2004 Projector Retrofit
Discussion in '4th Gen 4Runners (2003-2009)' started by Tony Ironsides, Jul 26, 2018.
  1. Jul 26, 2018 at 4:27 PM
    Tony Ironsides
    Tony Ironsides [OP] New Member
    Zachary
    04 Sport V8 4WD
    2.5" Dobinsons Springs/struts up front, .5" Dobinsons Spring/Shocks in rear; 255/80R17 Cooper STMAXX
    Curious as to what people have found to be a good retrofit kit and/or projector assembly replacement? It appears that most of the aftermarket headlight housings aren't the greatest quality. Because of this, Im leaning towards retrofitting projectors into my stock housings and possibly replacing the plastic if available. Any advice helps, thanks.
    2004 4RUNNER SPORT V8
  2. Dec 19, 2018 at 6:09 AM
    Yoda4R
    Yoda4R New Member
    Brian
    South Dakota
    2003 V8 4WD SR5. White with gray cladding.
    Amber marker lights in grill. HIR lights. Kenwood Excelon head unit.
    The Retrofit Source. Reach out to their customer service team and they'll be able to help you out.
  3. Dec 19, 2018 at 1:54 PM
    That_Titanium_4RNR
    That_Titanium_4RNR New Member
    Michael
    Greenville NC
    2006 Titanium Limited V8 4X4
    Dobinsons awning, TPMS Bypass, AIP Bypass, HCF Delete, LED License Plate Lights, LED Reverse Lights
    You could just put some 06-09 headlight assemblies in. They have projectors from factory. You will need to read up on this swap if you decide to do it, because it is not a straightforward swap, but it can and has been done.
  4. Dec 19, 2018 at 4:48 PM
    f250_
    f250_ New Member
    Ben
    2003 4runner SR5 4wd
    lifted, tires, roof rack, RTT, etc
    Retrofit source. I haven't messed with it at all, but every time I've looked into it the experts who like playing with HID retrofits all say the same thing.
    You can do the 06-09 headlight, but you'll need to replace the grill as well for an 06-09 one as well. That's never made sense to me before, you could get a really prime retrofit setup for what you would end up spending for a set of stock projector assembly's and a different stock grill. my .02
    Yoda4R likes this.
  5. Dec 21, 2018 at 7:22 AM
    That_Titanium_4RNR
    Michael
    Greenville NC
    It doesn't require a new grill. Just the plastic bumper filler underneath and they're like 10 bucks each haha....there will be a slight gap but its not bad at all and most people wouldn't even see it
    f250_[QUOTED] likes this.
  6. Dec 21, 2018 at 7:26 AM
    f250_
    f250_ New Member
    Ben
    Really? I've never seen the new headlights paired with the older grill before. I just knew they didn't match up perfectly. You got any pics of that combo?
    If this is the case it changes my mind.....
  7. Dec 21, 2018 at 7:31 AM
    That_Titanium_4RNR
    Michael
    Greenville NC
    This is a guy in my area, he said that bulb connector adaptors will be needed to
  8. Dec 21, 2018 at 7:38 AM
    That_Titanium_4RNR
    Michael
    Greenville NC
  9. Jan 18, 2019 at 8:29 AM
    Tony Ironsides
    Zachary
    04 Sport V8 4WD
    Thanks for the feedback! I'll let you guys know what I decide to do.
  10. Jan 18, 2019 at 9:14 AM
    blackoutt
    blackoutt New Member
    Southern IN
    2007 4Runner Limited V8
    Adventure Build
    I bought some Eagle Eyes brand sport headlights off Ebay for I think under $150 for my 07 limited, pulled them apart and installed G5-R projectors with a premade bracket from lightwerkz. I couldn't be happier with them. The housing quality seems the same as OEM to me (actually better just because my old ones had broken tabs and frosty lenses). The Eagle Eyes stock projectors were garbage compared to my OEM 07 projectors but the G5-R are way better than both so it didn't matter. I'd highly recommend a cheap housing with a true retrofit, and before this I wasn't an HID nazi and wasn't interested in the job but it was almost too easy with the right bracket and HID kit, took less than 2hrs.
    https://amzn.to/2AQiSuM
    Headlights from 1A auto that were Eagle Eyes brand here ^^^
