2003 4Runner Headlight Suggestions
Discussion in 'Lighting' started by PopThinks, Sep 10, 2018.
  1. Sep 10, 2018 at 6:19 PM
    PopThinks
    PopThinks [OP] New Member
    2003 4Runner Limited
    I've got a 2003 4Runner with cloudy headlight lenses. I thought I would replace the lens and upgrade the bulbs at the same time. I'm not interested in junk of "cool". I just want clear lenses and better illumination if possible. Suggestions are appreciated. Thanks.
  2. Sep 14, 2018 at 10:53 AM
    fmarkn
    fmarkn New Member
    05 Sport Edition 4.7
    Ceramic Brake Pads, 275-60-17 BFGoodrich, Light Bar
    I had Hazy lights and brought them back to NEW with "MOTHER'S MAG AND ALUMINUM POLISH" paste.. Using a soft cloth, apply paste ,(as if you were applying car wax) to the plastic headlight lenses. Use Plenty and keep it wet with paste as you apply it. You will feel the sense become smoother and cleaner as you progress. Work this into the entire lease. Using a clean Micro towel, wipe of DRY haze and buff sense. Repeat these steps 2-3-4 times using a fresh micro towel each time,,, buffing each time as you take off the DRY paste. The results are AMAZING.. Fast and easy Your light lenses will look like NEW... Good Luck,
    To update the brightness, use Higher Watt bulbs....
    TRD in PDX likes this.
