trace4711
    Trace4711 [OP] New Member
    2005 Silver 4Runner Limited
    Hoping someone can answer this...I have a 2005 4Runner Limited with 201,100 miles. A couple of weeks ago my brakes went out. Brought it to Firestone and after hooking it up to the computer, told me I need a new ABS module....a very expensive repair. Had the car towed somewhere else with the intention of having a used one put in and selling it. Got a call from the mechanic, less than an hour later, saying it was fixed. Apparently, the motor for the ABS module seized and he got it going. He said he can pull it and clean up the motor and he thinks it should be ok. My question is would you trust it not to seize again and what possibly caused it to seize to begin with. Can there be something wrong with the module that caused it to seize or did the motor just seize and that is what caused the failure. Any insight is appreciated. Thanks so much!!!
  2. Mar 9, 2018 at 8:29 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Well if it happened once and it's the same part I am pretty sure it will happen again sometime in the future. Check around on Craigslist and junkyards for a used replacement.
