2004 4Runner 2UZ-FE fuel pressure issue
Discussion in '4th Gen 4Runners (2003-2009)' started by KCVIking406, Apr 10, 2020.
  1. Apr 10, 2020 at 11:47 AM
    KCVIking406
    KCVIking406 [OP] New Member
    Trevor
    2004 Limited 4Runner 4.7l
    Hey group!
    So I was able to figure out my last problem of not getting power to my fuel pump relay but now I am experiencing the following...
    1. I'm only getting 19psi out of the brand new fuel pump.
    2. As soon as I turn the vehicle off, the fuel pressure bleeds back into the tank immediately which in turn makes for long starts.
    I have replaced the following...
    Fuel pump
    Injectors
    Fuel damper
    Could my problem be a bad fuel pump regulator?
    Any advice would be greatly appreciated!
  2. Jun 16, 2022 at 8:49 PM
    rowdsign
    rowdsign New Member
    The Regulator is on the pump assembly along with the filter. I have the same problem. Have you found a solution yet? I’m at a loss.
  3. Jun 17, 2022 at 7:24 AM
    BionicRandy likes this.
  4. Jun 22, 2022 at 3:59 PM
    rowdsign
    rowdsign New Member
    So I believe I have found the culprit. Took the intake manifold off today and found that the intake manifold gasket had been split in half around one of the valves. Going to replace it tonight or tomorrow and see what happens.
